12.05.2020, 09:25 #46Координатор темы
- 03.02.2006
- 53
- 21,047
- 10424
- 5587
Yes, log waiting answer from LoTW server, when tq8 file send to LoTW server. But waiting for a timeout. Timeout is about 30-40 sec (Timeout set not log, timeout set windows).
Ok, I will think about how to solve this problem. But the problem of waiting for a response from the server is this problem windows, not log. Here is problem.
If I understand correctly: you can add any file to QSO here -
Ant.: UW4HW, Pwr.: ~500 Wtts
09.08.2020, 17:01 #47QRP
- 26.10.2019
- 46
- 17
- 9
Hello friends ,
I need some guidance, to set the Capitalization in LogHX, to automatically write the first letter in upper case and the rest of the letters in lower case.
A feed back for versions 559 and 560, in these versions, I can't import any more .adif (upload) files exported from UR5EQF of size 57000 QSO.
When an attempt imports a small .adif with two QSOs, the process works, but a large file doesn't.
If an old version is reinstalled as 558, all working well, I use Windowns 7.
Thanks for any help, 73 de py5ej.
Pavanatti.
09.08.2020, 17:41 #48QRP
- 25.03.2020
- 30
- 20
Aexei,
After version 555/555 automatic reading of wsjtx_log.adi does not work anymore. Only UDP works. This is also the case on 560.
73 de LB2EG
11.08.2020, 09:41 #49Координатор темы
- 03.02.2006
- 53
- 21,047
- 10424
- 5587
It's work only for Name and QTH fields in QSOEntry window:
Can you send to me adif file? rx4hx@mail.ru I check it.
... Correct e-mail.
I'll try to check it out today.Последний раз редактировалось RX4HX; 11.08.2020 в 11:45.
11.08.2020, 12:27 #50Координатор темы
- 03.02.2006
- 53
- 21,047
- 10424
- 5587
11.08.2020, 13:23 #51Low Power
- 16.04.2020
- 89
I have just found my old .adif log from 20years ago and wanted to merge it into my existing log, however I don't want it to alter my DXCC as I am in a new QTH now, but I still want to be able to check the log quickly to see if we have had a QSO before.
So is there anyway to do this if I have my 2020 log open, for it to check the older log aswell?
11.08.2020, 15:15 #52Пользователь Linux
- 07.04.2002
- г.Москва, г.Троицк
- 49
- 9,540
- 2606
- 7758
If you had a callsign prior to this one, you have to create another log in LOGHX and import your old ADIF into that log.
If you have current callsign still, you can import your old ADIF into existed log and DXCC stats will be updated as well.
73! Anton RC3C (ex.RV3DHC, RK3KPE, 5ØVE/Ø, 5ØRC/38A2, 5ØRC/RP81, 5ØMKØØ12) & RY3AAL & 5ØRDXØØ3 & 5ØRC1Ø7 & RK5AØØ2SWL
11.08.2020, 15:28 #53Low Power
- 16.04.2020
- 89
Thanks, well its the same callsign but different QTH.
So I wanted to restart the DXCC, but also still check the other old log for previous QSOs. As this week I worked 2 stations who told me we had worked over 20 years ago, so that got me interested to find the adif, which I got from eqsl.
So basically I have main log M0CGF but would like to cross reference the M0CGF1999-2003 log when searching for callsigns.
11.08.2020, 15:48 #54Координатор темы
- 03.02.2006
- 53
- 21,047
- 10424
- 5587
11.08.2020, 15:50 #55Пользователь Linux
- 07.04.2002
- 49
- 9,540
- 2606
- 7758
If you already created M0CGF1999-2003 log , you have to press RMK (right mouse knob) in any point of "Previous QSO" window and choose other existed log to search for QSO you made years ago.
You're welcome.
LOGHX is not depended on different QTHs
anyway. So, you are able to create any other logs for different calls/qths as you wish.
12.08.2020, 16:38 #56QRP
- 26.10.2019
- 46
- 17
- 9
Hello, Alexei,
Thanks for orientation, the file. Adit was sent.
Sorry, about Capitalization question, I wasn't clear;
In my logHX the "Begin QTH with the upper letter" was setting, and not solve my problem.
Please, think in following scenery:
New station, for example "EE100V", is not present on Internal Callbook, is a new one on logHX.
From QRZ.com came Name: 100 ANIVERSARY VALENCIA C.F.
and QTH: ESPAÑA
So far it's perfect.
Now editing, Name and QTH fields in QSOEntry window, the Capitalization not work automatically, and here was my question.
Thanks again for any suggestion.
73 de py5ej,
Pavanatti.
13.08.2020, 13:49 #57Low Power
- 16.04.2020
- 89
Excellent thanks so much! Just got that working!
13.08.2020, 14:54 #58Координатор темы
- 03.02.2006
- 53
- 21,047
- 10424
- 5587
Fixed:
https://forum.qrz.ru/355-loghx-appar...ml#post1717329
http://rx4hx.qrz.ru/files/loghx/prer..._build_562.exe
Yes - it' work only when name or QTH manually enter.
which letter should be capitalized if name is "100 ANIVERSARY VALENCIA C.F."?73 de RX4HX, Alexei, http://rx4hx.qrz.ru
13.08.2020, 21:41 #59QRP
- 26.10.2019
- 46
- 17
- 9
Capitalization
Alexei, on the used example, a club station not involve a personal names, but In nearly all European and Latins languages, single-word proper nouns, including personal names, are capitalized as Name and QTH, that was the reason for the question.
Thanks so much for your attention to clear me that function to Capitalization Automatically the data from QRZ.com, Name and QTH fields in QSOEntry window, are not configurable, and it' work only when name or QTH are manually entered.
I did try the new version 562 with large.adi, exported from version 558, sorry, unfortunately the problem persists.
Perhaps the problem is with my local system.
I thank you for your work and promptness, please accept my thanks.
73 from py5ej.
Pavanatti.
13.08.2020, 22:18 #60Координатор темы
- 03.02.2006
- 53
- 21,047
- 10424
- 5587
169Спасибо
