Страница 62 из 68 ПерваяПервая ... 12525556575859606162636465666768 ПоследняяПоследняя
Показано с 916 по 930 из 1017
Like Tree167Спасибо
Тема: LogHX: English version
  1. #916
    03.02.2006
    20,753
    10225
    5491
    Цитата Сообщение от M0CGF Посмотреть сообщение
    Show status for only this month
    Right mouse click - menu - "Select time period"
    Same in previous QSO window.
  2. #917
    Low Power
    16.04.2020
    89
    3
    I can do that but can you have 2 windows? one showing this month and one showing all time - both showing at the same time??
  3. #918
    03.02.2006
    20,753
    10225
    5491
    Now - not. Only one window. But I need to think about it. Maybe is good idea - to make a separate window for each statistic.
  4. #919
    26.07.2023
    41
    4
    Hi Alexei,
    Couple of things now I've fixed my login problems on here.
    I posted in the past about the fonts in the Awards window doubling in size after restarting the program, when using a theme or skin for the main program.
    i have found that it actually happens if the Awards window is actually closed and re-opened, and not just when the program is closed down and restarted.
    I was also thinking as a suggestion, that the configuration of the Awards window could be loaded/saved in a similar manner to that of the Band Review windows.
    Finally (for now!) I am finding the sound output selection on the DX spots alarm (Setup.. General Setup.. Color setup for Country Status) is changed if another sound device is connected or reconnected. For example, I plug in a Midi device I use to control my SDR software, and LogHX changes the output device to the Midi device I just plugged in (undesired behaviour)
    Any way of making the selected sound output device "stick" ?
  5. #920
    03.02.2006
    20,753
    10225
    5491
    I will look for a problem here.
    Not. In Windows programs selects sound card by number. When attaching a new sound card, number of old card may change.
  6. #921
    26.07.2023
    41
    4
    Thanks .
    Understood, thanks.
    Thats a pain. Wish Microsoft would fix that. It's the same with displays when turning off the TV monitor and on again. It moves windows and sound cards around.
  7. #922
    Low Power
    16.04.2020
    89
    3
    Any idea what httpgeterror - error code 87, error message : The parameter is incorrect. its from the spotmachineserver.exe
  8. #923
    03.02.2006
    20,753
    10225
    5491
    Log version?
  9. #924
  10. #925
    03.02.2006
    20,753
    10225
    5491
    768
    Try this test version -
    http://rx4hx.qrz.ru/files/loghx/test..._build_770.exe
  11. #926
    Low Power
    16.04.2020
    89
    3
    sorry been away with work, says 404 error on the download
  12. #927
    03.02.2006
    20,753
    10225
    5491
    Now download last release 770 -
    http://rx4hx.qrz.ru/files/loghx/LogH..._build_770.exe
  13. #928
    QRPP
    21.11.2024
    Problem when loading new logHX3 version.
    Hello all,
    today morning my friend CT1EHK Carlos did upgrade of logHX3 to 770 version.
    He is facing the following situation:
Название:	WhatsApp Image 2024-11-28 at 13.49.05.jpeg
    He is able to run logHX3 when he chooses OK but he is afraid that something is not going well, Alex can you check what's wrong here ?
    Best 73 all.
    CT1DRB/OK8RB
    David Quental
  14. #929
    26.10.2019
    46
    17
    9
    Help sorting the QSLR(S)_Date columns
    Hello Dear Alexei.
    I need help sorting the QSLR(S)_Date columns after removing (30-12-1899).
    Thanks in advance for any guidance, 73 from py5ej.
  15. #930
    03.02.2006
    20,753
    10225
    5491
    Load new 770 release. This problem fixed here.
  1. LogHX: Актуальные релизы и история изменений.
    Ответов: 971
    Последнее сообщение: 08.01.2026, 00:04
  2. DIY UW3DI (for English OPs)
    от UU2JET в разделе КВ: UW3DI
    Последнее сообщение: 18.01.2013, 12:04
  3. KENWOOD TS-2000 (Black Version)
    от UA3IRS в разделе TS-2000
    Последнее сообщение: 16.11.2009, 20:16
  4. Navitel 2.0 Pocket PC Version
    от RX3AOE в разделе APRS
    Последнее сообщение: 26.09.2006, 03:39
  5. windows 64 bit version не ставится
    от UR4LZW в разделе Программное обеспечение
    Последнее сообщение: 12.09.2005, 23:58
