No way, Andrea, I am think. NOTES will be forever :r-l: Last word is on Alexey himself.
Here:
Вложение 292338
Now you can export log field Info to ADIF tag COMMENT.
Hello!
To contribute, follow my current setup of coutry_district.dat and more information.
HNY, and 73 de py5ej.
Stay safe.
Hi,
Anton.
As you can see from the attached files, the information is similar, but with a structure, and additional data,
to allow "auto-determine State", when added to country_district.dat, except for the Chile area.
The "XX - Call Distribution (Country).txt" files, also contain information for editing the "Primary and secondary areas" fields in LogHX.
Canada - Code adding, and some CQ and UTI zones have been corrected.
For testing, it will be necessary to replace the original file with country_district_(PY5EJ-2021-01).dat.
Thanks for your attention.
73 de py5ej.
Many thanks! Added! Please, check it:
http://rx4hx.qrz.ru/files/loghx/prer..._build_608.exe
Hello, I use V3.0 build 608. I use CWGet V2.37 registered, i can not start this from LogHX i have Error CWGet not found.
73 Pat
Hi Alexei,
Thanks for the info works now.
COUNTRY ERROR
C31CT was ANDORRA and not Uruguay
Вложение 293438
Hi,
Andrea and Anton.
In attention, I solved with the "country_district.dat (15jan21)" find in attached, for analyze and test,
If want test, please, rename and replace the file original.
Thanks.
73 de py5ej.
OK. I'll take a try this one. TNX
Tried.. C31CT now defined as Andorra
Вложение 293450
seems it works now with PY5EJ's correction
