Страница 44 из 68 ПерваяПервая ... 3437383940414243444546474849505154 ... ПоследняяПоследняя
Показано с 646 по 660 из 1017
Like Tree167Спасибо
Тема: LogHX: English version
  1. #646
    Low Power
    19.11.2019
    Nyirabrany
    11
    43
    Hello Alexei,
    Is it my problem only or others have this too?
    I started with eQSL a few weeks ago and when I downloaded eQSLs in LogHX the confirmed eQSLs not checked at all. All goes to the "Sent (eQSLS)". LoTW works fine but eQSL do this problem at me.
    Thank you for help!
  2. #647
    03.02.2006
    20,753
    10225
    5491
    Is here checked?
    You must download only CFM eQSL - ADIF from eQSL have not field "eQSL CFM"!
  3. #648
    Low Power
    19.11.2019
    Nyirabrany
    11
    43
    Thank you Alexei! This method is works! 73 Egon
  4. #649
    14.03.2022
    Oud-Turnhout
    59
    13
    4
    Hi Alexei,
    Is there any possibility that you can mount Azimuth Map LogHX via PstRotator. That you can use it to operate beam.
    73 Pat
  5. #650
    14.03.2022
    Oud-Turnhout
    59
    13
    4
    Hello Alexei,
    Is there a possibility to do the manager database update.
    73 Pat
  6. #651
    07.04.2002
    г.Москва, г.Троицк
    49
    9,498
    2570
    7707
    Arrow
    Цитата Сообщение от ON3PAT Посмотреть сообщение
    Hello Alexei,
    73 Pat
    There is no nessesary, b'coz we have QRZcom/QRZru/IK3QAR and other services to get QSL route to callsign.
    Here I do it manually If i have a time to do.
    Recently I did update it POBEDA-78 memorial within.
    This is the syntax of manager file to update database correctly:
    File Structure qslmanager.txt (or another txt file) to import into LOG
    -----------------------BEGIN-----------------------
    <3 spaces>02-may-22
    RP77A<7 spaces>RZ1OA
    RP77KO<7 spaces>RA3VE
    ON8X<7 spaces>ON8XXX
    DK0XXX<7 spaces>DA4XXX
    -----------------------/BEGIN----------------------
    ---begin-- & ---/begin--- you have to delete.
    Hope it will help you in any cases for manual update.
    Последний раз редактировалось RC3C; 13.05.2023 в 12:55.
  7. #652
    03.01.2021
    196
    18
    Hello Alexei,
    73 Pat
    Hi Pat, I've already contacted Alex about it, he's working on it and I hope everything will be ready soon.
    Greetings.
    73 de IK2XDE Andrea
    IK2XDE Andrea - WWLoc. JN45MQ
    https://www.xdenews.net/ik2xde/logonline/
    RADIO Setup (update 30/08/2025)
    ICOM IC-7600 - (HF - 50MHz.)
    SunSDR2DX - (HF - 50MHz. - 144 MHz.)
    OM Power - OM2000A+ (1.8-50 MHz. Amplifier)
    OB11-3 (11 element - 3 band - 10m-15m-20m)
    OB9-3 WARC (9 element - 3 band - 12m-17m-30m)
    SkyWire Loop (40-60-80-160 m.)
    LogHX Managers Database (update for free)
    https://www.xdenews.net/managers/
  8. #653
    03.02.2006
    20,753
    10225
    5491
    About managers - best way to find managers for Stations:
  9. #654
    Low Power
    19.11.2019
    Nyirabrany
    11
    43
    Hello Alexei,
    There is a new LogHX fan because I installed LogHX to a very good friend of mine.
    Everything works fine, just only one thing we don't know...
    How to control the PTT in VoiceHX window? [TX] [RX] commands does not do it.
    With VOX or using MOX the messages are transmitting, no problem.
    In Logger32's DVK window there was a COM port to control PTT.
    He has microHAM 2R+ and FTdx5000.
    Thank you for your help in advance!
    73 Egon / HA3MN
  10. #655
    03.02.2006
    20,753
    10225
    5491
    [TX] [RX] commands must work!
    Example of macros:
    [TX]
    [CATCMD:MD2;]
    CQ
    CQ
    [CATCMD:MD3;]
    [RX]
    Where - CQ is CQ.wav file in VoiceMacros folder.
  11. #656
    04.01.2019
    103
    38
    33
    Hello Alexei,
    73 Pat
    Hello/Privet Alexei, Pat, Andrea
    Another option is to use OK1RR's QSL Managers Database. Martin OK1RR updates this database every month. But he uses a different .txt file format than Alexei in LogHX. It is possible to modify this file as needed by LogHX. It would be better if Alexei made it possible to import a .txt file from OK1RR to LogHX. Would it be possible Alexei?
    https://ok1rr.com/downloads/qsl-managers-database/
    Vlado OM3BY
  12. #657
    Low Power
    19.11.2019
    Nyirabrany
    11
    43
    Example of macros:
    [TX]
    [CATCMD:MD2;]
    CQ
    CQ
    [CATCMD:MD3;]
    [RX]
    Hello Alexei,
    Sorry for the late answer but my friend was very QRL.
