Страница 11 из 68 ПерваяПервая ... 4567891011121314151617182161 ... ПоследняяПоследняя
Показано с 151 по 165 из 1017
Like Tree167Спасибо
Тема: LogHX: English version
  1. #151
    QRPP
    22.12.2020
    Hi Alexei
    I tried as you suggested regarding translating the User2 -> SOTA_REF for ADIF export but I can't get this to work. When I examine the ADIF export in ADIF Master the User1/User2 and User3 fields are populated, the transformation of User fields via the ADIF Setup page doesn't work for me. Maybe there is something else I should be doing.
    I am exporting using the menu item File -> Export -> ADIF Format
    Many thanks, Mark M0NOM
  2. #152
    03.02.2006
    20,753
    10225
    5491
    Цитата Сообщение от Alde Посмотреть сообщение
    look for LU#(Sulfix XP-XZ) Tierra del Fuego the state is TF (not FT).
    Fixed!
    What version of log do you use? May be problem here - use this version:
    http://rx4hx.qrz.ru/files/loghx/prer..._build_604.exe
    Цитата Сообщение от M0CGF Посмотреть сообщение
    For Flora Fauna is it possible to match the reference exactly like on the wwff website, For example DLFF-0093 instead of DFFF-093?
    Yes, you can itself correct WFF award.
    But you must remember: DLFF-0093 is not equal DL-093! Set for QSO field WFF as in award format!
  3. #153
    QRPP
    22.12.2020
    Hi Alexei
    Yes, the 604 version works correctly, thank you, and seasons greetings.
    Regards, Mark. M0NOM
  4. #154
    03.01.2021
    196
    18
    Good evening everyone.
    I found this problem in the "New qso Entry" window.
    If I enter RX4HX, it correctly goes to read the fields on QRZ.COM (so I configured it), and then automatically inserts them in the registration window of the qso.
    But if I enter RX4HX/p or RX4HX/m it does not read any data on QRZ.COM.
    In this case it should read only the full name field (FName + Name) and the e-mail field, leaving the QTH, State, County, and WWLoc field blank
    because being in portable or mobile I will have to enter other data (other place) provided by the correspondent.
    I hope I was clear in the explanation.
    Thanks for the attention
    73 de IK2XDE Andrea.
    Good evening,
    sorry, I've been using LogHX (v3.0 build 604) for a few days,
    the management of the awards not clear to me.
    In the process of entering a qso, where I can enter the reference of the desired award .. ??
    For example .... if I am in qso with DL8AAM, I would like to insert the appropriate DOK reference,
    but in the window "qso entry" there is only the possibility to choose the IOTA (drop-down menu)
    and WFF .... which seem does not work, there is no reference....no drop-down menu.
    Thanks for the attention.
  5. #155
    03.02.2006
    20,753
    10225
    5491
    It's sets here -
    Now info will be search only for RX4HX.
  6. #156
    03.01.2021
    196
    18
    ok works, but the command works in reverse.
    Thanks.
  7. #157
    03.02.2006
    20,753
    10225
    5491
    All Ok:
    Not found without - Название: 1.png
    Now found - Название: 2.png
  8. #158
    03.01.2021
    196
    18
    Good evening,
    but in the window "qso entry" there is only the possibility to choose the IOTA (drop-down menu...ok)
    For the other award.....where I put the reference....??
  9. #159
    03.02.2006
    20,753
    10225
    5491
    qso entry
    You can setup QSOEntry window as you like - look here:
    https://forum.qrz.ru/355-loghx-appar...ml#post1688916
    you can set count visible fields and set fields name.
  10. #160
    03.01.2021
    196
    18
    OK, but that's not my problem.
    I have already put 10 lines and all fields.
    The problem is that the IOTA field offers the drop-down menu with references
    the WFF field does not offer any drop-down menus and no references.
    And then if I wanted to put another award type RDA how do I put it .. ??
    Thanks.
