Страница 58 из 68 ПерваяПервая ... 848515253545556575859606162636465 ... ПоследняяПоследняя
Показано с 856 по 870 из 1017
Like Tree167Спасибо
Тема: LogHX: English version
  1. #856
    03.02.2006
    20,753
    10225
    5491
    Цитата Сообщение от IK2XDE Посмотреть сообщение
    Problem with SSB Macros from LOGHX - do NOT send audio via TCI
    I remember that. But there is no way to do this yet.
    It would be nice if when I change the radio, the band maps would also change automatically,
    so if I am with radio 1 and switch to radio 2, it should automatically close band maps 1 and open band maps 2
    I agree, this is a necessary function. I will do it in the next release.
  2. #857
    03.01.2021
    196
    18
    Hi Alex, I understand that this is not easy to implement.
    The solution could be to bypass the problem,
    using "RADIO MACROS" supplied with Esdr3 v 1.0.8 and working perfectly.
    At this point, as for the bandmap 1 and 2,
    when you switch FROM radio1 (es. ICOM)
    to RADIO 2 SunSDR2 radio via TCI,
    "CW paddle windows" and "Voice windows" are automatically closed,
    and the external program "RADIO MACROS" opens.
    Perhaps it is useless to waste time implementing it,
    since the original RADIO MACROS program powered by Expert works perfectly.
    Thanks for your efforts
    73 de IK2XDE Andrea.
    IK2XDE Andrea - WWLoc. JN45MQ
    https://www.xdenews.net/ik2xde/logonline/
    RADIO Setup (update 30/08/2025)
    ICOM IC-7600 - (HF - 50MHz.)
    SunSDR2DX - (HF - 50MHz. - 144 MHz.)
    OM Power - OM2000A+ (1.8-50 MHz. Amplifier)
    OB11-3 (11 element - 3 band - 10m-15m-20m)
    OB9-3 WARC (9 element - 3 band - 12m-17m-30m)
    SkyWire Loop (40-60-80-160 m.)
    LogHX Managers Database (update for free)
    https://www.xdenews.net/managers/
  3. #858
    21.07.2022
    80
    20
    Awards Criteria - County vs. State
    I worry about adding awards where the first and only criterion is the district (County, Okres in Czech). But the program needs State - but we have no states, only Counties (Okresy). Many OK/OM stations indicate on servers (eg Hamqth) County character code - mine is GBL. What with it? Can County be added as the first criterion? And would it be possible to import a database of OK/OM callsigns with County codes?
    Thank you for the info.
    73 Josef OK2WO
  4. #859
    03.02.2006
    20,753
    10225
    5491
    It's wrong! Look here - https://adif.org/314/ADIF_314.htm
    Enumeration for Country Code 503 (Czech Republic)
    Code Primary Administrative Subdivision
    Southern Moravia (Jihomoravský kraj)
    GBL Blansko
    By ADIF standart - GBL is Primary Administrative Subdivision - for log - State.
  5. #860
    21.07.2022
    80
    20
    Re:
    Oh yes - ADIF specifications - I did not know it, sorry. Thank you for clearing. I was looking in LogHX (live example):
    Next I was looking to Hamqth XML (example on web) - there is <district> as our OKRES (STATE by ADIF) code:
    That is a referred problem, probably.
    73 all the best, Josef OK2WO
  6. #861
    QRPP
    05.01.2024
    41
    6
    I also meet the same issue,
    v761:????? as callsign、???as mode、???as band
    v762:callsign is ok;???as mode、???as band
    - - - Updated - - -
    Hello,
    in the last version of LogHX I am noticed the problem:
    QSO from MSHV is written to log with ?????? as callsign, sometimes. Previous versions were OK, no ??????...
    73 de Josef, OK2WO
  7. #862
    21.07.2022
    80
    20
    I do not see ? ? ? as Mode, but now (since I changed to vers. 762) the Mode is not taken from MSHV. It is a big issue, FT8, MSK, FSK, Q65 QSOs are RTTY or SSB by the band !
  8. #863
  9. #864
    03.02.2006
    20,753
    10225
    5491
    Pse QRX! Will be fixed in new release.
  10. #865
    21.07.2022
    80
    20
    Thank you. Look please for "Propagation", it is (and was) not copied to log.
  11. #866
    QRPP
    25.07.2024
    4
    Hi,
    Upgraded to 762 and changed "Call" font size and type at "Find" search.
    Wher can I set these parameters? TU
    73 Steve HA9PP
  12. #867
    03.02.2006
    20,753
    10225
    5491
    Now you can not change font for field Call (Find call), but if need - I can make it.
    Today I test MSHV with log (I use JTDX for FT8). I can not found problem.
    Explain - where ??? In QSOEntry window?
    Pse printsrceen!
  13. #868
    QRPP
    25.07.2024
    4
    [QUOTE=RX4HX;2041645]Now you can not change font for field Call (Find call), but if need - I can make it.
    I have returned to 761, so PSE check this part of program and make correction if possible. TU
    73 Steve HA9PP
  14. #869
    03.02.2006
    20,753
    10225
    5491
    Will be done in 763 version.
  15. #870
    03.02.2006
    20,753
    10225
    5491
    Done -
    https://forum.qrz.ru/355-loghx-appar...ml#post2041730
  1. LogHX: Актуальные релизы и история изменений.
    Ответов: 971
    Последнее сообщение: 08.01.2026, 00:04
  2. DIY UW3DI (for English OPs)
    от UU2JET в разделе КВ: UW3DI
    Последнее сообщение: 18.01.2013, 12:04
  3. KENWOOD TS-2000 (Black Version)
    от UA3IRS в разделе TS-2000
    Последнее сообщение: 16.11.2009, 20:16
  4. Navitel 2.0 Pocket PC Version
    от RX3AOE в разделе APRS
    Последнее сообщение: 26.09.2006, 03:39
  5. windows 64 bit version не ставится
    от UR4LZW в разделе Программное обеспечение
    Последнее сообщение: 12.09.2005, 23:58
