19.01.2023, 23:01 #601Standart Power
- 04.01.2019
- 101
- 38
- 32
Hi Christian
The only problem was in what format Band was written. If you wrote it as in the menu, it did not work correctly (40M, 20M...with a space). If you wrote Band without space (40M,20M...) everything worked correctly. Alexei already fixed it in 718.
Stopping the rotator would be a very nice feature.
Vlado OM3BY
22.01.2023, 19:51 #602Low Power
- 02.05.2021
- 53
- 6
24.01.2023, 21:13 #603Standart Power
- 03.01.2021
- 196
- 18
Again about award section.
After updating some awards, including the WFF,
I found this small problem, the references are sorted only on the first field (country)
and cannot be sorted by reference number. (see pictures)
I think it's more convenient to be able to choose the order,
if sorted by country or by reference, personally I prefer by reference.
Thanks for the attention
73 de IK2XDE AndreaIK2XDE Andrea - WWLoc. JN45MQ
https://www.xdenews.net/ik2xde/logonline/
RADIO Setup (update 30/08/2025)
ICOM IC-7600 - (HF - 50MHz.)
SunSDR2DX - (HF - 50MHz. - 144 MHz.)
OM Power - OM2000A+ (1.8-50 MHz. Amplifier)
OB11-3 (11 element - 3 band - 10m-15m-20m)
OB9-3 WARC (9 element - 3 band - 12m-17m-30m)
SkyWire Loop (40-60-80-160 m.)
LogHX Managers Database (update for free)
https://www.xdenews.net/managers/
26.01.2023, 15:13 #604Low Power
- 02.05.2021
- 53
- 6
26.01.2023, 18:06 #605Standart Power
- 03.01.2021
- 196
- 18
Hello,
the problem occurs with all versions.
The awards are simply sorted only with the first field (country) and it is not possible to sort them with the second field (reference).
I've personally updated and added several new awards, and they all have the same problem.
It's a small problem, which I hope Alexey will be able to solve in the next version.
Thank you.IK2XDE Andrea - WWLoc. JN45MQ
26.01.2023, 19:32 #606Координатор темы
- 03.02.2006
- 53
- 20,620
- 10150
- 5452
Ant.: UW4HW, Pwr.: ~500 Wtts
02.02.2023, 20:32 #607QRP
- 15.04.2021
- 80
- 12
LogHX, IC-7100, CW keying
Hello,
I am testing my new IC-7100 with my logs. The tcvr has a USB connection but only for CAT, no RTS or DTR is supported on the virtual COM port. It seems the only other USB / COM port could be used for CW keying.
But - I am testing it with my contest SW Tucnak (Czech made) where Hamlib (last version) is used. Voala - CW keying works via CAT perfectly. There is of course the option "CW via CAT".
Could be the same option added to LogHX radio setting?
Thanks and 73 de Josef OK2WOПоследний раз редактировалось Josef OK2WO; 02.02.2023 в 20:42.
02.02.2023, 20:45 #608Координатор темы
- 03.02.2006
- 53
- 20,620
- 10150
- 5452
03.02.2023, 22:35 #609QRP
- 15.04.2021
- 80
- 12
Sri, it is not what I mean. Excuse for my bad description of the problem. There is no option "CW via CAT" - I was playing with FLDigi where it is. Tucnak has the option "Hamlib" for CW keying:
I read on Hamlib documentation: rigctl has the command b which is "send_morse" character. A little problem is that speed cannot be controlled from a log but must be controlled by radio (no problem with IC-7100). ESC function for breaking preprogrammed macros works well. The rig poll interval should be short, 100 ms is OK.
Josef OK2WO
03.02.2023, 22:45 #610Координатор темы
- 03.02.2006
- 53
- 20,620
- 10150
- 5452
04.02.2023, 11:27 #611Координатор темы
- 03.02.2006
- 53
- 20,620
- 10150
- 5452
Please, test this version:
http://rx4hx.qrz.ru/files/loghx/test..._build_719.exe
Set CW here -
04.02.2023, 16:50 #612Standart Power
- 03.01.2021
- 196
- 18
04.02.2023, 22:04 #613Координатор темы
- 03.02.2006
- 53
- 20,620
- 10150
- 5452
05.02.2023, 11:13 #614QRP
- 15.04.2021
- 80
- 12
Tested - CW works OK, but after keying up MHz are missing:
73 Josef OK2WO
06.02.2023, 20:59 #615Standart Power
- 03.01.2021
- 196
- 18
167Спасибо
