29.11.2024, 15:53 #931QRP
- 26.10.2019
- 46
- 17
- 9
07.12.2024, 01:03 #932QRP
- 26.07.2023
- 41
- 4
Hi Alexei,
Just a heads up that Windows Defender flagged a threat after I installed build 771 this evening, clearly it's a false positive - details in the screengrab image below in case it's of any help:
I am also getting the error below when I click on a DX spot - everything happens normally as it should but I also get this pop up box:
I clear the box down and all is fine.
07.12.2024, 09:58 #933Координатор темы
- 03.02.2006
- 53
- 20,568
- 10123
- 5443
Yes, CreateBauckup.exe create zip-archive, and it's look like virus.
Fixed -
http://rx4hx.qrz.ru/files/loghx/test..._build_772.exe73 de RX4HX, Alexei, http://rx4hx.qrz.ru
Ant.: UW4HW, Pwr.: ~500 Wtts
08.01.2025, 21:13 #934Standart Power
- 03.01.2021
- 196
- 18
Hello Alexey,
with new buid 774 - 08/01/2025
whean I use OFFLINE MANAGERS DATABASE
function LOAD from *.TXT file
I receive this error:
LogHX run as administrator.
Hope you will find this bug.
Thanks.
73 de IK2XDE Andrea.IK2XDE Andrea - WWLoc. JN45MQ
https://www.xdenews.net/ik2xde/logonline/
RADIO Setup (update 30/08/2025)
ICOM IC-7600 - (HF - 50MHz.)
SunSDR2DX - (HF - 50MHz. - 144 MHz.)
OM Power - OM2000A+ (1.8-50 MHz. Amplifier)
OB11-3 (11 element - 3 band - 10m-15m-20m)
OB9-3 WARC (9 element - 3 band - 12m-17m-30m)
SkyWire Loop (40-60-80-160 m.)
LogHX Managers Database (update for free)
https://www.xdenews.net/managers/
08.01.2025, 22:45 #935Координатор темы
- 03.02.2006
- 53
- 20,568
- 10123
- 5443
08.01.2025, 22:59 #936Standart Power
- 03.01.2021
- 196
- 18
here some example.
3A/IZ8EGM,IZ8EGM,01-01-2015,31-12-2015
3A/MM0NDX,EB7DX,01-01-2021,31-12-2024,WEB OQRS - https://www.eb7dx.com - ONLY DIRECT - NO BUREAU
3A/MM0SAJ,EB7DX,16-01-2024,31-12-2024
3A/N0FW/P,W8QID,01-01-2005,31-12-2005
3A/N9NS/P,W8QID,01-01-2005,31-12-2005
3A/OJ0Y,EB7DX,01-01-2019,31-12-2019,WEB OQRS - https://www.eb7dx.com - ONLY DIRECT - NO BUREAU
3A/OK1CZ,OK1CZ,01-01-2000,31-12-2000
3A/ON4LUC/P,ON6DP,01-01-2007,31-12-2007
3A/ON5NT/P,ON5NT,01-01-2007,31-12-2007
3A/ON5UR,M0URX,01-01-2012,31-12-2014,WEB OQRS - https://www.m0urx.com
3A/ON8AK,M0URX,01-01-2012,31-12-2012,WEB OQRS - https://www.m0urx.com
3A/PB8DX,OQRS,01-01-2022,31-12-2022,CLUBLOG OQRS - LOTW
3A/RA9USU,UA3DX,01-01-2021,31-12-2021
3A/SP2FAX/P,SP2PI,01-01-2005,31-12-2005
3A/SP2JMB/P,SP2PI,01-01-2005,31-12-2005
This file never change
File CREATE with "SAVE TO TXT FILE"
73 de IK2XDE AndreaIK2XDE Andrea - WWLoc. JN45MQ
09.01.2025, 15:40 #937Координатор темы
- 03.02.2006
- 53
- 20,568
- 10123
- 5443
09.01.2025, 20:36 #938Standart Power
- 03.01.2021
- 196
- 18
Hello Alexey,
now all work fine.
Thanks.IK2XDE Andrea - WWLoc. JN45MQ
13.01.2025, 22:34 #939QRP
- 21.07.2022
- 80
- 20
Telnet problem
Last version:
Wrong CONNECT_SERVER!
on any server. What is new, where is a problem?
73 Josef OK2WO
14.01.2025, 00:34 #940QRP
- 21.07.2022
- 80
- 20
Solved - all my data, including the callsign, disappeared from the setup, I don't know why, after upgrade...
73 Josef OK2WO
14.01.2025, 09:22 #941Координатор темы
- 03.02.2006
- 53
- 20,568
- 10123
- 5443
16.01.2025, 13:06 #942QRP
- 26.07.2023
- 41
- 4
Ignore my previous, I solved it.Последний раз редактировалось Jim Smith; 16.01.2025 в 12:56. Причина: solved
27.01.2025, 16:06 #943QRP
- 26.07.2023
- 41
- 4
It looks like recent Windows Defender updates is generating false positives for trojan viruses in LogHX files.
This morning, Spottercollector.exe was eaten by Defender.
I updated LogHX to 776 and this time Defender ate LogHX.exe as well as SpotterCollector.
I have put an exception on the LogHX folder, reinstalled and all is ok now.
28.01.2025, 22:21 #944Координатор темы
- 03.02.2006
- 53
- 20,568
- 10123
- 5443
28.01.2025, 23:51 #945QRP
- 26.07.2023
- 41
- 4
Haha, yes thats hat I meant. Not enough coffee consumed at that point.
On another note - I was using 775, but I had to roll back to an earlier build becasue Telnet kept disconnecting and was not re-connecting automatically. I find it strange that it should disconnect at all, as it's a localhost / 127.0.0.1 connection to VE7CC cluster client running on the same machine.....
The disconnection happens due to "Timeout get gata from server [127.0.0.1]" ( assume gata = data ). Another program I use doesn't get these disconnections, so I wonder how long a timeout has to be before LogHX assumes a timeout and disconnects.
Anyway, I rolled back to 771 (the last I'd downloaded) and all is well again, the disconnects still happen but HX connects again straight away.
167Спасибо
