Страница 63 из 68 ПерваяПервая ... 135356575859606162636465666768 ПоследняяПоследняя
Показано с 931 по 945 из 1017
Like Tree167Спасибо
Тема: LogHX: English version
  1. #931
    26.10.2019
    46
    17
    9
    Thanks for your attention and support, 73 from py5ej.[/QUOTE]
    Цитата Сообщение от Alde Посмотреть сообщение
    Alexei, thanks for your attention and suggestion.
    Unfortunately, the problem persists. In the old versions, it was possible to sort the QSLR(S)_Date columns without any problems.
    However, in recent versions including the recommended 770, when I try to sort it is no longer possible.
    I'm in a loop, removing the date 30-12-1899 leaves the field empty, with the field empty it is NOT possible to sort the column, if I repair the logHX as suggested the date 30-12-1899 reappears.
    How can I remove the unwanted date from the logHX, and then sort the columns mentioned?
  2. #932
    26.07.2023
    41
    4
    Hi Alexei,
    Just a heads up that Windows Defender flagged a threat after I installed build 771 this evening, clearly it's a false positive - details in the screengrab image below in case it's of any help:
Название:	Screenshot 2024-12-06 215415.png
    I am also getting the error below when I click on a DX spot - everything happens normally as it should but I also get this pop up box:
Название:	Screenshot 2024-12-06 220055.png
    I clear the box down and all is fine.
  3. #933
    03.02.2006
    20,753
    10225
    5491
    Цитата Сообщение от Jim Smith Посмотреть сообщение
    image below
    Yes, CreateBauckup.exe create zip-archive, and it's look like virus.
    Fixed -
    http://rx4hx.qrz.ru/files/loghx/test..._build_772.exe
  4. #934
    03.01.2021
    196
    18
    Hello Alexey,
    with new buid 774 - 08/01/2025
    whean I use OFFLINE MANAGERS DATABASE
    function LOAD from *.TXT file
    I receive this error:
    Название: Immagine 2025-01-08 190706.jpg
    Название: Immagine 2025-01-08 190741.jpg
    LogHX run as administrator.
    Hope you will find this bug.
    Thanks.
    73 de IK2XDE Andrea.
    IK2XDE Andrea - WWLoc. JN45MQ
    https://www.xdenews.net/ik2xde/logonline/
    RADIO Setup (update 30/08/2025)
    ICOM IC-7600 - (HF - 50MHz.)
    SunSDR2DX - (HF - 50MHz. - 144 MHz.)
    OM Power - OM2000A+ (1.8-50 MHz. Amplifier)
    OB11-3 (11 element - 3 band - 10m-15m-20m)
    OB9-3 WARC (9 element - 3 band - 12m-17m-30m)
    SkyWire Loop (40-60-80-160 m.)
    LogHX Managers Database (update for free)
    https://www.xdenews.net/managers/
  5. #935
    03.02.2006
    20,753
    10225
    5491
    Hello Andrea!
    Please, write here 2-5 lines from this TXT-file.
  6. #936
    03.01.2021
    196
    18
    here some example.
    3A/IZ8EGM,IZ8EGM,01-01-2015,31-12-2015
    3A/MM0NDX,EB7DX,01-01-2021,31-12-2024,WEB OQRS - https://www.eb7dx.com - ONLY DIRECT - NO BUREAU
    3A/MM0SAJ,EB7DX,16-01-2024,31-12-2024
    3A/N0FW/P,W8QID,01-01-2005,31-12-2005
    3A/N9NS/P,W8QID,01-01-2005,31-12-2005
    3A/OJ0Y,EB7DX,01-01-2019,31-12-2019,WEB OQRS - https://www.eb7dx.com - ONLY DIRECT - NO BUREAU
    3A/OK1CZ,OK1CZ,01-01-2000,31-12-2000
    3A/ON4LUC/P,ON6DP,01-01-2007,31-12-2007
    3A/ON5NT/P,ON5NT,01-01-2007,31-12-2007
    3A/ON5UR,M0URX,01-01-2012,31-12-2014,WEB OQRS - https://www.m0urx.com
    3A/ON8AK,M0URX,01-01-2012,31-12-2012,WEB OQRS - https://www.m0urx.com
    3A/PB8DX,OQRS,01-01-2022,31-12-2022,CLUBLOG OQRS - LOTW
    3A/RA9USU,UA3DX,01-01-2021,31-12-2021
    3A/SP2FAX/P,SP2PI,01-01-2005,31-12-2005
    3A/SP2JMB/P,SP2PI,01-01-2005,31-12-2005
    This file never change
    File CREATE with "SAVE TO TXT FILE"
    73 de IK2XDE Andrea
  7. #937
    03.02.2006
    20,753
    10225
    5491
    here some example.
    Fixed -
    http://rx4hx.qrz.ru/files/loghx/LogH..._build_774.exe
  8. #938
    03.01.2021
    196
    18
    Hello Alexey,
    now all work fine.
    Thanks.
  9. #939
    21.07.2022
    80
    20
    Telnet problem
    Last version:
    Wrong CONNECT_SERVER!
    on any server. What is new, where is a problem?
    73 Josef OK2WO
  10. #940
    21.07.2022
    80
    20
    Solved - all my data, including the callsign, disappeared from the setup, I don't know why, after upgrade...
    73 Josef OK2WO
  11. #941
    03.02.2006
    20,753
    10225
    5491
    All setup data saved in <LogHX>\INI folder. You can restore all data from backup.
  12. #942
    26.07.2023
    41
    4
    Ignore my previous, I solved it.
    Изображения Изображения
  13. #943
    26.07.2023
    41
    4
    It looks like recent Windows Defender updates is generating false positives for trojan viruses in LogHX files.
    This morning, Spottercollector.exe was eaten by Defender.
    I updated LogHX to 776 and this time Defender ate LogHX.exe as well as SpotterCollector.
    I have put an exception on the LogHX folder, reinstalled and all is ok now.
  14. #944
    03.02.2006
    20,753
    10225
    5491
    Yes, last update of Windows Defender find trojan in SpotMachineServer.exe (not Spottercollector.exe!).
    This is a problem of Windows Defender. Log is not trojan)))
  15. #945
    26.07.2023
    41
    4
    Haha, yes thats hat I meant. Not enough coffee consumed at that point.
    On another note - I was using 775, but I had to roll back to an earlier build becasue Telnet kept disconnecting and was not re-connecting automatically. I find it strange that it should disconnect at all, as it's a localhost / 127.0.0.1 connection to VE7CC cluster client running on the same machine.....
    The disconnection happens due to "Timeout get gata from server [127.0.0.1]" ( assume gata = data ). Another program I use doesn't get these disconnections, so I wonder how long a timeout has to be before LogHX assumes a timeout and disconnects.
    Anyway, I rolled back to 771 (the last I'd downloaded) and all is well again, the disconnects still happen but HX connects again straight away.
  1. LogHX: Актуальные релизы и история изменений.
    Ответов: 971
    Последнее сообщение: 08.01.2026, 00:04
  2. DIY UW3DI (for English OPs)
    от UU2JET в разделе КВ: UW3DI
    Последнее сообщение: 18.01.2013, 12:04
  3. KENWOOD TS-2000 (Black Version)
    от UA3IRS в разделе TS-2000
    Последнее сообщение: 16.11.2009, 20:16
  4. Navitel 2.0 Pocket PC Version
    от RX3AOE в разделе APRS
    Последнее сообщение: 26.09.2006, 03:39
  5. windows 64 bit version не ставится
    от UR4LZW в разделе Программное обеспечение
    Последнее сообщение: 12.09.2005, 23:58
