LOGHX v. 3.0 build 723
startin log with ....\LogHX\LogHX3.exe /D=IK2XDE
Do NOT read last view template.
I must select my view template that I save and load it.
LOG NOT save LAST view template as default.
73 de IK2XDE Andrea
73 de IK2XDE Andrea
Yes, it's new function: if "View" selected in profile or here
Вложение 337280
open selected "View", else - last opened "View".
Hello Alexei,
Updated to 723 and I got a error message when I click in Award:RDA window. 722 is OK.
Вложение 337351
Can't close any windows, I have to kill the process and restart the program.
TU 73 Egon / HA3MN
PS: I tried Award:DXCC, same error.
Is there a solution? I am using EESDR V3 with 2 RX open.
I use RX1 for SSB and RX2 for JTDX.
Problem when I start JTDX, RX1 also goes into DIGU.
I use both RX1 and RX2 over TCI, see photo setup.
73 Pat
Вложение 338033
Hello,
from vers. 725 I have serious problems with views. F.e. my main view is FT8 where should be No Radio and external program is MSHV (Freq and Mode are marked as from MSHV). If I save this view and open again, the Hamlib is marked as ON (why?) together with No Radio, the mode on radio is changed from USB-D to RTTY-R (why??) and MSHV is started up (it is not wanted in settings). If I want to stop MSHV temporarily, no matter if from LogHX panel or from MSHV directly (f.e. I need to make quick CW QSO) both programs are stopped and started again with the same problems (loop?).
No problem with previous versions.
Any idea?
Josef OK2WOВложение 338164
Solved.
I had to change the views setting and restart several times - now it is OK. Sorry for the note. 73 Josef OK2WO
Sri boys, with the testing of MMVARI functions I accidentally closed Macros panel. What it can be added back? Thanks for help. Josef OK2WO
You can not 100% сlose macros panel.
Look at here:
Вложение 339059
Pull mouse here.
Or -
LogHX\INI\loghx_view.ini - section [DigitalForm] -
MacrosPanel_Height=100 - set here 100.
TNX!
Hello,
does exist some help (how-to) for the setting of the new contest (if DLL does not exists) ?
For example VHF Reg. 1 CW/SSB contests, or local activity contests, where are QSO nr, WW loc and special exchange (QTH, name) are sent...
I tried to make macros but [myloc], [myqth] etc. do not work...
73 Josef OK2WO
This is in the plans. I hope I'll do it soon. :s10:
