Please read old problem, solved (message #817)
Now If I downgrade to v763 all work fine
If I upgrade to v767 CAT do NOT work
So I think there is some changes .
Thanks.
73 de IK2XDE Andrea
... but here is problem with Yaesu TRX....
Well, try this version:
http://rx4hx.qrz.ru/files/loghx/test..._build_767.exe
Need printscreen this two windows from version 763, where all work well -
Вложение 360176
for IC-7600.
I found problem - try again:
Another version for testing:
With the latest version 767 (the one from today 06/09)
Everything works correctly.
However, I discovered that the changes were made between 759 and 761
(I have never tried 760) and since then all the subsequent ones do not work.
However, I confirm that the V 767 from today 06/09/2024 works correctly with my IC-7600,
correctly manages the split frequency, both vfa and vfob, correctly records the qso in log rxfreq and txfreq,
on the band map the red and blue arrows are correctly displayed.
In the qso entry window, the call of the station positioned on VfoaA (RxFreq) is correctly displayed.
Thank you.
73 de IK2XDE Andrea
