28.05.2021, 20:38 #331Standart Power
- 03.01.2021
- 196
- 18
Thanks, now with buil 645 work great.....PTT and CW on different port.......thanks....!!
Sorry, with buil 645 I NOT found DXCC field in the clublog/eqsl/hrdlog adif file.
SORRY THIS MOD NOT WORK
<< NEW >>
Now orange band button change band correctly in the bandmap.....thanks....!!
<< NEW >>
The VOICE WINDOWS not resize the button key (NOT ENLARGE the button)
Thanks.
73 de IK2XDE Andrea.Последний раз редактировалось IK2XDE; 28.05.2021 в 20:45.
29.05.2021, 10:51 #332Координатор темы
- 03.02.2006
- 53
- 20,753
- 10225
- 5491
Thank you very much Andrea!
Your comments are very helpful in working on log!
I'll fix it soon!73 de RX4HX, Alexei, http://rx4hx.qrz.ru
Ant.: UW4HW, Pwr.: ~500 Wtts
04.06.2021, 21:15 #333Координатор темы
- 03.02.2006
- 53
- 20,753
- 10225
- 5491
05.06.2021, 16:20 #334Standart Power
- 03.01.2021
- 196
- 18
Yes.....with build 647 VOICE WINDOWS resize button key....now work fine.
With build 647 I NOT find DXCC adif field in the clublog upload file, please remember to do this.
Please remember also my post N. 329 about Telnet cluster.
I noticed that in the telnet window, many lines are cut / deleted especially
at the beginning of the connection, all the lines sent by the cluster are not displayed.
In my opinion this is a mistake, often in that part there are important warnings for users,
or instructions for use, for filters, for skimmers or other.
Thanks for your good job.
73 de IK2XDE Andrea.Последний раз редактировалось IK2XDE; 05.06.2021 в 16:25.
05.06.2021, 20:39 #335Standart Power
- 03.01.2021
- 196
- 18
About EQSL image.
I just download from eqsl all my 65000 qsl image,
all image are stored in a directory, C:\Users\LOG\Pictures\IK2XDE-EQSL
As you can see in the example, all immage,
All qsl use this format file name: CALL_DATE_TIME_BAND_MODE.png
I try to import a single file image in the PHOTO field of the log, and all work fine,
but, import manualy 65000 file take a long time.
Can you please add and automatic integration of the file....??
For example, if I push show photo (on selected qso)
automatic verify if file exist in the declared directory, and show it.
No importing all immage, no importing link or other, only verifiy the file ...and if exist show it.
Thanks for your attention,
I hope this change is possible....!!
06.06.2021, 01:02 #336Координатор темы
- 03.02.2006
- 53
- 20,753
- 10225
- 5491
07.06.2021, 11:26 #337Координатор темы
- 03.02.2006
- 53
- 20,753
- 10225
- 5491
07.06.2021, 19:56 #338Standart Power
- 03.01.2021
- 196
- 18
Well, thanks you for your work.
- With build 648 in the cluster telnet windows, all the string are showed, all seem to work correct now....thanks...!!
- With build 648 in the cluglog adif, was added DXCC adif field, well....tested, and all work fine.......thanks...!!
- With build 648 we have now a problem with separete COM configuratio of PTT and CW
with buil 647 work great, but now if i setup a different port, CW work on the same port of PTT.
I think you will have to verify something here....!!
Thanks for your effort.
08.06.2021, 08:00 #339Координатор темы
- 03.02.2006
- 53
- 20,753
- 10225
- 5491
08.06.2021, 19:34 #340Standart Power
- 03.01.2021
- 196
- 18
Made some other test,
with build 648 .....PTT/CW separate COM port work fine.....!!
This is my config "RADIO 1" SETUP ( 2 x IC-7600 )
IC-7600 N.1
PTT for Voice Key on COM7
MMVARI for AFSK digi like PSK31/63 on COM3
IC-7600 N.2
CW for CW KEY on COM5
MMTTY for FSK RTTY with EXTFSK64 on COM4
SunSDR2DX
On "Radio 2" I have setup TCI with SunSDR2DX
no problem with TCI....no problem with SDC.....!!
73 de IK2XDE AndreaПоследний раз редактировалось IK2XDE; 08.06.2021 в 19:43.
09.06.2021, 22:41 #341Standart Power
- 03.01.2021
- 196
- 18
With build 649
there is a small problem with the CW macro window.
When I press "TUNE" there is no way to stop the transmission,
if I press "ESC" it doesn't work, I have to send a macro and then it stops.
Before (buil 647) it was turned off by pressing "ESC" or again press "TUNE"
Thanks.Последний раз редактировалось IK2XDE; 09.06.2021 в 22:50.
IK2XDE Andrea - WWLoc. JN45MQ
https://www.xdenews.net/ik2xde/logonline/
RADIO Setup (update 30/08/2025)
ICOM IC-7600 - (HF - 50MHz.)
SunSDR2DX - (HF - 50MHz. - 144 MHz.)
OM Power - OM2000A+ (1.8-50 MHz. Amplifier)
OB11-3 (11 element - 3 band - 10m-15m-20m)
OB9-3 WARC (9 element - 3 band - 12m-17m-30m)
SkyWire Loop (40-60-80-160 m.)
LogHX Managers Database (update for free)
https://www.xdenews.net/managers/
10.06.2021, 12:21 #342Координатор темы
- 03.02.2006
- 53
- 20,753
- 10225
- 5491
Try this version:
http://rx4hx.qrz.ru/files/loghx/prer..._build_650.exe
Is now ok?73 de RX4HX, Alexei, http://rx4hx.qrz.ru
10.06.2021, 19:39 #343Standart Power
- 03.01.2021
- 196
- 18
YES.....!!
from my side, i have done some tests,
and everything seems to work correctly now.
73 de IK2XDE AndreaIK2XDE Andrea - WWLoc. JN45MQ
12.06.2021, 22:01 #344Координатор темы
- 03.02.2006
- 53
- 20,753
- 10225
- 5491
Andrea!
Test also this version:
http://rx4hx.qrz.ru/files/loghx/test..._build_651.exe
Is Ok?73 de RX4HX, Alexei, http://rx4hx.qrz.ru
13.06.2021, 00:45 #345Standart Power
- 03.01.2021
- 196
- 18
With this version (build 651)
RADIO1
HXCAT with IC-7600 work fine... !!
Separate COM port.....work fine...!!
PTT on COM 7....work fine....!!
CW on COM 5.....work fine....!!
CW macros.....work fine....!!
Voice key switch radio in tx (PTT) and play the selected file......work fine....!!
RADIO2
TCI with SunSDR2dx
CAT via TCI work fne....!!
CW macro via TCI work fine.....!!
.....but....
Voice key with TCI.....NOT WORK...... (TCI does not switch the radio in TX)
All others like cluster, statistic, award, ecc.... seems to work fine.
73 de IK2XDE Andrea.Последний раз редактировалось IK2XDE; 13.06.2021 в 00:52.
167Спасибо
