Страница 66 из 68 ПерваяПервая ... 165659606162636465666768 ПоследняяПоследняя
Показано с 976 по 990 из 1017
Like Tree167Спасибо
Тема: LogHX: English version
  1. #976
    21.07.2022
    80
    20
    AutoCQ works with FT991, not with FT991 DATA... 73 OK2WO
  2. #977
    Low Power
    16.04.2020
    89
    3
    Does anyone use their rotator at all with this software? I cannot get mine to goto a heading when the callsign is entered. It just goes to North no matter the contact.
  3. #978
    QRPP
    20.01.2024
    7
    I try again to download and install the 778 version. No virus inside: everything is working. No more error in the tcp tansmission.
    @M0CGF I'm using PstRotator and it works!
  4. #979
    Low Power
    16.04.2020
    89
    3
    Can you share PSTROTATOR settings please.
    I found my calibration was wrong, recalibrated and it worked but I want the USB COM connection to PSTrotator then I need a connection via TCP,IP,UDP or which ever works to LogHX. Right now I can work either programme standalone but not both, I like to see the direction of the antenna in pst.
  5. #980
  6. #981
    Low Power
    02.05.2021
    6
    Thumbs up
    Цитата Сообщение от S50U Посмотреть сообщение
    Alex hi
    Maybe it would be interesting for users of your programme to improve the reception of telnet DXCluster spots for interested group of users of POTA and SOTA programme. On the S50CLX DXCluster I have implemented the integration of spots that are not part of the classical telnet DXCluster network. More in my note below. The user of your programme would thus have the possibility to select in the programme the reception of specific spots via a button, with predefined commands to be sent to the S50CLX DXCluster after a successful connection. Sorting, searching by reference ... etc is a matter of implementing of LogHX. The idea for the button is:
    1. POTA ONLY spots -> command executed: ACC/SPOTS INFO -POTA-
    2. SOTA ONLY spots -> command executed: ACC/SPOTS INFO -SOTA-
    3. BOTH POTA&SOTA spots -> command executed: ACC/SPOTS INFO -POTA- OR INFO -SOTA-
    4. S50CLX CLUSTER DEFAULT (all spots) -> command executed: CLEAR/SPOTS ALL
    A connection via telnet protocol to S50CLX s50clx.infrax.si:41112 which is a completely free service is required to receive POTA/SOTA spots.
    Good luck, Dan S50U
    POTA and SOTA enthusiasts!
    POTA (Parks On The Air) and SOTA (Summits On The Air) are internationally renowned programmes. They encourage licensed radio amateurs to operate outdoors in nature parks or on mountain peaks. Operators making contacts in parks or on summits are called activators, and the other operators who contact them are hunters.
    On the S50CLX telnet DXCluster I implemented the collection of spots from POTA and SOTA that are not part of the classical telnet DXCluster network (potaapp and sotawatch). Such spots are tagged with [-POTA-] and [-SOTA-] respectively. In the comment field a spot tagged as such carries:
    POTA:
    - International POTA reference number, example: SI-0831
    - Mode of operation, example: CW
    - POTA reference name, example: Preval Vrh Ravni
    SOTA:
    - International SOTA peak reference number; example: S5/CP-002
    - Mode of operation; example: SSB
    - SOTA summit name, altitude, points; example: Porezen, 1630m, 8 points
    With the right settings, the exact DX spots you want can be received and this is achieved using the filters below. To change an existing filter, simply overwrite it with a new command. Each command (BOLD formatted text) must be entered on a new line, confirm the entry by pressing ENTER.
    - for receiving only POTA spots, command: ACC/SPOTS INFO -POTA-
    - for receive only SOTA spots, command: ACC/SPOTS INFO -SOTA-
    - for receiving POTA and SOTA spots, command: ACC/SPOTS INFO -POTA- OR INFO -SOTA-
    The CLEAR/SPOTS ALL command removes all set filters and the S50CLX passes us all SOTA, POTA, DXCluster and optionally RBN (SET/SKIMMER <mode>) spots.
    In cases where you do not want to receive POTA and SOTA spots e.g. in a contests, use the command as the first filter before all others REJ/SPOTS 1 INFO -POTA- OR INFO -SOTA-
    Spot forwarding is based on the DXSpider DXCluster software validation and normalisation algorithm, rejecting duplicates spots and ensuring quality spots in the face of increasingly frequent malicious attacks on global amateur radio DXCluster network.