    Well, DVK is functioning perfectly! Thank you for the ideas!
    The format of the SSB solution is :
    [TX][CATCMD:TX1;]msg1[CATCMD:TX0;][RX]
    Thank you again!
  13. #658
    03.02.2006
    20,753
    10225
    5491
    I'm doing an import from a text file to manager database. But how to take into account the start date and the end date if they are not provided? After all, there may be different managers for same station at different times? How to log data from the OK1RR database when the start and end dates are not specified?
  14. #659
    Low Power
    19.11.2019
    Nyirabrany
    11
    43
    Hello Alexei,
    Is it possible to save Radio1/Radio2 setup and Rotor1/Rotor2 setup into the "Views"?
    My friend has two radios, one for HF and one for VHF but HF/VHF antennas are using the same rotor (there is only one rotor).
    I made to him two "Views" to change radios/rotor(s). One for HF and one for VHF but when he is using the "Select view" menu and select the "HF" view or the "VHF" view,
    the "Views" does not load the informations for which radio and rotor are belongs to the given "Views" because the LogHX does not save these informations.
    Are we do something wrong?
    Thank you again for your help in advance!
    73 Egon / HA3MN
    PS: There is an other friend of mine... I installed LogHX to him as well.
    He said, LogHX is much better than his old log program, you made so GOOD program!
    He loves it so much!
  15. #660
    07.07.2023
    16
    3
    3
    Request for Multicast UDP Support in LogHX
    Dear Alexei,
    I hope this email finds you well. I am writing to inquire about the availability of UDP Multicast support in LogHX and its potential inclusion in future releases.
    As an operator who frequently utilizes applications such as WSJT-X and JTDX, I have come to appreciate the convenience and functionality provided by UDP Multicasting. It enables multiple applications running on the same PC to interact with WSJT-X using a shared UDP IP Address and Port. This capability proves particularly valuable when using programs like GridTracker and JTAlert in conjunction with LogHX.
    However, upon my exploration of LogHX, I could not find any options or settings related to UDP Multicasting. Hence, I wanted to confirm if LogHX currently lacks support for this feature. If so, I kindly request you to consider implementing UDP Multicast support in future releases of LogHX. This enhancement would greatly enhance the interoperability and versatility of the LogHX application.
    For reference, the versions of the applications I am currently using are as follows:
    LogHX v3.0 build 730
    JTDX v2.2.160-rc2 HF
    WSJT-X v2.6.1 6b6d74
    To provide an example, I have outlined below the necessary configuration settings for enabling Multicast UDP in WSJT-X:
    1. Navigate to the Reporting tab in the WSJT-X Settings dialog.
    2. Under the UDP Server group of controls, set the UDP Server: address field to a valid IP address within the 224.0.0.1 through 224.0.0.255 or 239.0.0.0 through 239.255.255.255 address range. The default value of 224.0.0.1 is commonly used.
    3. Keep the default value of 2237 for the UDP Server port number: field.
    4. From the Outgoing interfaces: drop-down listbox, select the loopback_n option. You may choose to select all available interfaces.
    5. Set the Multicast TTL: field value to 1.
    6. Ensure that the checkboxes for Accept UDP requests, Notify on accepted UDP request, and Accepted UDP request restores window are selected.
    For visual reference, you can consult the following image from (https://support.hamradiodeluxe.com/s...multicasting):
    I sincerely appreciate your attention to this matter. Introducing UDP Multicast support in LogHX would greatly enhance its compatibility and utility in multi-application environments. Thank you for considering my request, and I look forward to any updates or feedback you may provide.
    73, PY5XT (Eleandro)
  1. LogHX: Актуальные релизы и история изменений.
    Ответов: 971
    Последнее сообщение: 08.01.2026, 00:04
  2. DIY UW3DI (for English OPs)
    от UU2JET в разделе КВ: UW3DI
    Последнее сообщение: 18.01.2013, 12:04
  3. KENWOOD TS-2000 (Black Version)
    от UA3IRS в разделе TS-2000
    Последнее сообщение: 16.11.2009, 20:16
  4. Navitel 2.0 Pocket PC Version
    от RX3AOE в разделе APRS
    Последнее сообщение: 26.09.2006, 03:39
  5. windows 64 bit version не ставится
    от UR4LZW в разделе Программное обеспечение
    Последнее сообщение: 12.09.2005, 23:58
