AutoCQ works with FT991, not with FT991 DATA... 73 OK2WO
Does anyone use their rotator at all with this software? I cannot get mine to goto a heading when the callsign is entered. It just goes to North no matter the contact.
I try again to download and install the 778 version. No virus inside: everything is working. No more error in the tcp tansmission.
@M0CGF I'm using PstRotator and it works!
Can you share PSTROTATOR settings please.
I found my calibration was wrong, recalibrated and it worked but I want the USB COM connection to PSTrotator then I need a connection via TCP,IP,UDP or which ever works to LogHX. Right now I can work either programme standalone but not both, I like to see the direction of the antenna in pst.
Ah I got it working now!!
By default, I use "N" in the PrintQueue field.
With version 779 of 05/08/2025, if I manually save a QSO, everything works correctly.
However, if I connect WSJT-X and the QSO in FT8 is automatically saved, the PrintQueue field is not saved
and the field in the log, remains empty.
Вложение 372608
73 de IK2XDE Andrea.
ik2xde@gmail.com
This problem is present in versions 777-778-779, in the old version 776 everything works correctly.
When I close the log and exit permanently, version 779 doesn't seem to close SpotMachineServer.exe and CWServerHX.exe properly.
I have to close them manually from Task Manager.
I try with v 779 dated 05-08-2025 (not today release)
Problem also with 777-778
Now I use version 776 without problem.
With version 779 dated 05-08-2025
Thanks.
Now I try
v 779 dated 14/08
v 780 dated 19/08 (test version)
problem persist.
When WSJT-X save qso , LOGHX save qso with PRINTQUEUE field "EMPTY"
Not save "N" that I put in the "QSO ENTRY" windows.
All ok with version 776
Thanks in advance.
Yes Andrea! Today I found problem! Pse QRX! I will fix the problem as soon as possible.
Fixed, please try:
http://rx4hx.qrz.ru/files/loghx/test..._build_780.exe
Unfortunately, even with this version the problem persists.
It also does not save other fields from qrz.com lije Name, qth, mail..ecc...
73 de IK2XDE Andrea
In practice, it doesn't take into account what's displayed in the QSO entry window,
it doesn't save data from QRZ Name, locator, QTH, mail, etc., and it doesn't save the PrintQueue field.
It only saves data from wsjt-x
Here
https://forum.qrz.ru/355-loghx-appar...ml#post2107085
is same problem as you problem. And today's 780 version has solved it.