  11. #161
    03.01.2021
    196
    18
    In the right part of the "qso entry" window I have activated the buttons,
    how can I do to activate only some and not all ..?
    I would like to use only the "find" button.
    Among other things, I suggest separating the information
    FIND CALL: QRZ.COM - QRZ.RU - HAMQTH - Clublog - EQSL
    FIND MANAGERS: IK3QAR Site - QSLInfo.de - Local File Manager
    FIND OTHER INFO: 425DXN - DXSUMMIT
    So three different buttons for the three choices
    Thanks.
    73 de IK2XDE Andrea
  12. #162
    26.10.2019
    46
    17
    9
    FT4 (qsl confirmation), from LoTW and eQS
    Hello,
    LogHX users.
    How to configure logHX, v.3.0 build 606, to obtain FT4 (qsl confirmation), from LoTW (R) and eQSL (R).
    For MODE: FT8, the LoTW, eQSL and ClubLog work well, and the LoTW (R), eQSL (R) and Clublog (R) fields, in to LogHX are correctly confirms;
    However, for MODE: MFSK, SUBMODE: FT4, only Clublog can confirm the Clublog (R) field as OK.
    From file download:
    ClubLog dl: ... <MODE:3>FT4 ... > the Clublog(R) field confirms, as OK;
    <MODE:3>FT8 ... > the Clublog(R) field confirms, as OK;
    eQSL dl: ... <MODE:3>FT8 ... > the eQSL(R) field confirms, as OK;
    <MODE:4>MFSK<SUBMODE:3>FT4 ... > the field eQSL(R), NOT confirms;
    LoTW dl: ... <MODE:3>FT8 ... > the LoTW(R) field confirms, as OK;
    <MODE:4>MFSK <SUBMODE:3>FT4 ... > the field LoTW(R) NOT confirms.
    In the Setup LogHX , Mode Setup, I found the standard configurations as : Mode - FT4, ModeDXCC - DIGITAL, Report - (-10), and V as OK, SubMode - FT4, Mode - MFSK.
    Thanks for any help, to setup the LogHX, and get the FT4, LoTW and eQSL confirmations.
    Happy New Year!!
    "Stay safe"
    73 from py5ej,
    Pavanatti.
  13. #163
    03.01.2021
    196
    18
    Hello Alde,
    I donwload and receive confirm from EQSL and LOTW without problem.
    You must verify that you have qso correct in the log.
    You must have MODE MFSK and SUBMODE FT4
    Sure you will have MODE FT4 ....wrong....
  14. #164
    03.02.2006
    20,753
    10225
    5491
    About mode FT4:
    you can use two variants:
    - first, you use in log mode FT4, but import/export ADIF with this settings
    - second variant - in log use mode MFSK, submode FT4 with settings for external program (from WSJTX/JTDX log get mode FT4)
    I'm use first variant. I think - it's simple.
  15. #165
    03.01.2021
    196
    18
    Good morning,
    in the calculation of the DXCC statistics, if I choose DXCC MODE,
    it only presents me the choice of CW - DIGITAL - PHONE
    the MIXED mode is missing.
    Hope it will be fixed in the next version.
    Thanks.
  1. LogHX: Актуальные релизы и история изменений.
    Ответов: 971
    Последнее сообщение: 08.01.2026, 00:04
  2. DIY UW3DI (for English OPs)
    от UU2JET в разделе КВ: UW3DI
    Последнее сообщение: 18.01.2013, 12:04
  3. KENWOOD TS-2000 (Black Version)
    от UA3IRS в разделе TS-2000
    Последнее сообщение: 16.11.2009, 20:16
  4. Navitel 2.0 Pocket PC Version
    от RX3AOE в разделе APRS
    Последнее сообщение: 26.09.2006, 03:39
  5. windows 64 bit version не ставится
    от UR4LZW в разделе Программное обеспечение
    Последнее сообщение: 12.09.2005, 23:58
