Страница 19 из 68 ПерваяПервая ... 912131415161718192021222324252629 ... ПоследняяПоследняя
Показано с 271 по 285 из 1017
Like Tree167Спасибо
Тема: LogHX: English version
  1. #271
    07.04.2002
    г.Москва, г.Троицк
    49
    9,498
    2570
    7707
    Цитата Сообщение от IK2XDE Посмотреть сообщение
    There is no way to see if a qso has already been sent in the past.
    For my needs I don`t upload QSO automatically to each eQSL/QSO service.
    So, if checking is needed just go to a service and seek for curtain QSO.
    I don`t see any other way to do.
  2. #272
    03.02.2006
    20,753
    10225
    5491
    When I select sinchronize download log and chose the file that will be /LOGHX/IK2XDE/DOWNLOAD directory....
    and pres GO.....whean I press GO ......everything crashes, even windows ... and I'm forced to restart the pc.
    Send mу adif-file with which problem with synchronization. I'll test it.
  3. #273
    03.01.2021
    196
    18
    In these years I have tried several logs, I think that an interesting function when we synchronize the log with eqsl,
    is to download the images of the qsl and save them linked to the qso.
    It would be useful to download the eqsl images and save them in the photo field of each qso.
    Thanks for attention
    73 de IK2XDE Andrea.
  4. #274
    03.02.2006
    20,753
    10225
    5491
    need date and time filter (FROM DATE <TO> DATE) and (FROM DATE and TIME <TO> DATE and TIME)
    Done:
    https://forum.qrz.ru/355-loghx-appar...ml#post1787835
  5. #275
    03.02.2006
    20,753
    10225
    5491
    Problem with LOTW and EQSL and clublog synchronize.
    Yes! I'm fix this problem!
    Prerelease 629:
    https://forum.qrz.ru/355-loghx-appar...ml#post1787917
  6. #276
    03.01.2021
    196
    18
    Prerelease 629:
    Sorry, but nothing change for me.
    Running buil 629 - (Windows 10pro - I7 9700k - 32GbRam)
    Starting log /D=IK2XDE
    When I try to synchronize LOTW download log, windows freeze.
    I just send you my log and adif file, try LOTW and also EQSL same problem.
    If I run log in normal mode (NO /D=IK2XDE) all work fine....!!!
    - OTHER QUESTION
    Using "QSO MANUAL ENTRY" it does not take data from qrz.com
    Using "QSO MANUAL ENTRY" the "Printqueue" field is missing (please add it)
    Thanks for your continued efforts to improve the software
    73 de IK2XDE Andrea
  7. #277
    03.01.2021
    196
    18
    To be more precise, the search on qrz.com does not work correctly,
    it is the third possibility, even if in the setup I have activated only one choice.
    I have only configured the search on QRZ.COM
    But first look on QRZ.RU ........ and get error.
    then it looks for HAM.QTH and gets an error
    Only as a last resort (3) search on QRZ.COM and enter the data correctly.
    73 de IK2XDE Andrea
  8. #278
    03.02.2006
    20,753
    10225
    5491
    QRZ.RU
    QRZ.RU window open or checked this menu:
    Same for HamQTH.
    Done - prerelease 630
    https://forum.qrz.ru/355-loghx-appar...ml#post1399067
    And check again
    Now is ok or not?
  9. #279
    03.01.2021
    196
    18
    Now is ok or not?
    OK.......Printqueue in the "QSO MANUAL ENTRY" windows work well......thanks...!!
    Problem with search info on qrz.com....in "QSO MANUAL ENTRY" was that if i press button
    on the right of the call, search start in all of three callbook QRZ.RU -> HAMQTH -> and finaly QRZ.COM
    with error result....of course....because was not configured....
    But If I select only QRZ.COM......should only search on qrz.com
    Unfortunately synchronize with lotw and eqsl still doesn't work.
    As soon as I press GO windows freezes.
    Please note that only if I start /D=IK2XDE
    If I start in normal mode, all work whit no problem.
    Thanks.
    73 de IK2XDE Andrea
    Another observation, although having entered the fields in setup, RTX, ANTENNA and POWER
    are not copied in the QSO entry window.
  10. #280
    03.02.2006
    20,753
    10225
    5491
    For QSOManuallyEntry set search servers here:
    It's very strange. Whan is on screen, when log is freezes?
  11. #281
    03.01.2021
    196
    18
    OK THANKS....!!
    I send you a video via mail
  12. #282
    03.02.2006
    20,753
    10225
    5491
    Thank you very much for video!
    About problem: do you run log as Administrator? Do you set Administrator rights for log icon (for /D=IK2XDE) ?
  13. #283
    03.01.2021
    196
    18
    Yes....I run as administrator......!!
  14. #284
    03.02.2006
    20,753
    10225
    5491
    Hm... It's mystery for me
    I'm check with you log/setup - not problem. Something block work of log.
  15. #285
    03.01.2021
    196
    18
    Well, after countless tests looking for the solution, I found what is blocking windows.
    "SHOW NEW COUNTRY"
    if I select this function everything stops as soon as I press "GO",
    if I don't select this function, everything works correctly.
    I have successfully syncronized over 100,000 qsos on lotw and eqsl with no problems.
    So the problem is "SHOW NEW COUNTRY" in the syncronize windows.
    In the clublog when we upload our log ..... please add the choice
    MERGE into EXISTING LOG.....or......CLEAR LOG before UPDATE (CLEAR OPTION)
    For all online log, LOTW, EQSL, CLUGLOG,
    please add the choice for UPLOAD
    CREATE FILE TO SEND MANUALLY via web interface.
    (Create file but not send automatically via LogHX)
    Thanks in advance.
    This function in my opinion i very important,
    very often we have problems with the internet line, with the server busy,
    especially during the weekends and after the contests.
    It is therefore very useful to be able to create the log to be sent,
    and then send it later, via the web and not automatically.
    Oppure per esempio io preferisco usare per LOTW il software TQSL separatamente.
    Grazie per l'attenzione.
  1. LogHX: Актуальные релизы и история изменений.
    Ответов: 971
    Последнее сообщение: 08.01.2026, 00:04
  2. DIY UW3DI (for English OPs)
    от UU2JET в разделе КВ: UW3DI
    Последнее сообщение: 18.01.2013, 12:04
  3. KENWOOD TS-2000 (Black Version)
    от UA3IRS в разделе TS-2000
    Последнее сообщение: 16.11.2009, 20:16
  4. Navitel 2.0 Pocket PC Version
    от RX3AOE в разделе APRS
    Последнее сообщение: 26.09.2006, 03:39
  5. windows 64 bit version не ставится
    от UR4LZW в разделе Программное обеспечение
    Последнее сообщение: 12.09.2005, 23:58
