Страница 42 из 68 ПерваяПервая ... 3235363738394041424344454647484952 ... ПоследняяПоследняя
Показано с 616 по 630 из 1017
Like Tree167Спасибо
Тема: LogHX: English version
  1. #616
    03.02.2006
    20,753
    10225
    5491
    Цитата Сообщение от IK2XDE Посмотреть сообщение
    clicking on ok, presents general setup, where my call is already inserted.
    Yes, it's wrong! I'll check this!
  2. #617
    03.02.2006
    20,753
    10225
    5491
    Цитата Сообщение от Josef OK2WO Посмотреть сообщение
    CW works OK, but after keying up MHz are missing:
    Hello Josef!
    What to do:
    - run only LogHX and select as CAT - CatHX. Setup CAT for you Trx. Set "PTT via CAT"
    - Menu Setup->Test CAT window.
    - CW window -> press RX/TX button for TX, wait 3 sec and press RX/TX button for RX.
    - close Test CAT window. When window coluses, will be created txt-file with command from TRX.
    Save this file and sen to me. Tnx!
  3. #618
    15.04.2021
    80
    12
    3
    All are arranged by you, but the TX switch on CW windows works for a very short time only. I tried the TUNE switch ON / 3 sec / OFF, file is here: IC-7100.txt
  4. #619
    Low Power
    02.05.2021
    6
    Цитата Сообщение от F8GHE Посмотреть сообщение
    Is it possible to create an Hotkey to "stop" the rotator rotation ?
    Not problem! I'll do it!
    How about Ctrl+ESC for stop rotation?
    Hi Alexei, Do you plan to add this Hotkey Ctrl+ESC (or Ctrl+Alt+ESC) in your next build720 ?
    (I would like to validate it with the EA4TX ARS-USB of my old friend because for his simplification I prefer not to installed PstRotator for him. With one less software, it will be easier for him )
    73s Christian F8GHE
  5. #620
    03.02.2006
    20,753
    10225
    5491
    Unckeck here -
    But now it 's enough -
    all is Ok!
    Question - when you Trx set to TX, LogHX show freq from Trx?
    Yes, everything is ready for this.
  6. #621
    15.04.2021
    80
    12
    3
    New file here with RX/TX working ((renamed to .txt):TotalTestCATFile.txt
    Frequency indicator is OK if TX (all digits).
    73 Josef
  7. #622
    03.02.2006
    20,753
    10225
    5491
    I found problem - please, test this version:
    http://rx4hx.qrz.ru/files/loghx/test..._build_720.exe
  8. #623
    15.04.2021
    80
    12
    3
    The build tested - CW via hamlib works OK. There are some limitations (IC-7100 specific):
    - it can send up to 29 chars only (incl. spaces)
    - speed and CW chars settings must be controlled in radio
    AutoCQ in LogHX works OK.
    Anyway, the best solution for IC-7100 CW is to use the additional USB port with USB/RS232 convertor.
    Thank you Alex for your perfect work. 73 GL Josef
  9. #624
    Low Power
    02.05.2021
    6
    Howto to setup LogHX with a rotor controler EA4TX ARS-USB w and wo PstRotatorAZ
    Hi,
    Here is a small Howto to setup LogHX with a rotor controler ARS-USB from EA4TX with and without PstRotatorAz. It wrote in French but if you think that coukd be usefull for community, I can translate it in English.
    73s Christian F8GHE
    Вложения Вложения
  10. #625
    Low Power
    02.05.2021
    6
    Howto change the font size of the "setup menu", the icons and clock size ?
    Hello,
    I just installed LogHX 7.19 on a new PC with Win11 and I'm not able to modify the font size of the "setup menu", the icons and the clock size. My font size is so small, that I can't read menu After multiples tests, I don't know if it is a Window11 or a LogHX parameter.
    Who can help me ?
    73s Christian F8GHE
  11. #626
    03.02.2006
    20,753
    10225
    5491
    For change clock size - replace files in folder Skins\Default\0.jpg...9.jpg and R.jpg to another. You can find these files on the internet.
    The rest cannot be changed yet.
  12. #627
    Low Power
    02.05.2021
    6
    Thanks very much Alexei.
    Ok for the clock size and about the unchangeable font size of the "General Setup" menu but here are some remarks about it:
    • I never met this type of tiny font size with Win7 or Win10 and my friend F1DJY who use Win11 doesn't meet this type of problem.
    • When I try to change the default font size of Win11, the font size of the "Genral Setup" menu always stays the same.
    Questions:
    • Is it the default font size of Win11 that used for this menu of LogHX or is it a setting in an .ini file?
    • May be, I have to reset and create new .ini files ?
    73s Christian F8GHE
  13. #628
    03.02.2006
    20,753
    10225
    5491
    I'm not sure, but I think promblem with skin. Try disable skin and change default Win font. Log not save fonts for Setup window.
  14. #629
    03.01.2021
    196
    18
    Hello,
    I find this little problem,
    all CW spot from skimmer EA8/DF4UE-#
    carry a letter C in the bandmap
    I think it is due to the very long call.
    If possible, check the alignment correction
    Thanks for your work
    73 de IK2XDE Andrea
    IK2XDE Andrea - WWLoc. JN45MQ
    https://www.xdenews.net/ik2xde/logonline/
    RADIO Setup (update 30/08/2025)
    ICOM IC-7600 - (HF - 50MHz.)
    SunSDR2DX - (HF - 50MHz. - 144 MHz.)
    OM Power - OM2000A+ (1.8-50 MHz. Amplifier)
    OB11-3 (11 element - 3 band - 10m-15m-20m)
    OB9-3 WARC (9 element - 3 band - 12m-17m-30m)
    SkyWire Loop (40-60-80-160 m.)
    LogHX Managers Database (update for free)
    https://www.xdenews.net/managers/
  15. #630
    03.02.2006
    20,753
    10225
    5491
    Fixed in new release!
  1. LogHX: Актуальные релизы и история изменений.
    Ответов: 971
    Последнее сообщение: 08.01.2026, 00:04
  2. DIY UW3DI (for English OPs)
    от UU2JET в разделе КВ: UW3DI
    Последнее сообщение: 18.01.2013, 12:04
  3. KENWOOD TS-2000 (Black Version)
    от UA3IRS в разделе TS-2000
    Последнее сообщение: 16.11.2009, 20:16
  4. Navitel 2.0 Pocket PC Version
    от RX3AOE в разделе APRS
    Последнее сообщение: 26.09.2006, 03:39
  5. windows 64 bit version не ставится
    от UR4LZW в разделе Программное обеспечение
    Последнее сообщение: 12.09.2005, 23:58
