06.11.2022, 13:40 #556Координатор темы
- 03.02.2006
- 53
- 20,616
- 10148
- 5452
Ant.: UW4HW, Pwr.: ~500 Wtts
26.11.2022, 21:36 #557Low Power
- 16.04.2020
- 89
I am looking at putting my World Castles Awards in the log, esp the English castle awards.
I've got the basic reference numbers, I wonder if its possible to get the actual name in there also?
Also for 1 QSO where they have multiple references, how can we get the log to recognise this? I have given User7 to WCA references in my log, it reads great for only one reference, but for multi refs it doesn't, could it be read by comma seperated values?
26.11.2022, 21:46 #558Координатор темы
- 03.02.2006
- 53
- 20,616
- 10148
- 5452
26.11.2022, 22:18 #559Low Power
- 16.04.2020
- 89
Thanks Alexei for the quick reply. Yes I am going through all my logs just tieing up the references from the e-log on the castles site and correcting the G. I haven't really looked at using the awards properly yet. My next target is getting FLdigi and CW set up properly as I am getting back into CW and want to try PSK31 again.
Spelling update under "Utilites" should be "Utilities" and then "Advancent Search" should be "Advanced Search"
"Non Standart callsign" should be "Non Standard Callsign"
09.12.2022, 14:43 #560Standart Power
- 03.01.2021
- 196
- 18
Hi Alexey, as always thanks for your constant work to update the log.
Unfortunately with version 708 and 709 we lost the automatic sending of QSOs on clublog.
Back to 707 everything works fine, I also tested other logs and there doesn't seem to be a problem from clublog,
so the problem seems to be LogHX with automatic clublog disabled.
(in fact in the general setup the checkbox for automatic sending has disappeared).... is it a mistake.....?
Is there some reason unknown to us...??
It's a shame was one of the great features of this log.
Thanks for answer.
73 de IK2XDE AndreaIK2XDE Andrea - WWLoc. JN45MQ
https://www.xdenews.net/ik2xde/logonline/
RADIO Setup (update 30/08/2025)
ICOM IC-7600 - (HF - 50MHz.)
SunSDR2DX - (HF - 50MHz. - 144 MHz.)
OM Power - OM2000A+ (1.8-50 MHz. Amplifier)
OB11-3 (11 element - 3 band - 10m-15m-20m)
OB9-3 WARC (9 element - 3 band - 12m-17m-30m)
SkyWire Loop (40-60-80-160 m.)
LogHX Managers Database (update for free)
https://www.xdenews.net/managers/
09.12.2022, 18:43 #561Координатор темы
- 03.02.2006
- 53
- 20,616
- 10148
- 5452
13.12.2022, 00:30 #562Low Power
- 02.05.2021
- 53
- 6
[QUOTE=F8GHE;1912424]After a good night everything is working
(Check setup and Restart DXLOG and LogHX)
Thanks very much and have a nice sunday !
73s Christian F8GHE
Hi, here i a very simple Howto to connect LogHX to DXLog.
ATTACH=CONFIG]332573[/ATTACH]
Вложение 332571
73s Christian F8GHE
- - - Updated - - -
[QUOTE=F8GHE;1920566]With the correct file
Последний раз редактировалось F8GHE; 13.12.2022 в 00:23.
15.12.2022, 12:51 #563Low Power
- 02.05.2021
- 53
- 6
15.12.2022, 20:45 #564Standart Power
- 03.01.2021
- 196
- 18
I'm sorry I can't help you, but I couldn't find any news about it.
Sending real time QSOs was essential for the proper functioning of live streams
whose instructions can be found here: https://clublog.freshdesk.com/suppor...g-live-streams
In fact if you continue to use the 707 version everything works correctly, without errors like other logs,
I don't receive errors and reports from clublog.
I don't see why LogHX should disable this feature when all other logs use it without any problem.
Try to enable real time automatic sending again, and see if the clublog authors report the bug or the problem.
Thank you.IK2XDE Andrea - WWLoc. JN45MQ
29.12.2022, 19:46 #565Low Power
- 02.05.2021
- 53
- 6
Hi, I also regret this feature
With the last Prerelease version 712 is the "Automatic send" to ClubLog OK like with the previous release version 707 ?
73s Christian F8GHE
- - - Updated - - -
It seems that LogHx is not in this list of softwares that support QSOs upload in realtime to ClubLog:
https://clublog.freshdesk.com/suppor...ltime-uploads-
from this page https://clublog.freshdesk.com/suppor...g-live-streams
Maybe could be add ?
73s Christian F8GHE
31.12.2022, 13:01 #566Standart Power
- 03.01.2021
- 196
- 18
Unfortunately even with version 714, automatic upload is disabled.
I hope Alexey will quickly fix this important function.
Many other software works fine...how did they fix it...?
Let's try to contact the clublog manager to verify the problem..??
Alexey thank you in advance for the time you will spend on this.
Thanks.
31.12.2022, 13:18 #567Координатор темы
- 03.02.2006
- 53
- 20,616
- 10148
- 5452
LogHX don't use Club Log Live Stream uploads. Like here -
But log can use this URL to upload QSO in realtime:
https://clublog.freshdesk.com/suppor...-into-club-log
Ok! I restore realtime uploads.
... Done -
http://rx4hx.qrz.ru/files/loghx/prer..._build_714.exe73 de RX4HX, Alexei, http://rx4hx.qrz.ru
31.12.2022, 19:14 #568Low Power
- 02.05.2021
- 53
- 6
01.01.2023, 16:57 #569Low Power
- 16.04.2020
- 89
Happy New Year all!
Looking for advice from you users on the CW set up in LogHx.
At the moment, I have only used for normal logging and with WSJTX, I have different views to suit each.
I did have it working a long time ago with PSK31 but my set up has changed and I am still trying to get it to work, I think its an FLDigi issue.
My main question is using CW windows for Morse code. I am getting back into CW so both my sending and recieving are slow! So I am looking at creating a view to decode CW and maybe have the keyer enabled but I really plan to use my paddle again. Is there a good set up for CW that anyone can share that I could try?
Thanks!
01.01.2023, 19:08 #570QRP
- 26.10.2019
- 46
- 17
- 9
Report on version 3.0 build from 708 to 715
Hello, Dear Alexei - RX4HX
Best wishes for a Happy New Year to you and all group members.
Report on version 3.0 build from 708 to 715 (on previous builds including 707 was normal).
Randomly when I try to edit a QSO, the PC crashes, to restart it you have to turn off the power.
I use Windows 7 Ultimate Service Pack 1, Intel i7-3770 CPU @ 3.40GHz, 64Bits.
73 and Happy New Year for all, from py5ej;
Pavanatti.
167Спасибо
