Страница 35 из 68 ПерваяПервая ... 2528293031323334353637383940414245 ... ПоследняяПоследняя
Показано с 511 по 525 из 1017
Like Tree167Спасибо
Тема: LogHX: English version
  1. #511
    21.07.2022
    80
    20
    Thank you
    Super. All is clear. It works perfectly. Thank you for the help - I did not find it on online help pages. 73 GL Josef OK2WO
  2. #512
    21.07.2022
    80
    20
    Hello,
    I found by chance in the Forum new Macros for CW/Digital: [RX: <DOAFTERRX>]
    <DOAFTERRX> - Letter:
    S - SAVE, C - Clear TX Window, F- Focus to QSOentry window.
    Macros Example: [RX: SCF], [RX: S], [RX: SC]
    Question: Why is it not listed optionally in "Rig Control" menu?
    73 Josef OK2WO
  3. #513
    03.02.2006
    20,630
    10151
    5453
    That's a good point. I will add it in "Rig Control" menu!
  4. #514
    Low Power
    02.05.2021
    6
    Hamlib Error during RADIO1 setup
    I would like to use Hamlib for the setup of my Radio ICOM IC-705 but :
    1. When I select Hamlib on the Radio Setup, I received this Error message : "Error Start Hamlib"
    2. In the Hamlib setup the IC-705 is missing in the list
    3. Hamlib files in the folder Hamlib seem very old (2014). How to update them ?
    I tried to installed the last version Hamlib 4.4 but it is the same.
    This setuo is not clear for me
    73s Christian F8GHE
  5. #515
    25.03.2020
    30
    3
    20
    Hi Christian, I have installed a new Hamlib on PC and thereafter copied the files to the Hamlib subdirectory under LogHX. Works, but I still get the Hamlib error message on LogHX start up. Choosing Hamlib from the radio drop down menu makes it all work, though.
    73 de LB2EG Richard
  6. #516
    03.02.2006
    20,630
    10151
    5453
    Download files from here -
    https://github.com/Hamlib/Hamlib/releases/tag/4.4
    hamlib-w32-4.4.zip - for WIndows 32
    hamlib-w64-4.4.zip - for WIndows 64
    Here is test release of LogHX with new Hamlib 4.4:
    http://rx4hx.qrz.ru/files/loghx/test..._build_699.exe
    Hamlib check trx connection! Turn on trx before log run! And if you use IC-705, you must select IC-705 only, otherwise there will be an error! Now IC-705 present:
  7. #517
    Low Power
    02.05.2021
    6
    Hi Alexei and Richard,
    Thanks very much for your help. Now LogHX is ready with Hamlib 4.4 and I'm able to select IC-705 !
    73's Christian F8GHE
    - - - Updated - - -
    - - - Updated - - -
    Hi Richard, Thanks very much. Now all is OK with the last LogHX build 699. Last Hamlib 4.4 is inside LogHX
    73s Christian F8GHE
  8. #518
    21.07.2022
    80
    20
    Sri does not work for me: vers. 699, FT-991 connected (works OK with Omnirig with the same settings). Still "Error start hamlib" - any idea? 73 Josef OK2WO
  9. #519
    03.02.2006
    20,630
    10151
    5453
    How work Hamlib: LogHX run Hamlib (rigctld.exe file) with parametrs. Parametrs set Radio and COM-port settings. If Hamlib connect to Trx - it's Ok, otherwise error "Error start hamlib".
    Here is only one - Hamlib can not connect to Trx.
  10. #520
    Low Power
    16.04.2020
    89
    3
    I have just updated to 700 and I am getting 2 entries into the log when I press enter. One entry has all the details from qrz, the other is a new line with just the callsign,date and time.
    When I try and delete, it asks to update the dxcc statistics, then it creates another qso line.
  11. #521
    03.02.2006
    20,630
    10151
    5453
    Select "No" for update DXCC statictic. You need update DXCC statistic, if deleted QSO change if.
    DXCC statistic calculated when new QSO add to log.
  12. #522
    Low Power
    16.04.2020
    89
    3
    thanks the issue is why is it adding 2 qso's then ont deleting them without adding another back in? i reverted to an older release now and its not happening.
  13. #523
    03.02.2006
    20,630
    10151
    5453
    adding 2 qso's
    Check here - Setup - Net setup -
    I think problem here!
  14. #524
    15.04.2021
    80
    12
    3
    LogHX + MSHV + FT-847
    I use LogHX + MSHV in my second QTH with FT-847 transceiver. Due to the specific properties of the transceiver, it is necessary to use a separate COM port, connected to the Data in/out terminal for modulation and PTT. (I also use USB interface SCU-17 but this is not important at this point.)
    However, it is important that I have to manually close this COM port before running MSVH (this port is normally used for PTT/CW).
    Question: Would it be possible to add "Close PTT/CW port" to be added to MSHV settings (or other external programs)?
    Note: For FT-847 and digital modes, PTT via CAT cannot be used (TX modulation would not pass).
    Thank you for reading, 73 Josef OK2WO
  15. #525
    03.02.2006
    20,630
    10151
    5453
    Yes. Use "View" for MSHV like here:
    CAT setup will be saved in view file.
  1. LogHX: Актуальные релизы и история изменений.
    Ответов: 971
    Последнее сообщение: 08.01.2026, 00:04
  2. DIY UW3DI (for English OPs)
    от UU2JET в разделе КВ: UW3DI
    Последнее сообщение: 18.01.2013, 12:04
  3. KENWOOD TS-2000 (Black Version)
    от UA3IRS в разделе TS-2000
    Последнее сообщение: 16.11.2009, 20:16
  4. Navitel 2.0 Pocket PC Version
    от RX3AOE в разделе APRS
    Последнее сообщение: 26.09.2006, 03:39
  5. windows 64 bit version не ставится
    от UR4LZW в разделе Программное обеспечение
    Последнее сообщение: 12.09.2005, 23:58
