11.04.2021, 20:57 #301Пользователь Linux
- 07.04.2002
- г.Москва, г.Троицк
- 49
- 9,498
- 2570
- 7707
is that strictly needed?
If the IK3QAR and QRZ COM/RU services are included, there is no matter to update local QSLM database. Also, there is a tool in menu to see NG8K contest callsign activity/QSLm information.
I believe everyone update it manually for their needs, I do that here.
12.04.2021, 09:30 #302Standart Power
- 03.01.2021
- 196
- 18
13.04.2021, 01:20 #303Standart Power
- 03.01.2021
- 196
- 18
Hello Alexey,
the problem described in message 223 persists even with build 634.
about message 273 I hope you will consider this implementation.
(eqsl download QSL immage and put it in photo field)
73 de IK2XDE Andrea.
13.04.2021, 11:50 #304Координатор темы
- 03.02.2006
- 53
- 20,753
- 10225
- 5491
Ant.: UW4HW, Pwr.: ~500 Wtts
13.04.2021, 19:42 #305Standart Power
- 03.01.2021
- 196
- 18
Hello
SET FREQ FOR BUTTON was correct,
problem when a change band, (CHANGE BAD FROM RADIO)
CAT change band in the qso entry windows, and the band map but....
bold fond change with band so....like in example 40m (BOLD FONT)
but yellow button background NOT hcange band...stay on old band. (17m in example)
If I change band press bandmap button all is ok...!!Последний раз редактировалось IK2XDE; 13.04.2021 в 19:48.
24.04.2021, 14:18 #306Standart Power
- 03.01.2021
- 196
- 18
Using VOICE WINDOWS with LogHX 3.0 build 636
If I setup button as in image, I receive error....file NOT FOUND
But if I remove [TX] and [RX] file was found and play by logHX regularly
I think there is some problem with TX command.....that include [TX] and [RX] in the file path name.
Please confirm that TX command FOR VOICE WINDOWS will be send via PTT COM SET for MMVARI (AFSK)
If yes...please add description for PTT for MMVARI and VOICE (AFSK)
Thanks.
73 de IK2XDE Andrea.Последний раз редактировалось IK2XDE; 24.04.2021 в 14:27.
27.04.2021, 12:10 #307Координатор темы
- 03.02.2006
- 53
- 20,753
- 10225
- 5491
27.04.2021, 12:51 #308Standart Power
- 03.01.2021
- 196
- 18
Yes....with no macros, file will play regularly,
but radio NOT go in TX.....PTT not work....!!
I think PTT is the same of MMVARI......right.....???
73 de IK2XDE Andrea
27.04.2021, 15:59 #309Координатор темы
- 03.02.2006
- 53
- 20,753
- 10225
- 5491
27.04.2021, 20:23 #310Standart Power
- 03.01.2021
- 196
- 18
Well....I have a problem.
I use different radio for CW and for SSB and DIGI.
On SSB and DIGI I use ICOM IC-7600 ACC1 connector wired to COM7 (no CW-KEY connector)
PTT was on COM7 (DTR) work correct with MMVARI in AFSK mode
FSK was on COM7 (RTS) work correct with MTTY in FSK mode (with external FSK)
No CW port was configured. (NO CABLE)
Just put in the RADIO SETUP window the choice of PTT line for the voice keyer.
VOICE PTT --> like CW PTT....or like MMVARI PTT
In fact the voice is transmitted through the sound blaster as for the psk31 in AFSK.
I hope it is possible, I await your confirmation.
Thank you.
73 de IK2XDE Andrea
27.04.2021, 21:34 #311Координатор темы
- 03.02.2006
- 53
- 20,753
- 10225
- 5491
27.04.2021, 22:09 #312Standart Power
- 03.01.2021
- 196
- 18
Yes, if I use only one radio, but CW/PTT set on COM5,
was connect to the second radio IC-7600
(Yes I have two ICOM IC-7600) that work simultaneously. (of course with filter and different antenna....hi..)
COM 2 for CAT
COM 5 for CW on IC-7600 (1)
COM 7 for SSB and DIGI on IC-7600 (2)
all configured as RADIO1
on RADIO2 I have SunSDR2DX with TCI
My station was Multi TX and Multi Operator
IK2XDE Andrea and my brother IK2XDF Gianpaolo
Thanks for attention.
01.05.2021, 14:01 #313Standart Power
- 03.01.2021
- 196
- 18
Hello, using LogHX v3.0 build 636
Start log with /D=IK2XDE
Select view template,
show template in C:/LOGHX/Views and not template in C:/LOGHX/IK2XDE/Views
I thinks correct is: if I start with /D=IK2XDE will show template in C:/LOGHX/IK2XDE/Views
I thinks correct is: if I start with /D=IQ2LZ will show template in C:/LOGHX/IQ2LZ/Views
I thinks correct is: if I start with /D=IK2XDF will show template in C:/LOGHX/IK2XDF/Views
All operators can have different display choices based on the operating mode and personal choices.
SAVE TEMPLATE work correct and save template in the correct directory, but Select template show always default directory.
01.05.2021, 23:30 #314Standart Power
- 03.01.2021
- 196
- 18
Upload QSO to Clublog/Lotw/Eqsl
If I select new function "Manually upload to server"...all work fine....!
but at this point I think another step is needed.
After creating the adif file ..... before closing the window .... the choice should be presented:
Mark exported qso as SENT...... YES or NO
Infact now, all qso exported to adif, was NOT marked as send.
Thanks.
In this regard, it would be enough to have a separate configuration for the voice.
CW / PPT
MMVARI / PTT
VOICE / PTT
surely other colleagues will have different configurations
73 de IK2XDE Andrea
02.05.2021, 01:17 #315Low Power
- 02.05.2021
- 53
- 6
Hi, who knows when the 705 will be supported for a CatHX configuration ?
When I'm using LogHX with Win4IcomSuite and CWskimmer with Omnirig (The only way for cwskimmer), I,m not able to configure the IC-705 in LogHX with Omnirig (I have a violation). To bypass this issue I use the last version of Flrig that support the IC-705 for LogHX but it is not optimum. I have some trouble durng the initialization of LogHX and Flrig. After some time it works but it is not very friendly
73s Christian F8GHE
- - - Updated - - -
Hi, who knows when the Icom IC-705 will be supported for a CatHX configuration ?
73s Christian F8GHE
167Спасибо
