13.08.2020, 23:20 #61Пользователь Linux
- 07.04.2002
- г.Москва, г.Троицк
- 49
- 9,498
- 2570
- 7707
14.08.2020, 03:59 #62QRP
- 26.10.2019
- 46
- 17
- 9
Hello friends, RX4HX and RC3C.
In search of a solution, I adopted an action radical all was deleted, and a new installation was done, and to work fine, all field from "ADIF setup" now are in blank.
Alexei, in all old versions, until the version 558 the "ADIF setup" were :
[ConvertADIFField]
ADIFField1 = QSLMSG # ADDRESS
ADIFField2 = COMMENT # NOTES
ADIFField3 = STATE1 # USER1
ADIFField4 = STATE2 # USER2
ADIFField5 = STATE3 # USER3
[SetADIFField]
USER1 = STATE1
USER2 = STATE2
USER3 = STATE3
To summarize, the problem cannot be attributed to the size of large.adi, as reported, but perhaps due to the combination of fields assigned into "ADIF setup" together with the recent versions.
I appreciate the collaboration and the attention received.
73 from py5ej.
Pavanatti.Последний раз редактировалось Alde; 14.08.2020 в 04:03.
14.08.2020, 09:01 #63Пользователь Linux
- 07.04.2002
- 49
- 9,498
- 2570
- 7707
15.08.2020, 23:54 #64Координатор темы
- 03.02.2006
- 53
- 20,753
- 10225
- 5491
You right! Problem was here. Fixed:
http://rx4hx.qrz.ru/files/loghx/prer..._build_563.exe
P.S. Check Setup->ADIF setup - I changed here.73 de RX4HX, Alexei, http://rx4hx.qrz.ru
Ant.: UW4HW, Pwr.: ~500 Wtts
17.08.2020, 15:36 #65QRP
- 26.10.2019
- 46
- 17
- 9
Hello!
Dear Alexei, with the new version 563 everything is back to normal, now it is possible to use the old ADIF setup.
Thanks and,
73 from py5ej,
Pavanatti.
21.08.2020, 22:13 #66Low Power
- 16.04.2020
- 89
When I work a station from the USA for example and I am using QRZ.com as the lookup, the log fills in the name and address but not the state and QSL information. I need to manually run "find from internet" for the date tag before it updates. Any ideas what I am missing?
22.08.2020, 09:09 #67Координатор темы
- 03.02.2006
- 53
- 20,753
- 10225
- 5491
23.08.2020, 02:08 #68Low Power
- 16.04.2020
- 89
30.08.2020, 23:54 #69QRP
- 25.03.2020
- 30
- 20
Hello again Alexei,
I understand that you are quite busy working on other parts of your log program these days. I do, however, hope that you will find time to make automatic reading of wsjtx_log.adi work again.
Using the test versions, i understand that the "Active calls for JT65/Jt9FT8... modes" window will read the frequency of RX1. In my setup using Sunsdr2-DX, I use RX2 for FT8/FT4, picking CW DX on RX1. I may have overlooked something in the setup, but otherwise it would be nice to have an option to direct the active calls window to the QRG of RX2.
73 de LB2EG Richard
31.08.2020, 08:54 #70Координатор темы
- 03.02.2006
- 53
- 20,753
- 10225
- 5491
I'm check this - all is ok! May be wrong path to wsjtx_log.adi in log setup for external programs?
How JTDX/WSJT-X work with SunSDR2?
May be two path:
1. JTDX use LogHX as virtual TS-870 - set number radio here:
2. LogHX use TCI and JTDX work with ExpertSDR as TS-480 (select COM port for second radio)73 de RX4HX, Alexei, http://rx4hx.qrz.ru
31.08.2020, 16:03 #71QRP
- 25.03.2020
- 30
- 20
02.10.2020, 00:01 #72QRP
- 25.03.2020
- 30
- 20
Hello Alexei,
I have two radios in home shack, SunSDR2-DX and Flex-6300. When using the Flexradio with loghx (build 575) i am trying to direct dxcluster spots to the SMARTSDR waterfall, using the N1MM UDP protocol. I can monitor the xml data sent from loghx to SmartsSDR via SmartCAT N1MM UDP port but no spots shows up on the waterfall. Using N1MM sending spots to SMARTSDR works ok.
Reading the Russian language loghx groups, I understand that you did some testing on this in December 2018, but I cannot find any info on success..
If this function is not working in loghx, I can assist on testing.
73 de LB2EG RichardПоследний раз редактировалось lb2eg; 02.10.2020 в 00:07.
02.10.2020, 23:15 #73Координатор темы
- 03.02.2006
- 53
- 20,753
- 10225
- 5491
03.10.2020, 10:43 #74QRP
- 25.03.2020
- 30
- 20
On N1MM website you will find the information here (spot data) https://n1mmwp.hamdocs.com/appendice...dp-broadcasts/
Comparing xml data sent from loghx to SmartSDR on UDP port 12061 to data from N1MM shows very little difference :
From LOGHX:
From N1MM:
73 de LB2EG RichardПоследний раз редактировалось lb2eg; 03.10.2020 в 10:50.
03.10.2020, 11:26 #75Координатор темы
- 03.02.2006
- 53
- 20,753
- 10225
- 5491
Thanks for info!
Correct - try this version:
http://rx4hx.qrz.ru/files/loghx/prer..._build_576.exe73 de RX4HX, Alexei, http://rx4hx.qrz.ru
167Спасибо