    The S50CLX DXCluster can be reached via telnet at: s50clx.infrax.si port 41112
    My small contribution to the promotion of outdoor activities in POTA and SOTA hamradio programmes. :-)
    Spread the news, thanks
    73 Danilo S50U sys S50CLX DXCluster
    p.s. The information is also published on the Radioklub Cerkno S50E website https://s50e.si/pota-sota-dxcluster/
    Hi, this is a very good idea !
    I hope that Alex could work on it.
    73s Christian F8GHE
  7. #982
    03.01.2021
    196
    18
    PrintQueue "N" (QSL not need) (version 779)
    By default, I use "N" in the PrintQueue field.
    With version 779 of 05/08/2025, if I manually save a QSO, everything works correctly.
    However, if I connect WSJT-X and the QSO in FT8 is automatically saved, the PrintQueue field is not saved
    and the field in the log, remains empty.
Название:	Immagine 2025-08-06 135506.jpg
    73 de IK2XDE Andrea.
    ik2xde@gmail.com
    IK2XDE Andrea - WWLoc. JN45MQ
    https://www.xdenews.net/ik2xde/logonline/
    RADIO Setup (update 30/08/2025)
    ICOM IC-7600 - (HF - 50MHz.)
    SunSDR2DX - (HF - 50MHz. - 144 MHz.)
    OM Power - OM2000A+ (1.8-50 MHz. Amplifier)
    OB11-3 (11 element - 3 band - 10m-15m-20m)
    OB9-3 WARC (9 element - 3 band - 12m-17m-30m)
    SkyWire Loop (40-60-80-160 m.)
    LogHX Managers Database (update for free)
    https://www.xdenews.net/managers/
  8. #983
    03.01.2021
    196
    18
    ik2xde@gmail.com
    This problem is present in versions 777-778-779, in the old version 776 everything works correctly.
    When I close the log and exit permanently, version 779 doesn't seem to close SpotMachineServer.exe and CWServerHX.exe properly.
    I have to close them manually from Task Manager.
  9. #984
    03.02.2006
    20,752
    10225
    5491
    Do yuo use 779 release? I've just checked that this field is saved correctly.
  10. #985
    03.01.2021
    196
    18
    I try with v 779 dated 05-08-2025 (not today release)
    Problem also with 777-778
    Now I use version 776 without problem.
    With version 779 dated 05-08-2025
    Thanks.
  11. #986
    03.01.2021
    196
    18
    Now I try
    v 779 dated 14/08
    v 780 dated 19/08 (test version)
    problem persist.
    When WSJT-X save qso , LOGHX save qso with PRINTQUEUE field "EMPTY"
    Not save "N" that I put in the "QSO ENTRY" windows.
    All ok with version 776
    Thanks in advance.
  12. #987
    03.02.2006
    20,752
    10225
    5491
    Yes Andrea! Today I found problem! Pse QRX! I will fix the problem as soon as possible.
    Fixed, please try:
    http://rx4hx.qrz.ru/files/loghx/test..._build_780.exe
  13. #988
    03.01.2021
    196
    18
    Fixed, please try:
    Unfortunately, even with this version the problem persists.
    It also does not save other fields from qrz.com lije Name, qth, mail..ecc...
    73 de IK2XDE Andrea
    It also does not save other fields from qrz.com like Name, qth, mail..ecc...
    In practice, it doesn't take into account what's displayed in the QSO entry window,
    it doesn't save data from QRZ Name, locator, QTH, mail, etc., and it doesn't save the PrintQueue field.
    It only saves data from wsjt-x
    Последний раз редактировалось IK2XDE; 21.08.2025 в 13:19.
  14. #989
    03.02.2006
    20,752
    10225
    5491
    Here
    https://forum.qrz.ru/355-loghx-appar...ml#post2107085
    is same problem as you problem. And today's 780 version has solved it.
  15. #990
    03.01.2021
    196
    18
    Here
    With the latest version, all fields are saved correctly, except the PRINTQUEUE field.
    The problem with this field persists; it saves a blank field, not with the "N" (qsl not needed).
  1. LogHX: Актуальные релизы и история изменений.
    Ответов: 971
    Последнее сообщение: 08.01.2026, 00:04
  2. DIY UW3DI (for English OPs)
    от UU2JET в разделе КВ: UW3DI
    Последнее сообщение: 18.01.2013, 12:04
  3. KENWOOD TS-2000 (Black Version)
    от UA3IRS в разделе TS-2000
    Последнее сообщение: 16.11.2009, 20:16
  4. Navitel 2.0 Pocket PC Version
    от RX3AOE в разделе APRS
    Последнее сообщение: 26.09.2006, 03:39
  5. windows 64 bit version не ставится
    от UR4LZW в разделе Программное обеспечение
    Последнее сообщение: 12.09.2005, 23:58
