Страница 67 из 68 ПерваяПервая ... 1757606162636465666768 ПоследняяПоследняя
Показано с 991 по 1,005 из 1017
Like Tree167Спасибо
Тема: LogHX: English version
  1. #991
    03.01.2021
    196
    18
    Цитата Сообщение от IK2XDE Посмотреть сообщение
    With the latest version, all fields are saved correctly, except the PRINTQUEUE field.
    The problem with this field persists; it saves a blank field, not with the "N" (qsl not needed).
    Returning to version 776 all work fine,
    so please check here the difference.
    Thanks in advance.
    73 de IK2XDE Andrea
    IK2XDE Andrea - WWLoc. JN45MQ
    https://www.xdenews.net/ik2xde/logonline/
    RADIO Setup (update 30/08/2025)
    ICOM IC-7600 - (HF - 50MHz.)
    SunSDR2DX - (HF - 50MHz. - 144 MHz.)
    OM Power - OM2000A+ (1.8-50 MHz. Amplifier)
    OB11-3 (11 element - 3 band - 10m-15m-20m)
    OB9-3 WARC (9 element - 3 band - 12m-17m-30m)
    SkyWire Loop (40-60-80-160 m.)
    LogHX Managers Database (update for free)
    https://www.xdenews.net/managers/
  2. #992
    03.02.2006
    20,678
    10181
    5461
    Hello Andrea!
    Try this test version:
    http://rx4hx.qrz.ru/files/loghx/test..._build_780.exe
    Version at 25 august.
  3. #993
    03.01.2021
    196
    18
    Hello Andrea!
    Unfortunately, even with this version the problem persists.
    It also does not save other fields from qrz.com like Name, qth, mail..ecc...
    73 de IK2XDE Andrea
  4. #994
    03.02.2006
    20,678
    10181
    5461
    Why this can happen: before saving QSO, call field in WSJT-X is cleared and fields in LogHX are cleared also.
    Do you use WSJT-X or JTDX?
  5. #995
    03.01.2021
    196
    18
    Hi, thanks for your attention.
    You probably have the solution right in front of you, but you can't see it...hey...
    Let's start with something that's certain: version 776 works correctly.
    So you need to look at what you changed afterward; the problem persists from 777 to 780.
    I use WSJT-X as always and obviously haven't changed any configurations (which I checked, however).
    When the callsign of the correspondent is in the call field of wsjt-x,
    the callsign field in the "log entry" window is filled with the same callsign.
    Loghx searches for the data on qrz.com and completes the other fields.
    Then I put "N" in the Print Queue field because I don't want a QSL (QSL NOT NEED).
    Here's where it ends: when WSJT-X saves the QSO, LogHX also saves the QSO,
    but without the pre-populated qrz.com fields and also leaves the PrintQueue field blank, where I manually entered the "N."
    Check carefully: the solution is in version 776, which works correctly.
    Thanks in advance for your efforts in finding the solution.
  6. #996
    03.02.2006
    20,678
    10181
    5461
  7. #997
    Low Power Аватар для UD8S
    24.05.2022
    Оренбург
    8
    14
    Что то не пойму что делаю не так, прошу помощи гуру, задача из журнала выбрать связи в FT8, FT4 и все это сохранить в adif. Что делал, в журнале выбрал фильтр-установить фильтр Нажмите на изображение для увеличения.
ID:	373109 , настроил дату старта и окончания, настроил мод и диапазоны, выбрал все континенты, тыкаю установить фильтр, по идее в журнале должны все связи выделится, но я не вижу выделения как при выделении клавишей пробел, где покопать??
  8. #998
    03.01.2021
    196
    18
    OK, this version saves the PrintQueue field correctly,
    but it does not save the other fields filled with data from qrz.com.
    73 de IK2XDE Andrea
  9. #999
    03.02.2006
    20,678
    10181
    5461
    It was difficult, but I did it!)))
    Now all is Ok!
  10. #1000
    03.01.2021
    196
    18
    Now all is Ok!
    OK , Now I test v 780 date 28/08/2025 - 15.50
    all fields was saved correctly......thanks....!!
    But we have another problem
    Название: Immagine 2025-08-28 181350.jpg
    Duble Error on start, v 780 28/08 15.50
Размер: 24.1 КбНазвание: Immagine 2025-08-28 184253.jpg
  11. #1001
    03.02.2006
    20,678
    10181
    5461
  12. #1002
    03.01.2021
    196
    18
    OK, now everything seems to be working fine.
    I'll continue testing in the next few days.
    Thank you very much.
  13. #1003
    03.01.2021
    196
    18
    Hello Alex,
    what about SSB Macros via TCI for our SunSDR2DX....??
    For now, I'm using RadioMacros, which comes with ESDR3, but it would be nice to see it work with LogHX.
    Will there be any future possibility of using MTTY via TCI?
    Thanks for your attention.
    73 by IK2XDE Andrea.
  14. #1004
    03.01.2021
    196
    18
    Hi,
    how do you use this new feature and what is it for?
    LogHX3.exe /V=ViewName
    start LogHX with "View" - "ViewName"
    Thanks.
    73 de IK2XDE Andrea
  15. #1005
    03.02.2006
    20,678
    10181
    5461
    Load log with "View"="ViewName".
    I haven't figured out how to do this yet.
  1. LogHX: Актуальные релизы и история изменений.
    Ответов: 971
    Последнее сообщение: 08.01.2026, 00:04
  2. DIY UW3DI (for English OPs)
    от UU2JET в разделе КВ: UW3DI
    Последнее сообщение: 18.01.2013, 12:04
  3. KENWOOD TS-2000 (Black Version)
    от UA3IRS в разделе TS-2000
    Последнее сообщение: 16.11.2009, 20:16
  4. Navitel 2.0 Pocket PC Version
    от RX3AOE в разделе APRS
    Последнее сообщение: 26.09.2006, 03:39
  5. windows 64 bit version не ставится
    от UR4LZW в разделе Программное обеспечение
    Последнее сообщение: 12.09.2005, 23:58
