26.10.2022, 08:17 #541Координатор темы
- 03.02.2006
- 53
- 20,753
- 10225
- 5491
Search in Google: fldigi xml-rpc
Example:
Fldigi Users Manual: Xmlrpc Control73 de RX4HX, Alexei, http://rx4hx.qrz.ru
Ant.: UW4HW, Pwr.: ~500 Wtts
26.10.2022, 11:34 #542Low Power
- 02.05.2021
- 53
- 6
26.10.2022, 20:01 #543Low Power
- 02.05.2021
- 53
- 6
Is it possible to listen an UDP broadcast with LogHX (For example QSOs broadcasted by DXLOG on the UDP port 12060 of the localhost) ?
I think that it should be possible with the Spot-machine but I'm not able to configure it
73s Christian F8GHE
28.10.2022, 20:55 #544Координатор темы
- 03.02.2006
- 53
- 20,753
- 10225
- 5491
29.10.2022, 20:06 #545Low Power
- 02.05.2021
- 53
- 6
I would like to know if it is possible to connect LogHX to the UDP Broadcast QSOs or SPOTs Output from DXLOG ?
DXLOG is able to Broadcast QSO or SPOTs to UDP. It is possible to select N1MM format for QSO.
I was able to connect this UDP output to Log4OM with the Inbound Communicator of Log4OM and I would like to do the same with LogHX.
30.10.2022, 19:04 #546Координатор темы
- 03.02.2006
- 53
- 20,753
- 10225
- 5491
01.11.2022, 17:00 #547Low Power
- 02.05.2021
- 53
- 6
03.11.2022, 15:54 #548Low Power
- 02.05.2021
- 53
- 6
After setup DXLOG.NET for Broadcasting, it works with Log4OM but not with LogHX.
Maybe my LogHX setup is not correct ? I checked on TAB Broadcast data /Received (N1MM format) / Radio, Contact and Spots on port 12060 (Same as on your ScreenShot)
And now when I close LogHX, I received this UDP error message.
03.11.2022, 18:46 #549Координатор темы
- 03.02.2006
- 53
- 20,753
- 10225
- 5491
04.11.2022, 15:28 #550Low Power
- 02.05.2021
- 53
- 6
05.11.2022, 14:59 #551Low Power
- 02.05.2021
- 53
- 6
05.11.2022, 17:26 #552Координатор темы
- 03.02.2006
- 53
- 20,753
- 10225
- 5491
Hello Christian!
Thank you so much for the very detailed information! I found the error and corrected it. Try this test version -
... deleted!
Re-setup ports for Broadcast!
Update: new release
https://forum.qrz.ru/355-loghx-appar...ml#post1912284Последний раз редактировалось RX4HX; 05.11.2022 в 22:31.
06.11.2022, 00:14 #553Low Power
- 02.05.2021
- 53
- 6
Alexei, the pleasure is mine. I really like LogHX and it's me who thanks you for all your work and the time spent for LogHX.
I'm sorry but it seems the same for me with the new build_707 except the disappearance of the UDP error
After re-setup of UDP port 13063
=> Everything is OK with Radio (Same on previous version 706)
=> But Contacts and Spots from DXLOG not seen on LogHX (Same on previous version 706)
Please confirm that Contacts or Spots could be seen in the QSO-Entry window ?
73s Christian F8GHE
06.11.2022, 00:57 #554Координатор темы
- 03.02.2006
- 53
- 20,753
- 10225
- 5491
Setup of DXLOG and LogHX right? Look at print screen:
Now use one port for radio, spots and contacts!73 de RX4HX, Alexei, http://rx4hx.qrz.ru
06.11.2022, 13:29 #555Low Power
- 02.05.2021
- 53
- 6
167Спасибо
