16.01.2021, 13:57 #196Standart Power
- 03.01.2021
- 196
- 18
16.01.2021, 16:10 #197Пользователь Linux
- 07.04.2002
- г.Москва, г.Троицк
- 49
- 9,498
- 2570
- 7707
Andrea,
Please, check WFF field equals to WFF. It has to be. If not, you have to change it to WFF.
1) Click 1 time LKM (Left key mouse) on WFF field
2) click RKM (right key mouse)
3) In opened menu use "Set log field"
4) In small window check if WFF equals to WFF like as my example
5) Change the field if no equal to WFF
6) LKM on [V] Field: options
7) choose the right log Field name to set
8) When choice is done, then click OK
if you need to change the name of log field, just change manually field "Field caption:" by typing text, then choose right Field log name to equal (see 6-7-8 units above)
Hope it helps
There is no WFF territory list in LogHX at all, Andrea.Последний раз редактировалось RC3C; 16.01.2021 в 16:08.
16.01.2021, 17:01 #198Standart Power
- 03.01.2021
- 196
- 18
18.01.2021, 00:28 #199QRP
- 26.10.2019
- 46
- 17
- 9
Suggestion to LogHX country_district.dat to BY - China
Alexey, Andrea and Anton.
In attached on to "country_district.dat (17jan21)" there is a complement for VK country, and new data for BY country, all info is for analyze and test.
To test, please, rename and replace the file original.
Thanks.
73 de py5ej.
Stay save.
18.01.2021, 00:34 #200Пользователь Linux
- 07.04.2002
- 49
- 9,498
- 2570
- 7707
18.01.2021, 21:12 #201Standart Power
- 03.01.2021
- 196
- 18
Thanks Alde,
I will test it as soon as possible.
In this moment I focus my test on the award,
but I can't get the drop-down menu working on the other fields,
only on the iota it works. (in the qso entry windows)
I cannot choose the reference of the 9AFF (for example) from the menu,
but I can only enter it manually.
73 de IK2XDE Andrea
18.01.2021, 23:09 #202Big Gun
- 28.11.2013
- 71
- 6,135
- 4071
- 753
19.01.2021, 00:16 #203Standart Power
- 03.01.2021
- 196
- 18
Hello Niclolay,
thanks for your answer,
but I think you are wrong.
Is not necessary to use USER5 field.
Reference was in WFF field.
So you can insert reference for 9AFF award in the WFF field
And you can find your qso, with WFF field with 9AFF reference
And also you can find qsl in 9AFF award statistic.
The problem that I write was that in the QSO entry windows,
for IOTA field we have a drop-down menu that
present all IOTA reference valid for this call......
This function NOT work for WFF field.
Thanks.
73 de IK2XDE Andrea
23.01.2021, 02:25 #204Standart Power
- 03.01.2021
- 196
- 18
MULTIPLE LOG with MULTIPLE CALSIGN......How to setup...??
Can someone explain me how to setup multiple log with multiple callsign.
My situation was:
Log: IK2XDE - Operator: IK2XDE Andrea
Log: IK2XDF - Operator: IK2XDF Gianpaolo (my brother)
Log: IQ2LZ - Operator: IK2XDE+IK2XDF+IK2ZJR....and other (club station call)
All log have different QTH and different login and password for LOTW/EQSL/HRDLOG...ecc..
I think the way was create 3 different DATABASE, and inside 3 different LOG (one for call)
Where I put all different config for LOTW/EQSL/HRDLOG...eccc...
Thanks.
IK2XDE Andrea
Previus QSOs windows
If in QSO ENtry window i type HG5OG, in the previus qso i find HG5OG and also HG5OGI
But that is wrong......HG5OGI was different call station.
I think this is a little bug.
23.01.2021, 08:59 #205Координатор темы
- 03.02.2006
- 53
- 20,753
- 10225
- 5491
For use log fom many callisgn:
https://forum.qrz.ru/355-loghx-appar...ml#post1765426
Run log with parametr - /D=<Folder name with ini-files> like:
LogHX3.exe /D=IQ2LZ
Easy way - make icons for each call on desctop. When you run LogHX3.exe /D=IQ2LZ first time - all ini-files will be copy on C:\LogHX\IQ2LZ folder (if log was installed in C:\LogHX). And now you can setup log for IQ2LZ with itself paramerts.
Create new log-base for each call.
Look here:
Ant.: UW4HW, Pwr.: ~500 Wtts
24.01.2021, 16:10 #206Standart Power
- 03.01.2021
- 196
- 18
OK,
it would be more practical to switch from one log to another without having to exit the program.
Binding the directory with all the INI files to the log and call.
However, the idea of having separate directories for each call is great.
I tried /D=IK2XDE and it works, created the directory and copied the files.
At the start, however, does NOT connect the cluster via telnet.
If I run the program without /D=IK2XDE the telnet works fine.
73 de IK2XDE Andrea
25.01.2021, 16:52 #207QRP
- 26.10.2019
- 46
- 17
- 9
Suggestion to HC+HK+OA on country_district - LogHX
Hello Alexey (RX4HX), and LogHX users!
For analysis, testing, and possible inclusion in future LogHX distributions, I present, attached, the file "CountryFile HC+HK+OA 2021-01-24.zip".
In addition to the previous suggestions, information was included for HC (Ecuador), HK (Colombia) and OA (Peru).
To test, please rename and replace the original file.
73 from py5ej,
Pavanatti.
Stay save.
25.01.2021, 19:42 #208Координатор темы
- 03.02.2006
- 53
- 20,753
- 10225
- 5491
25.01.2021, 19:57 #209Пользователь Linux
- 07.04.2002
- 49
- 9,498
- 2570
- 7707
26.01.2021, 00:00 #210Standart Power
- 03.01.2021
- 196
- 18
About the Band / Mode Statistic
Currently showing two values (qso worked) + (qso confirmed)
You could please evaluate the possibility of putting the choice of single view (only qso worked) or the double one (worked + confirmed).
To be able to change the sort of "mode" columns.
It would also be nice to be able to export it to excel.
Thanks.
IK2XDE Andrea.
167Спасибо
