Страница 68 из 68 ПерваяПервая ... 18586162636465666768
Показано с 1,006 по 1,017 из 1017
Like Tree167Спасибо
Тема: LogHX: English version
  1. #1006
    Low Power
    16.04.2020
    89
    3
    Can someone please share the settings I need to log from VARAC into LogHX? I've tried UDP N1MM, 12061 as shown in the Set up, recieve interface is 127.0.0.1 all boxes ticked
  2. #1007
    Low Power
    02.05.2021
    6
    Hi,
    Can you tell us more explanations about your need ?
    73s Christian F8GHE
  3. #1008
    04.01.2010
    Краснодар
    134
    35
    98
    GD. Not supported...
    It would be possible to experiment, but I don’t want to install VaraAC just because of this. Perhaps the ADIF transmission format is not what LogHX wants.
Название:	Снимок экрана 2025-11-24 035554.png
  4. #1009
    03.02.2006
    20,649
    10158
    5456
    UDP N1MM
    UDP N1MM work without problems.
  5. #1010
    Low Power
    16.04.2020
    89
    3
    Thanks, I will keep trying.
    Another question on spotting.
    On 6m for example the comments have this. Is there any way to automate the population of the comment field with certain info when sending a spot?
    IO85WU<ES>JO82LX Tnx FT8 QSO
  6. #1011
    04.01.2019
    101
    38
    32
    I do it like this
Название:	telnet sprava.png
    Vlado OM3BY
  7. #1012
    Low Power
    16.04.2020
    89
    3
    Many thanks Vlado! That's exactly what I was looking for!
  8. #1013
    Low Power
    16.04.2020
    89
    3
    I updated to 782 this morning. When I click the telnet cluster spots, it no longers changes the radio to that frequency. I remember when I upgraded last time this happened and I had to revert to an older version. Any one else have this or have a solution?
  9. #1014
    03.02.2006
    20,649
    10158
    5456
    Here -
  10. #1015
    Low Power
    16.04.2020
    89
    3
    Thanks, It works in the "Spots" and "Alarms" tab but it doesnt work in the Telnet, Telnet 2, Telnet 3 tabs for me, it used to work.
  11. #1016
    Low Power
    16.04.2020
    89
    3
    Any news on this item please?
  12. #1017
    03.02.2006
    20,649
    10158
    5456
    Please, test this version -
    http://rx4hx.qrz.ru/files/loghx/test..._build_783.exe
    is now Ok?
  1. LogHX: Актуальные релизы и история изменений.
    Ответов: 971
    Последнее сообщение: 08.01.2026, 00:04
  2. DIY UW3DI (for English OPs)
    от UU2JET в разделе КВ: UW3DI
    Последнее сообщение: 18.01.2013, 12:04
  3. KENWOOD TS-2000 (Black Version)
    от UA3IRS в разделе TS-2000
    Последнее сообщение: 16.11.2009, 20:16
  4. Navitel 2.0 Pocket PC Version
    от RX3AOE в разделе APRS
    Последнее сообщение: 26.09.2006, 03:39
  5. windows 64 bit version не ставится
    от UR4LZW в разделе Программное обеспечение
    Последнее сообщение: 12.09.2005, 23:58
