Страница 28 из 68 ПерваяПервая ... 1821222324252627282930313233343538 ... ПоследняяПоследняя
Показано с 406 по 420 из 1017
Like Tree167Спасибо
Тема: LogHX: English version
  1. #406
    14.03.2022
    Oud-Turnhout
    59
    13
    4
    Thanks Alexei,
    Now it works, it is also possible to use 2 open QSO Entry for Radio 1 & 2.
    73 Pat
    - - - Updated - - -
    When I use RX1 on 10.136 DIGU for FT8 with JTDX, then I can't change RX2 on 40M, it stays on DIGU.
    When I click LSB it goes back to DIGU.
    73 Pat
  2. #407
    03.01.2021
    196
    18
    It's been a while since I wrote, today we are at version 3.0 build 686
    Here are some observations:
    The awardsbase.mdb file which is normally found in the ... /LOGHX/AWARDS directory
    It is not copied to the directory .... /LOGHX/IK2XDE/AWARDS
    if I start the software with the command LogHX3.exe /D=IK2XDE
    It would be useful if LOGHX automatically proposes the update of the CTY.DAT file
    when and if available.
    https://www.country-files.com/big-cty/
    or a button is created to automatically search and update this file
    Regarding the offline file managers, I think it is useless to ask the management,
    I know you are working on it ... I hope to see it soon in the next version.
    73 de IK2XDE Andrea
    ik2xde@gmail.com
    IK2XDE Andrea - WWLoc. JN45MQ
    https://www.xdenews.net/ik2xde/logonline/
    RADIO Setup (update 30/08/2025)
    ICOM IC-7600 - (HF - 50MHz.)
    SunSDR2DX - (HF - 50MHz. - 144 MHz.)
    OM Power - OM2000A+ (1.8-50 MHz. Amplifier)
    OB11-3 (11 element - 3 band - 10m-15m-20m)
    OB9-3 WARC (9 element - 3 band - 12m-17m-30m)
    SkyWire Loop (40-60-80-160 m.)
    LogHX Managers Database (update for free)
    https://www.xdenews.net/managers/
  3. #408
    07.04.2002
    г.Москва, г.Троицк
    49
    9,498
    2570
    7707
    1) It updates by Alexey when new pre or release published
    2) you can manually update it by tracking availability the file on certain resource.
  4. #409
    03.01.2021
    196
    18
    Hello,
    obviously what you wrote, is the procedure we have done up to now,
    but an automatism, without waiting for a new software release, would be very welcome.
    When the software starts, as it checks if there is a new release,
    in the same way it could check if there is a new version of the CTY.DAT file
    We will be very grateful to you Alexey
    73 de IK2XDE Andrea.
  5. #410
    07.04.2002
    г.Москва, г.Троицк
    49
    9,498
    2570
    7707
    it is optional IMHO, but the last word is from Alexey.
    For myself I do I manually is case of really few changes in CTY.DAT time-to-time happens.
    Do you know the procedure HOWTO update CTY.DAT by your hands?
  6. #411
    Low Power
    02.05.2021
    6
    Hello,
    I'm in JN37AH (Est of France near Besançon), when I plot on maps spots from my own local skimmer, it's like I'm in the south of america. My station setup seems correct. What I could forget ?
    7"s Christian F8GHE
  7. #412
    03.02.2006
    20,753
    10225
    5491
    Цитата Сообщение от F8GHE Посмотреть сообщение
    JN37AH
    Check locator in Setup->General setup and Setup->Profiles (if used).
  8. #413
    Low Power
    02.05.2021
    6
    My General Setup
    It's correct when I connect the Spot machine to the RBN (With the telnet protocol).
    Not clear for me! I have to do more tests for more details in my request !!
    73s Christian F8GHE
  9. #414
    03.01.2021
    196
    18
    Yes.
    Alexei knows that I am available for every need,
    I have already made myself available to him several times.
    We hope he take this into consideration too.
    Here all work fine with buil 686.
    73 de IK2XDE Andrea
  10. #415
    07.04.2002
    г.Москва, г.Троицк
    49
    9,498
    2570
    7707
    ok, Andrea. Good. So, Alexey has always his last word in any case because it is his LOG.
  11. #416
    03.02.2006
    20,753
    10225
    5491
    My General Setup
    In log check you locator -
    is here ok?
  12. #417
    Low Power
    02.05.2021
    6
    is here ok?
    Yes this setup seems correct but I have to check to configure the Localhost Spot-Machine to spots my CWskimmer-srv output (It seems the origin of issue)Нажмите на изображение для увеличения.
  13. #418
    Low Power
    02.05.2021
    6
    I just find my mistake !! It was the Localhost setup Нажмите на изображение для увеличения.
  14. #419
    03.02.2006
    20,753
    10225
    5491
    Thanks for finding the problem! Yes, I completely forgot that you need to specify your call sign in Localhost!
  15. #420
    Low Power
    02.05.2021
    6
    Alexei,
    Here are just 2 small syntax errors in the LocalHost configuration window of the spotmachine
    - Log in promt => Login prompt
    - Replay => Login prompt answer
    73s Christian F8GHE
  1. LogHX: Актуальные релизы и история изменений.
    Ответов: 971
    Последнее сообщение: 08.01.2026, 00:04
  2. DIY UW3DI (for English OPs)
    от UU2JET в разделе КВ: UW3DI
    Последнее сообщение: 18.01.2013, 12:04
  3. KENWOOD TS-2000 (Black Version)
    от UA3IRS в разделе TS-2000
    Последнее сообщение: 16.11.2009, 20:16
  4. Navitel 2.0 Pocket PC Version
    от RX3AOE в разделе APRS
    Последнее сообщение: 26.09.2006, 03:39
  5. windows 64 bit version не ставится
    от UR4LZW в разделе Программное обеспечение
    Последнее сообщение: 12.09.2005, 23:58
