Страница 2 из 68 ПерваяПервая 1234567891252 ... ПоследняяПоследняя
Показано с 16 по 30 из 1017
Like Tree167Спасибо
Тема: LogHX: English version
  1. #16
    26.10.2019
    46
    17
    9
    Thanks for your help to updating LogHX's internal callbook, great result.
    Following your guidance, the internal Callbook was updated, and added 25000 news Calls sign to internal callbook.
  2. #17
    07.04.2002
    г.Москва, г.Троицк
    49
    9,497
    2569
    7700
    Цитата Сообщение от F5CBQ Посмотреть сообщение
    I checked on my 2 computers and the acces rights are the same.....I certainly miss something !
    ah, OK.
    Seems to be,,
  3. #18
    12.01.2020
    10
    I run in administrator mode, turned off the antivirus, and it does not work
  4. #19
    26.10.2019
    46
    17
    9
    Importing/exporting an adif file, some CQ/ITU zones are modified by LogHX.
    LogHX3Setup_build_529, in a simple process of importing/exporting an adif file, some CQ/ITU zones are modified by LogHX.
    To test the file "IN original.adi" was imported to >> LogHX >> and the file exported was "OUT changed.adi".
    Please see the following:
    AA4M - DM42 - CQ/ITU 03/06 in > the LogHX export CQ/ITU 05/08
    K6JDC - FM07VX- CQ/ITU 05/08 in > the LogHX export CQ/ITU 03/06
    N7MDW - EM75XR- CQ/ITU 04/08 in > the LogHX export CQ/ITU 03/06
    K5PDC - FM16TV- CQ 05/08 in > the LogHX export CQ 04/08
    KV4AA - EN41VL- CQ/ITU 04/07 in > the LogHX export CQ/ITU/ ITU 05/08
    I need help to config the LogHX for import/export an adif file to LogHX without changing the original (in case CQ/ITU).
    Thanks for any help to config the logHX.
    Вложения Вложения
  5. #20
    03.02.2006
    20,618
    10148
    5452
    Not problem:
  6. #21
    03.02.2006
    20,618
    10148
    5452
    not work
  7. #22
    26.10.2019
    46
    17
    9
    Not problem:
    Hi Alexei,
    Thanks for your prompt reply, I configured the import options for LogHX, as your recommendation, but the problem still exists.
    I used the "IN original.adi" file in the attachment to my initial post to test.
    When I import my complete log (50000 records), + - 5% of the records are exported with the CQ / ITU changed by LogHX.
    I am looking for import options like "(not) Compute DXCC from callsign", available at UR5EQF Log.
    73 of PY5EJ.
  8. #23
    12.01.2020
    10
    I found it in the LogHX folder. Is it correct ?
  9. #24
    03.02.2006
    20,618
    10148
    5452
    problem still exist
    Fixed - now work well:
    http://rx4hx.qrz.ru/files/loghx/prer..._build_530.exe
    Is it correct
    No - Ctrl+Alt+Del -> Task manager -> Look at StopMachineServer in working process.
  10. #25
    12.01.2020
    10
    Alexei, I hope to be in the correct folder
Название:	SpotMachine Server.jpg
  11. #26
    26.10.2019
    46
    17
    9
    Importing/exporting file.adi, solved with LogHX_530.
    Hi Alexei.
    With a new release, LogHX_530, my problem with CQ/ITU was solved.
    Thanks for all,
    73 de py5ej,
    Pavanatti
  12. #27
    03.02.2006
    20,618
    10148
    5452
    Something is blocking the signal from SpotServer to Log.
    It's may be inside Window antivirus - try insert log and spotserver to exception.
    Here is russian:
    https://forum.qrz.ru/377-jt65-jt9-ws...ml#post1650284
    For help:
    Run gpedit.msc, then
  13. #28
    12.01.2020
    10
    some news .... I installed gpedit successfully. I inserted exeptions but the problem is still present .... I installed a new antivirus (Avast) instead of windows antivirus. despite the installation of the new antivirus, I still have the problem .....
  14. #29
    12.01.2020
    10
    in the "time file spots" setup, the time life is 1 hour for the bandmap. in the radio1 bandmap, the time life spot is only 2/3 minutes. Why I can't increase the time life spot in the radio 1 bandmap? is it possible to highlight the spot in the radio bandmap ? Нажмите на изображение для увеличения.
Название:	Time life spots.jpg
  15. #30
    Low Power
    16.04.2020
    89
    3
    Hi
    I am looking at changing my QSO input box from what I have
    to something like this to save space at the top of the box. Plus I like the colours to highlight the freq, band etc
    I am new to this, secondary question, can I run loghx, wsjt and JT alert all at the same time? I have loghx and wsjt working OK but when I add in JT alert it doesn't work, I think due to UDP conflicts. I have tried various changes but cannot seem to fix it. I want JT alert to read my LogHx log.
  1. LogHX: Актуальные релизы и история изменений.
    Ответов: 971
    Последнее сообщение: 08.01.2026, 00:04
  2. DIY UW3DI (for English OPs)
    от UU2JET в разделе КВ: UW3DI
    Последнее сообщение: 18.01.2013, 12:04
  3. KENWOOD TS-2000 (Black Version)
    от UA3IRS в разделе TS-2000
    Последнее сообщение: 16.11.2009, 20:16
  4. Navitel 2.0 Pocket PC Version
    от RX3AOE в разделе APRS
    Последнее сообщение: 26.09.2006, 03:39
  5. windows 64 bit version не ставится
    от UR4LZW в разделе Программное обеспечение
    Последнее сообщение: 12.09.2005, 23:58
