Страница 20 из 68 ПерваяПервая ... 1013141516171819202122232425262730 ... ПоследняяПоследняя
Показано с 286 по 300 из 1017
Like Tree167Спасибо
Тема: LogHX: English version
  1. #286
    03.01.2021
    196
    18
    Hello Alexei,
    Using build 631
    In the "QSO MANUALLY ENTRY" now you add e drop down menu for "Print Queue" field.....welll....work fine.
    But you are missing "N" QSL NOT NEED please add it....
    Thanks.
    73 de IK2XDE Andrea.
  2. #287
    03.02.2006
    20,753
    10225
    5491
    Цитата Сообщение от IK2XDE Посмотреть сообщение
    I found what is blocking windows.
    "SHOW NEW COUNTRY"
    Many thanks Andrea! This is a big help for me! In new version I'll make here new functional.
    It is therefore very useful to be able to create the log to be sent,
    and then send it later, via the web and not automatically.
    How about variant - checkbox "Send manually" in upload window?
    Oppure per esempio io preferisco usare per LOTW il software TQSL separatamente.
    About LoTW: here create ADIF or tq8 file for manually upload?
    Look new prerelease 632 for new work of Print Queue here:
    https://forum.qrz.ru/355-loghx-appar...ml#post1792469
  3. #288
    03.01.2021
    196
    18
    Yes, for EQSL and CLUBLOG
    checkbox "CREATE ADIF TO SEND MANUALLY"
    if checked, loghx only create an adif file, to be send manually via
    web interface.
    Same checkbox here.
    Create ADIF file to be send manually with TQSL,
    then users sign file with TQSL and send to lotw server.
    Thanks.
    Ok, using build 632
    Please here add this choice "QSL NOT NEED" = PritQueue field = "N"
    Thanks in advance.
    73 de IK2XDE Andrea
    A simple solution would be to create a TXT file similar to NotFoundRecord_Lotw
    containing:
    "New COUNTRY CONFIRMED" and
    "NEW QSO CONFIRMED"
    so after synchronization we can see the result.
  4. #289
    03.02.2006
    20,753
    10225
    5491
    Done:
    http://rx4hx.qrz.ru/files/loghx/prer..._build_632.exe
  5. #290
    03.02.2006
    20,753
    10225
    5491
    Done:
    https://forum.qrz.ru/355-loghx-appar...ml#post1792793
  6. #291
    03.01.2021
    196
    18
    OK....try build 633
    works perfectly .... thanks .... !!
    With build 633 works perfectly .... thanks .... !!
    Well all work fine for me with build 633
    In this section it remains for you to fix HRDLOG.
    Without upsetting the program, it is enough that it puts UPLOAD
    with these possibilities:
    ALL QSO
    SELECTED QSO
    NOT SEND QSO
    manually upload to server (only create ADIF)
    To do this I think it is necessary to add in the log the field "HrdlogS" (Yes or No)
    to know which qso's have already been sent or not to the server.
    Thanks for the excellent work you are doing, and the constant commitment.
    In the next few days I will ask you again for the management of the local database of managers.
    73 of IK2XDE Andrea
  7. #292
    Low Power
    16.04.2020
    89
    3
    I seem to be getting this error a lot recently in 631 Название: Capturedec.JPG
  8. #293
    03.02.2006
    20,753
    10225
    5491
    What decimal separator do you use? What skin do you use (may be "broken" skin)?
    About new fields in log: i'm waiting "Russian Lotw" - http://Hamlog.online for add fields for this QSL. I hope it will be soon.
  9. #294
  10. #295
    03.02.2006
    20,753
    10225
    5491
    To M0CGF: what decimal separator here:
  11. #296
  12. #297
    03.01.2021
    196
    18
    Using build 634
    I try to setup "Digital Mode Windows" using RTTY.
    Radio was IC-7600 mode RTTY (not USB or LSB) using FSK
    So I will configure MTTY to TX with EXTFSK64.
    Problem was that when I start "Digital Mode Windows" Radio go on SSB....
    How can I configure to stay on RTTY....??
    I find that if I disable CAT (setting NO RADIO) all work fine.
    SO I think that HXCATinterface when find DIGI MODE change tu USB (using AFSK)
    but I whant to stay in RTTY using FSK.
  13. #298
    03.02.2006
    20,753
    10225
    5491
    Two variants -
    Uncheck Use SSB or check Not change TRX mode.
  14. #299
    03.01.2021
    196
    18
    Well, everything works perfectly.....!!
    Sorry but there are still some configurations / settings that I don't know.
    Have you thought about how to update the management
    of the managers on the local database ... ??
  15. #300
    03.01.2021
    196
    18
    In the "SET FILTER WINDOW"
    "Use Costum Filed" section,
    Freq field was missed....please ad it....
    I know that there is band filter,
    but is different search for 20m qsl or for 14,260 qso.
    Please add all log field here.....hi...
    Thanks in advance.
  1. LogHX: Актуальные релизы и история изменений.
    Ответов: 971
    Последнее сообщение: 08.01.2026, 00:04
  2. DIY UW3DI (for English OPs)
    от UU2JET в разделе КВ: UW3DI
    Последнее сообщение: 18.01.2013, 12:04
  3. KENWOOD TS-2000 (Black Version)
    от UA3IRS в разделе TS-2000
    Последнее сообщение: 16.11.2009, 20:16
  4. Navitel 2.0 Pocket PC Version
    от RX3AOE в разделе APRS
    Последнее сообщение: 26.09.2006, 03:39
  5. windows 64 bit version не ставится
    от UR4LZW в разделе Программное обеспечение
    Последнее сообщение: 12.09.2005, 23:58
