Страница 60 из 68 ПерваяПервая ... 1050535455565758596061626364656667 ... ПоследняяПоследняя
Показано с 886 по 900 из 1017
Like Tree167Спасибо
Тема: LogHX: English version
  1. #886
    03.01.2021
    196
    18
    ??? IC-7600 like others transceivers has 2 VFO - VFO-A and VFO-B.
    But I checked INI-files for IC-7600 - here is mistakes.
    What ini-file for 7600 do you use?
    IC-7600 or
    IC-7600v2-DATA or
    IC-7600v2?
    Please read old problem, solved (message #817)
    Now If I downgrade to v763 all work fine
    If I upgrade to v767 CAT do NOT work
    So I think there is some changes .
    Thanks.
    73 de IK2XDE Andrea
    IK2XDE Andrea - WWLoc. JN45MQ
    https://www.xdenews.net/ik2xde/logonline/
    RADIO Setup (update 30/08/2025)
    ICOM IC-7600 - (HF - 50MHz.)
    SunSDR2DX - (HF - 50MHz. - 144 MHz.)
    OM Power - OM2000A+ (1.8-50 MHz. Amplifier)
    OB11-3 (11 element - 3 band - 10m-15m-20m)
    OB9-3 WARC (9 element - 3 band - 12m-17m-30m)
    SkyWire Loop (40-60-80-160 m.)
    LogHX Managers Database (update for free)
    https://www.xdenews.net/managers/
  2. #887
    03.02.2006
    20,753
    10225
    5491
    Цитата Сообщение от IK2XDE Посмотреть сообщение
    v763 all work fine
    ... but here is problem with Yaesu TRX....
    Well, try this version:
    http://rx4hx.qrz.ru/files/loghx/test..._build_767.exe
  3. #888
    03.01.2021
    196
    18
    NO SORRY....
    When I move the split vfo, the blue arrow does not track the split frequency
    Also FREQB does not track the split frequency.
  4. #889
    03.02.2006
    20,753
    10225
    5491
    NO SORRY
    Need printscreen this two windows from version 763, where all work well -
    for IC-7600.
  5. #890
    03.02.2006
    20,753
    10225
    5491
    NO SORRY
    I found problem - try again:
  6. #891
    03.01.2021
    196
    18
    Now default work correct
    but if I set FreqA option,
    red arrow disappears from band map,
    and FreqB do NOT track the VfoB.
  7. #892
    03.02.2006
    20,753
    10225
    5491
    Do you use CatHX or OmniRig?
  8. #893
    03.01.2021
    196
    18
    I use CatHX
    Thanks.
  9. #894
    03.02.2006
    20,753
    10225
    5491
    Did it work differently in version 763? I've checked it now - everything is same as in version 763.
  10. #895
    03.02.2006
    20,753
    10225
    5491
  11. #896
    03.01.2021
    196
    18
    This time
    blue arrow disappears,
    and FreqB no track VfoB
    I investigate, the last version that work correct was v 761 (sorry not 763)
    with v 761 CatHX work perfect with IC-7600
    Thanks.
  12. #897
    03.02.2006
    20,753
    10225
    5491
    FreqB no track VfoB
    When you use "FreqB" - is split OFF?
    For option "FreqA" or "FreqB": here is same code - 767 and 761.
  13. #898
    03.01.2021
    196
    18
    VfoA = FreqA = Freq (Fixed freq. where I listen DX station)
    SPLIT ON
    VfoB = FreqB (TX frequency where I move my TX split frequency)
    Thanks.
  14. #899
    03.02.2006
    20,753
    10225
    5491
    SPLIT ON
    If you select FreqA/FreqB in Radio setup, you can not use split. This setting is for fixing Vfo.
    Why do yuo use FreqA/FreqB? This setting was made for FlexRadio.
  15. #900
    03.01.2021
    196
    18
    With the latest version 767 (the one from today 06/09)
    Everything works correctly.
    However, I discovered that the changes were made between 759 and 761
    (I have never tried 760) and since then all the subsequent ones do not work.
    However, I confirm that the V 767 from today 06/09/2024 works correctly with my IC-7600,
    correctly manages the split frequency, both vfa and vfob, correctly records the qso in log rxfreq and txfreq,
    on the band map the red and blue arrows are correctly displayed.
    In the qso entry window, the call of the station positioned on VfoaA (RxFreq) is correctly displayed.
    Thank you.
    73 de IK2XDE Andrea
  1. LogHX: Актуальные релизы и история изменений.
    Ответов: 971
    Последнее сообщение: 08.01.2026, 00:04
  2. DIY UW3DI (for English OPs)
    от UU2JET в разделе КВ: UW3DI
    Последнее сообщение: 18.01.2013, 12:04
  3. KENWOOD TS-2000 (Black Version)
    от UA3IRS в разделе TS-2000
    Последнее сообщение: 16.11.2009, 20:16
  4. Navitel 2.0 Pocket PC Version
    от RX3AOE в разделе APRS
    Последнее сообщение: 26.09.2006, 03:39
  5. windows 64 bit version не ставится
    от UR4LZW в разделе Программное обеспечение
    Последнее сообщение: 12.09.2005, 23:58
