26.03.2024, 23:08 #811Координатор темы
- 03.02.2006
- 53
- 20,753
- 10225
- 5491
Ant.: UW4HW, Pwr.: ~500 Wtts
27.03.2024, 21:41 #812Standart Power
- 03.01.2021
- 196
- 18
OK we will wait....for now we will use "RadioMacros" from ExpertSDR
OK, here you can find my two videos
First video with SunSDR2DX via TCI al work fine, split operation and frequency correct in the log.
https://www.xdenews.net/managers/files/1.mp4
Second video with ICOM IC-7600 + CatHX Interface (WRONG FREQUENCY in split operation)
https://www.xdenews.net/managers/files/2.mp4
I hope this video help you for understand the problem.
73 de IK2XDE AndreaIK2XDE Andrea - WWLoc. JN45MQ
https://www.xdenews.net/ik2xde/logonline/
RADIO Setup (update 30/08/2025)
ICOM IC-7600 - (HF - 50MHz.)
SunSDR2DX - (HF - 50MHz. - 144 MHz.)
OM Power - OM2000A+ (1.8-50 MHz. Amplifier)
OB11-3 (11 element - 3 band - 10m-15m-20m)
OB9-3 WARC (9 element - 3 band - 12m-17m-30m)
SkyWire Loop (40-60-80-160 m.)
LogHX Managers Database (update for free)
27.03.2024, 23:47 #813Координатор темы
- 03.02.2006
- 53
- 20,753
- 10225
- 5491
28.03.2024, 01:03 #814Standart Power
- 03.01.2021
- 196
- 18
28.03.2024, 22:18 #815Координатор темы
- 03.02.2006
- 53
- 20,753
- 10225
- 5491
28.03.2024, 22:34 #816Standart Power
- 03.01.2021
- 196
- 18
No....IC-7600v2.ini NOT work correct.
Yes, I just delete INIT1, this is old problem.
No I investigate....try also IC7600 and IC7600-DATA,
but all the tree file have the same problem.
I will make some modify, but I don not understand about CAT command in the INI file.
Anyway correct file was IC-7600v2 because I have v2 firmware in the radio.
29.03.2024, 03:00 #817Standart Power
- 03.01.2021
- 196
- 18
Well, I find a solution.
after some test and mods on the original file ini, I have solved the problem deleting
[STATUS 10] from the file.
; - Removed pmVfoA and pmVfoB when both pmFreqA and pmFreqB are available.
;[STATUS10]
;Command=FEFE7AE0.07D2.FD
;ReplyLength=15
;Validate=FEFE7AE007D2FD.FEFEE07A.07D2.00.FD
;Flag1=00000000000000.00000000.0000.01.00|pmVfoB
;Flag2=00000000000000.00000000.0000.0F.00|00000000000000.00000000.0000 .00.00|pmVfoA
Now all work correct, ISO qso and SPLIT qso will be stored in the log,
with the correct RX Freq. and also correct TX Freq.
This is my personal file.
http://www.xdenews.net/managers/files/IC-7600v2-XDE.ini
If anyone else owns an IC-7600 please test it, and report any malfunctions to me.
For me everything seems to be working fine now.
29.03.2024, 13:43 #818QRP
- 26.07.2023
- 41
- 4
Changing radio
Hi Alexei,
How easy would it be to place a button on the log input screen to change radio from Radio 1 to radio 2? Perhaps a Button that says R1 or R2 that can be toggled?
It would be much quicker and easier to change radios on the fly with a simple click instead of having to go into the menu to do it.
Thanks.
29.03.2024, 17:45 #819Standart Power
- 03.01.2021
- 196
- 18
Hi Jim, to do this I found it convenient to use a HotKey (IdKeys900 - Change Active Radio),
but it would actually be useful to have a button, and perhaps also add the change of the relevant BandMap
Then Switch between Radio 1 and Radio 2 and Switch between BandMap1 and BandMap2.
We hope that Alexey finds this request useful and easy to apply.
73 of IK2XDE AndreaIK2XDE Andrea - WWLoc. JN45MQ
29.03.2024, 18:26 #820QRP
- 26.07.2023
- 41
- 4
Thank you Andrea, I will look into that. Need to work out how I make that work.
Do I literally put "IdKeys900" in the window next to the hotkey that I want to use?
- - - Updated - - -
it's OK, I've sussed it now! Better than navigating to a button to be honest, now using Numpad and .
29.03.2024, 18:28 #821Standart Power
- 03.01.2021
- 196
- 18
29.03.2024, 23:56 #822Координатор темы
- 03.02.2006
- 53
- 20,753
- 10225
- 5491
30.03.2024, 21:52 #823QRP
- 26.07.2023
- 41
- 4
Any way to increase the "capacity" or store of DX spots?
During busy contests, spots are disappearing from the list in less than 10 minutes, even if the life has been set to 120 minutes.
Been looking for a setting to change but can't find it.
30.03.2024, 23:45 #824Координатор темы
- 03.02.2006
- 53
- 20,753
- 10225
- 5491
01.04.2024, 17:08 #825Standart Power
- 03.01.2021
- 196
- 18
Here's a little request for future changes
Send spot via telnet --> Insert macros in info
Please add [submode] field
Thank you.
73 de IK2XDE Andrea.
In this regard, I think that in a very busy contest like a CQ WW the time limit to use is 20 minutes,
no more, 120 minutes is too much...we're talking about thousands of spots per minute.
But anyway what is the real limit set in loghx...??
Is there a maximum number or not..??
167Спасибо
