10.06.2022, 12:35 #451Координатор темы
- 03.02.2006
- 53
- 20,753
- 10225
- 5491
Try new prerelease
https://forum.qrz.ru/355-loghx-appar...ml#post1886596
and look list selected hosts. I think several hosts have been selected.73 de RX4HX, Alexei, http://rx4hx.qrz.ru
Ant.: UW4HW, Pwr.: ~500 Wtts
10.06.2022, 13:03 #452Low Power
- 19.11.2019
- Nyirabrany
- 11
- 43
Running b690 but nothing changed.
Same situations.
Checked only one in telnet2 and telnet3 as you see on the photos.
.... and I repeat again : Telnet3 is using Telnet2 setup, NOT the Telnet3/localhost setup!
If I go to "Cluster" window and choose "Telnet3", I see Hamalert's setup as I sent photos about it in my last message.
10.06.2022, 13:26 #453
10.06.2022, 21:03 #454Координатор темы
- 03.02.2006
- 53
- 20,753
- 10225
- 5491
11.06.2022, 00:23 #455Standart Power
- 03.01.2021
- 196
- 18
With vers. 690 and 691 crash on start,
NOT FOUND any STYLES in setup. (only Windows...NOT others)
73 de IK2XDE Andrea.IK2XDE Andrea - WWLoc. JN45MQ
https://www.xdenews.net/ik2xde/logonline/
RADIO Setup (update 30/08/2025)
ICOM IC-7600 - (HF - 50MHz.)
SunSDR2DX - (HF - 50MHz. - 144 MHz.)
OM Power - OM2000A+ (1.8-50 MHz. Amplifier)
OB11-3 (11 element - 3 band - 10m-15m-20m)
OB9-3 WARC (9 element - 3 band - 12m-17m-30m)
SkyWire Loop (40-60-80-160 m.)
LogHX Managers Database (update for free)
https://www.xdenews.net/managers/
11.06.2022, 08:01 #456Координатор темы
- 03.02.2006
- 53
- 20,753
- 10225
- 5491
11.06.2022, 08:32 #457Low Power
- 19.11.2019
- Nyirabrany
- 11
- 43
Alexei,
b691: Telnet2 window is totally empty, Telnet1, Telnet3 are OK.
b688: Telnet1, Telnet2, Localhost are perfect.
11.06.2022, 15:31 #458Low Power
- 02.05.2021
- 53
- 6
Yes, I confirm an issue with the skin colors.
Not possible to save a modified default blue color (C6DDE7) in the "Log Windows" or "Previous QSO" with the Grid Color setup .
73s Christian F8GHE
- - - Updated - - -
No problems with build 686 that I just test !
73s Christian F8GHE
14.06.2022, 11:14 #459Координатор темы
- 03.02.2006
- 53
- 20,753
- 10225
- 5491
Fixed - reload this version:
http://rx4hx.qrz.ru/files/loghx/prer..._build_691.exe73 de RX4HX, Alexei, http://rx4hx.qrz.ru
14.06.2022, 12:57 #460Low Power
- 19.11.2019
- Nyirabrany
- 11
- 43
Alexei,
Can you put a "COPY" button in the "QSO manually entry/edit" window, which is copy ALL details of the original window?
It would be very useful when there are more than one RDA. It would be copied all to a new window and needed just overwrite the State/Country fileds.
Thank you in advance, 73 Egon
14.06.2022, 16:00 #461Low Power
- 19.11.2019
- Nyirabrany
- 11
- 43
Alexei,
Just inform you about b692 : Telnet1, Telnet3 are OK. Telnet2 still only a empty window.
Is there any info source about updating? What did you updated in prerelease version?
I know the Whatnews.txt but there is nothing any about prerelease(s).
Thank you!
14.06.2022, 16:20 #462Координатор темы
- 03.02.2006
- 53
- 20,753
- 10225
- 5491
15.06.2022, 00:21 #463Low Power
- 02.05.2021
- 53
- 6
Hello,
With the last buid 692
- issue with styles list corrected
- but issue with Grid colors not solved : The default grid color on "Log Windows" and "Previous QSO windows" modified automatically from white to blue color (C6DDE7) after update from build 686 to 692. And it is not possible to change this default bue color.
73s Christian F8GHE
15.06.2022, 17:12 #464Low Power
- 19.11.2019
- Nyirabrany
- 11
- 43
Alexei,
Installed 692 again. I did a lot of research and figured out what was causing the problem at me in the Telnet2 window.
If something is in TelnetScripts2 (TelnetScripts2.hx), than Telnet2 window does not work.
I tried with a few server from Server#2's list and with EMPTY Scripts#2 all servers are working,
including HamAlert (hamalert.prg / 7300) which I inserted in the LogHX/Setup Machine window.
If I inserting just only ONE line (or TWO) into Scripts#2 (like login: and my call), Telnet2 window does NOTHING.
Pushing (Connect) Telnet2 button, nothing happen.
I tried to replace TelnetScrips2.hx from a older backup (b688 and older) but nothing...
I gave up...
Sincerely, Egon
PS: Telnet1, Telnet3 are fine.
I have no more time now but soonly I will try to change Telnet3 <-> Telnet2 details. Maybe...
15.06.2022, 19:42 #465Low Power
- 19.11.2019
- Nyirabrany
- 11
- 43
Alexei,
b692:
I just finished the investigation with interesting results.
I put "hamalert.org/7300" setup to Telnet1,2,3.
Of course, during the test I checked the tested Telnet, unchecked the other two.
- Telnet1 is 100% OK, working fine with Scripts1 (two lines are in it, login: and password: )
- Telnet2 is not working IF there is something in Sricpt2
- Telnet3 is the same as Telnet2
I tried dx.hu/9000 server in Telnet1, 2, 3 with one line in the scripts1, 2, 3.
All OK!
No idea...
- - - Updated - - -
UPDATE:
Ignore the following two lines above :
"I tried dx.hu/9000 server in Telnet1, 2, 3 with one line in the scripts1, 2, 3.
All OK!
Sorry but it is not true!
167Спасибо
