Thanks for your attention and support, 73 from py5ej.[/QUOTE]
Hi Alexei,
Just a heads up that Windows Defender flagged a threat after I installed build 771 this evening, clearly it's a false positive - details in the screengrab image below in case it's of any help:
Вложение 363258
I am also getting the error below when I click on a DX spot - everything happens normally as it should but I also get this pop up box:
Вложение 363261
I clear the box down and all is fine.
Yes, CreateBauckup.exe create zip-archive, and it's look like virus.
Fixed -
http://rx4hx.qrz.ru/files/loghx/test..._build_772.exe
Hello Alexey,
with new buid 774 - 08/01/2025
whean I use OFFLINE MANAGERS DATABASE
function LOAD from *.TXT file
I receive this error:
Вложение 364405
Вложение 364406
LogHX run as administrator.
Hope you will find this bug.
Thanks.
73 de IK2XDE Andrea.
here some example.
3A/IZ8EGM,IZ8EGM,01-01-2015,31-12-2015
3A/MM0NDX,EB7DX,01-01-2021,31-12-2024,WEB OQRS - https://www.eb7dx.com - ONLY DIRECT - NO BUREAU
3A/MM0SAJ,EB7DX,16-01-2024,31-12-2024
3A/N0FW/P,W8QID,01-01-2005,31-12-2005
3A/N9NS/P,W8QID,01-01-2005,31-12-2005
3A/OJ0Y,EB7DX,01-01-2019,31-12-2019,WEB OQRS - https://www.eb7dx.com - ONLY DIRECT - NO BUREAU
3A/OK1CZ,OK1CZ,01-01-2000,31-12-2000
3A/ON4LUC/P,ON6DP,01-01-2007,31-12-2007
3A/ON5NT/P,ON5NT,01-01-2007,31-12-2007
3A/ON5UR,M0URX,01-01-2012,31-12-2014,WEB OQRS - https://www.m0urx.com
3A/ON8AK,M0URX,01-01-2012,31-12-2012,WEB OQRS - https://www.m0urx.com
3A/PB8DX,OQRS,01-01-2022,31-12-2022,CLUBLOG OQRS - LOTW
3A/RA9USU,UA3DX,01-01-2021,31-12-2021
3A/SP2FAX/P,SP2PI,01-01-2005,31-12-2005
3A/SP2JMB/P,SP2PI,01-01-2005,31-12-2005
This file never change
File CREATE with "SAVE TO TXT FILE"
73 de IK2XDE Andrea
Hello Alexey,
now all work fine.
Thanks.
Last version:
Wrong CONNECT_SERVER!
on any server. What is new, where is a problem?
73 Josef OK2WO
Solved - all my data, including the callsign, disappeared from the setup, I don't know why, after upgrade...
73 Josef OK2WO
Ignore my previous, I solved it.
It looks like recent Windows Defender updates is generating false positives for trojan viruses in LogHX files.
This morning, Spottercollector.exe was eaten by Defender.
I updated LogHX to 776 and this time Defender ate LogHX.exe as well as SpotterCollector.
I have put an exception on the LogHX folder, reinstalled and all is ok now.
Haha, yes thats hat I meant. Not enough coffee consumed at that point.
On another note - I was using 775, but I had to roll back to an earlier build becasue Telnet kept disconnecting and was not re-connecting automatically. I find it strange that it should disconnect at all, as it's a localhost / 127.0.0.1 connection to VE7CC cluster client running on the same machine.....
The disconnection happens due to "Timeout get gata from server [127.0.0.1]" ( assume gata = data ). Another program I use doesn't get these disconnections, so I wonder how long a timeout has to be before LogHX assumes a timeout and disconnects.
Anyway, I rolled back to 771 (the last I'd downloaded) and all is well again, the disconnects still happen but HX connects again straight away.
