Super. All is clear. It works perfectly. Thank you for the help - I did not find it on online help pages. 73 GL Josef OK2WO
Hello,
I found by chance in the Forum new Macros for CW/Digital: [RX: <DOAFTERRX>]
<DOAFTERRX> - Letter:
S - SAVE, C - Clear TX Window, F- Focus to QSOentry window.
Macros Example: [RX: SCF], [RX: S], [RX: SC]
Question: Why is it not listed optionally in "Rig Control" menu?
73 Josef OK2WO
Hamlib Error during RADIO1 setup
I would like to use Hamlib for the setup of my Radio ICOM IC-705 but :
1. When I select Hamlib on the Radio Setup, I received this Error message : "Error Start Hamlib"
2. In the Hamlib setup the IC-705 is missing in the list
3. Hamlib files in the folder Hamlib seem very old (2014). How to update them ?
Вложение 326696
I tried to installed the last version Hamlib 4.4 but it is the same.
This setuo is not clear for me :s9:
73s Christian F8GHE
Hi Christian, I have installed a new Hamlib on PC and thereafter copied the files to the Hamlib subdirectory under LogHX. Works, but I still get the Hamlib error message on LogHX start up. Choosing Hamlib from the radio drop down menu makes it all work, though.
73 de LB2EG Richard
Download files from here -
https://github.com/Hamlib/Hamlib/releases/tag/4.4
hamlib-w32-4.4.zip - for WIndows 32
hamlib-w64-4.4.zip - for WIndows 64
Here is test release of LogHX with new Hamlib 4.4:
http://rx4hx.qrz.ru/files/loghx/test..._build_699.exe
Hamlib check trx connection! Turn on trx before log run! And if you use IC-705, you must select IC-705 only, otherwise there will be an error! Now IC-705 present:
Вложение 326699
Hi Alexei and Richard,
Thanks very much for your help. Now LogHX is ready with Hamlib 4.4 :p-up: and I'm able to select IC-705 !
73's Christian F8GHE
- - - Updated - - -
- - - Updated - - -
Hi Richard, Thanks very much. Now all is OK with the last LogHX build 699. Last Hamlib 4.4 is inside LogHX :p-up:
73s Christian F8GHE
Sri does not work for me: vers. 699, FT-991 connected (works OK with Omnirig with the same settings). Still "Error start hamlib" - any idea? 73 Josef OK2WO
I have just updated to 700 and I am getting 2 entries into the log when I press enter. One entry has all the details from qrz, the other is a new line with just the callsign,date and time.
When I try and delete, it asks to update the dxcc statistics, then it creates another qso line.
thanks the issue is why is it adding 2 qso's then ont deleting them without adding another back in? i reverted to an older release now and its not happening.
Check here - Setup - Net setup -
Вложение 327048
I think problem here!
I use LogHX + MSHV in my second QTH with FT-847 transceiver. Due to the specific properties of the transceiver, it is necessary to use a separate COM port, connected to the Data in/out terminal for modulation and PTT. (I also use USB interface SCU-17 but this is not important at this point.)
However, it is important that I have to manually close this COM port before running MSVH (this port is normally used for PTT/CW).
Question: Would it be possible to add "Close PTT/CW port" to be added to MSHV settings (or other external programs)?
Note: For FT-847 and digital modes, PTT via CAT cannot be used (TX modulation would not pass).
Thank you for reading, 73 Josef OK2WO
Yes. Use "View" for MSHV like here:
Вложение 327975
CAT setup will be saved in view file.
