Страница 59 из 68 ПерваяПервая ... 949525354555657585960616263646566 ... ПоследняяПоследняя
Показано с 871 по 885 из 1017
Like Tree167Спасибо
Тема: LogHX: English version
  1. #871
    QRPP
    25.07.2024
    4
    Alexei,
    Not recognized any difference. 763 still smaller.
    73 Steve HA9PP
  2. #872
    03.02.2006
    20,753
    10225
    5491
    Strange! Here -
    older and new version - same font now!
    What skin do you use?
  3. #873
    QRPP
    05.01.2024
    41
    6
    Explain - where ??? In QSOEntry window?
    Pse printsrceen!
    Log from MSHV:
    Log window:
  4. #874
  5. #875
    07.07.2023
    16
    3
    3
    Still UDP Multicast working on this new version build 765?
  6. #876
    03.02.2006
    20,753
    10225
    5491
    Fixed problem with UDP Multicast -
    http://rx4hx.qrz.ru/files/loghx/LogH..._build_766.exe
  7. #877
    03.01.2021
    196
    18
    Hello,
    starting with version 765, and later 766 and 767, there are problems opening the local file managers.
    versions 763 and 764 work correctly.
    Thanks.
    73 de IK2XDE Andrea
    IK2XDE Andrea - WWLoc. JN45MQ
    https://www.xdenews.net/ik2xde/logonline/
    RADIO Setup (update 30/08/2025)
    ICOM IC-7600 - (HF - 50MHz.)
    SunSDR2DX - (HF - 50MHz. - 144 MHz.)
    OM Power - OM2000A+ (1.8-50 MHz. Amplifier)
    OB11-3 (11 element - 3 band - 10m-15m-20m)
    OB9-3 WARC (9 element - 3 band - 12m-17m-30m)
    SkyWire Loop (40-60-80-160 m.)
    LogHX Managers Database (update for free)
    https://www.xdenews.net/managers/
  8. #878
    03.02.2006
    20,753
    10225
    5491
    Fixed - try this:
    http://rx4hx.qrz.ru/files/loghx/test..._build_767.exe
  9. #879
    03.01.2021
    196
    18
    All work fine now.
    Thanks.
    73 de IK2XDE Andrea
  10. #880
    03.01.2021
    196
    18
    ICOM IC-7600
    With version 767 [ something changed in the management of the cat when transmitting in split.
    Now, even if I set FREQA, it always reads the frequency FREQB, the one where I transmit in split.
    Instead it should remain FRQA where I receive the dx station.
    V763 work fine with cat.
    Thanks for your attention
    73 de IK2XDE Andrea
  11. #881
    03.02.2006
    20,753
    10225
    5491
    FREQA
    Fixed, please test -
  12. #882
    03.01.2021
    196
    18
    NO SORRY....
    When I move the split vfo, the blue arrow does not track the split frequency
    Also FREQB does not track the split frequency.
    When I disable SPLIT (Split=False), the frequency (FreqB) is updated.
    73 de IK2XDE Andrea
  13. #883
    03.02.2006
    20,753
    10225
    5491
    If you select FREQA or FREQB - Название: 1.jpg
    you can not use second VFO for split mode.
  14. #884
    03.01.2021
    196
    18
    Hi Alexey,
    ICOM IC-7600 does not have two separate vfos.
    when in split mode,
    the VFOA (FreqA) is fixed on the receive frequency, (red arrow on the bandmap) (in the log as RX FREQ)
    the VFOB (FreqB) you move it to the desired transmit frequency.
    (blue arrow on the bandmap) (in the log as TX FREQ)
    Please check, until version 763 everything worked fine.
    73 de IK2XDE Andrea
  15. #885
    03.02.2006
    20,753
    10225
    5491
    ??? IC-7600 like others transceivers has 2 VFO - VFO-A and VFO-B.
    But I checked INI-files for IC-7600 - here is mistakes.
    What ini-file for 7600 do you use?
    IC-7600 or
    IC-7600v2-DATA or
    IC-7600v2?
  1. LogHX: Актуальные релизы и история изменений.
    Ответов: 971
    Последнее сообщение: 08.01.2026, 00:04
  2. DIY UW3DI (for English OPs)
    от UU2JET в разделе КВ: UW3DI
    Последнее сообщение: 18.01.2013, 12:04
  3. KENWOOD TS-2000 (Black Version)
    от UA3IRS в разделе TS-2000
    Последнее сообщение: 16.11.2009, 20:16
  4. Navitel 2.0 Pocket PC Version
    от RX3AOE в разделе APRS
    Последнее сообщение: 26.09.2006, 03:39
  5. windows 64 bit version не ставится
    от UR4LZW в разделе Программное обеспечение
    Последнее сообщение: 12.09.2005, 23:58
