4U1VIC has been dismissed from Vienna and no longer valid as 4U callsign.
4U1A is valid from UN in Vienna. Please, note this. Any questions to Andy OE1ZZZ.
Thanks for info, also 4U1A was in my log,....same problem....for WAE
But of course OLD qso with 4U1VIC are currently valid for the award.
73 de IK2XDE Andrea
ik2xde@gmail.com
You must manually set country -
Вложение 333810
Hello,
unfortunately this is not the solution.
With CTRL+C I will change DXCC country, that is not the same of WAE country.
Вложение 333823
Вложение 333829
Вложение 333824
WAE award search in the Country field, and does not find UN Vienna, but will find OE - Austria DXCC 206
and for this he will count the valid QSO as Austria and not as Unitited Nation in Vienna.
Вложение 333825
Вложение 333828
Same problem with JW9JKA from Bear Is. EU-027
In the field country we will find JW - Svalbard DXCC 259
so in the WAE award will count like Svalbard Is. JW and not JW/B Bear Is.
I hope I have explained the problem well.
73 de IK2XDE Andrea
Ok i tried, but nothing changed, i completely disabled the skins, and i also tried to select others, but nothing changes.
This loading pause occurs on the first start.
Then if I go out and come back, at the new start everything works fine.
All this always and only on the PC with multiple monitors.
73 de IK2XDE Andrea
Hi, I'm currently testing (again) the ARS-USB rotator control (Az only) from EA4TX:
Everything work perfectly when I use ARS-USB through PSTRotator.
But it is not the same:
1. When I try to configure ARS-USB in direct connect to the serial COMx port in YAESU emulation without ARSVCOM.
- It works (Az is sent to the ARS-USB) but I observe after the second or the third character (Depend of LogHX config) of the Callsign input two clicks in the relay
of the control box per character sent (It's like a ARS-USB reset for each new character sent). AZ sent is correct and rotation OK.
- I didn’t find how to control rotor start as possible with DXLog (ALT+F12 or CTRL+F12) or PSTRotator (Option: Confim Imported Data)
(Automatic starting of the rotor is problematic because not necessarily desired).
When I don't check "Auto rotation to QSO entry Call" in config, I don't know how to start the rotation.
2. When I tried to configure ARS-USB as EA4TXARS in LogHX, I received an error message "Can not open link ARSWIN !".
I tried to install ARSWIN but it doesn't work on my x64 OS and ARSVCOM is not recognized.
Am I doing something wrong?
73s Christian F8GHE
- - - Updated - - -
Вложение 334347
Вложение 334348
73s Christian F8GHE
If I understand correctly, you want to start the rotation manually.
It's here - by keys:
Вложение 334350
or by mouse -
Вложение 334351
I'll correct this problem!
I checked. LogHX uses an old version of the EA4TX program. Install last version of EA4TX ARSVCOM and configure LogHX like Swisslog - select Yaesu rotor in LogHX.
https://ea4tx.com/en/faqs/ars-usb-fa...etup/swisslog/
Hi Cristian
I want to draw your attention to one problem when controlling the rotator from LogHX. In your picture of the rotator setup, I see that you have two antennas on one rotator (10M, 2M). I use 4bander 40,20,15 and 10M on one rotator with PSTRotor. When I configured it like you (40M,20M,15M,10M) the rotator only worked on the first band (40M). The rotator did not work on the other bands. I had to configure each band separately. Then it worked. You might have the same problem. On 10M the rotator will work for you as Alexey wrote, but on 2M the hint (Rotor connected!....) will not appear and the rotor does not work.
Вложение 334362
Vlado OM3BY
Hi Vlado, with the last build 717, I didn't meet this issu. I'm able to control all bands set on the same line with a "Rotor Type" = PSTROTOR or YAESU and in Manual or Automatic control.
May be Alexei solved this issu previously !?
73s Christian F8GHE
- - - Updated - - -
Hi Alexei, Thanks very much. Now, everything works perfectly :s7:
Note: A hotkey to "stop" the rotation of the motor could be very useful. This would allow to overcome ARSVCOM or PSTROTATOR to do that.
73s Christian F8GHE
