Страница 37 из 68 ПерваяПервая ... 2730313233343536373839404142434447 ... ПоследняяПоследняя
Показано с 541 по 555 из 1015
Like Tree167Спасибо
Тема: LogHX: English version
  1. #541
    03.02.2006
    20,463
    10078
    5415
    Цитата Сообщение от F8GHE Посмотреть сообщение
    Who can explain to me how FLDIGI communicates with LogHX?
    Search in Google: fldigi xml-rpc
    Example:
    Fldigi Users Manual: Xmlrpc Control
  2. #542
    Low Power
    02.05.2021
    6
    Example:
    Thanks very much, That's what I was looking for
  3. #543
    Low Power
    02.05.2021
    6
    Is it possible to listen an UDP broadcast with LogHX (For example QSOs broadcasted by DXLOG on the UDP port 12060 of the localhost) ?
    I think that it should be possible with the Spot-machine but I'm not able to configure it
    73s Christian F8GHE
  4. #544
    03.02.2006
    20,463
    10078
    5415
    What do you want to get? LogHX+JTDX+DXLOG?
  5. #545
    Low Power
    02.05.2021
    6
    I would like to know if it is possible to connect LogHX to the UDP Broadcast QSOs or SPOTs Output from DXLOG ?
    DXLOG is able to Broadcast QSO or SPOTs to UDP. It is possible to select N1MM format for QSO.
    I was able to connect this UDP output to Log4OM with the Inbound Communicator of Log4OM and I would like to do the same with LogHX.
  6. #546
    03.02.2006
    20,463
    10078
    5415
    It's here:
  7. #547
    Low Power
    02.05.2021
    6
    It's here:
    Alexei, Thanks very much for the reply but after where I can found received data to be able to use them with LogHX ?
    • Radio, Contact and Spots at NIMM Format
    • Contact at ADIF Format
    7"s Christian F8GHE
  8. #548
    Low Power
    02.05.2021
    6
    73"s Christian F8GHE
    After setup DXLOG.NET for Broadcasting, it works with Log4OM but not with LogHX.
    Maybe my LogHX setup is not correct ? I checked on TAB Broadcast data /Received (N1MM format) / Radio, Contact and Spots on port 12060 (Same as on your ScreenShot)
    And now when I close LogHX, I received this UDP error message.
    Название: udp error.JPG
  9. #549
    03.02.2006
    20,463
    10078
    5415
    This is an unnecessary warning. It won't be in the new version.
    setup DXLOG.NET
    Please, print screen of Dxlog setup for broadcast.
    port 12060
    It's wrong. Use different ports for spot, radio, contacts.
  10. #550
    Low Power
    02.05.2021
    6
    Here are my setup for DXLOG and LogHX
Название:	2022-11-04 12_58_22-dxlog.jpg
Название:	2022-11-04 12_58_22-logHX.jpg
  11. #551
    Low Power
    02.05.2021
    6
    I progress very slowly like a cat
    Now my "radio UDP" setup between LogHX and DXLOG is working
    But spot and contacts need more investigation
    Here is the status of my UDP setup
    - Radio is OK
    - Contacts and Spot are KO
    Here are print screens of DXLOG and LogHX
    73s Christian F8GHE
  12. #552
    03.02.2006
    20,463
    10078
    5415
    Hello Christian!
    Thank you so much for the very detailed information! I found the error and corrected it. Try this test version -
    ... deleted!
    Re-setup ports for Broadcast!
    Update: new release
    https://forum.qrz.ru/355-loghx-appar...ml#post1912284
  13. #553
    Low Power
    02.05.2021
    6
    Hello Christian!
    ... deleted!
    Update: new release
    Alexei, the pleasure is mine. I really like LogHX and it's me who thanks you for all your work and the time spent for LogHX.
    I'm sorry but it seems the same for me with the new build_707 except the disappearance of the UDP error
    After re-setup of UDP port 13063
    => Everything is OK with Radio (Same on previous version 706)
    => But Contacts and Spots from DXLOG not seen on LogHX (Same on previous version 706)
    Please confirm that Contacts or Spots could be seen in the QSO-Entry window ?
    73s Christian F8GHE
  14. #554
    03.02.2006
    20,463
    10078
    5415
    Setup of DXLOG and LogHX right? Look at print screen:
    Now use one port for radio, spots and contacts!
  15. #555
    Low Power
    02.05.2021
    6
    After a good night everything is working
    (Check setup and Restart DXLOG and LogHX)
    Thanks very much and have a nice sunday !
    73s Christian F8GHE
Название:	2022-11-06 11_21_42-Loghx-DXLOG-ok].jpg
  1. LogHX: Актуальные релизы и история изменений.
    Ответов: 971
    Последнее сообщение: 08.01.2026, 00:04
  2. DIY UW3DI (for English OPs)
    от UU2JET в разделе КВ: UW3DI
    Последнее сообщение: 18.01.2013, 12:04
  3. KENWOOD TS-2000 (Black Version)
    от UA3IRS в разделе TS-2000
    Последнее сообщение: 16.11.2009, 20:16
  4. Navitel 2.0 Pocket PC Version
    от RX3AOE в разделе APRS
    Последнее сообщение: 26.09.2006, 03:39
  5. windows 64 bit version не ставится
    от UR4LZW в разделе Программное обеспечение
    Последнее сообщение: 12.09.2005, 23:58
