Вложение 277878
Thanks, I am having trouble with Profiles.
I go to Create profile and type in all the boxes for my 3 types, M0CGF, M0CGF/M, M0CGF/P. I cannot then select these profiles in the log via the select profile option. When I go to the select setup>profiles>select Active Profile, none of these are in the list shown. If I type the full name in Set>profiles>create it then appears but I cannot get it to put in the information in the log. For example I run M0CGF/M, but often different locations so I want a profile per location with different equipment and location references.
Thanks, that saves well now, in the columns but now trying to get QRZ to upload, seems the _m is an issue but I cannot see where this is referenced
Вложение 279095
Profile name use only for save profile-settings. It's all. I think - it's coincidence. May be call M0CGF/M not register on QRZ.COM?
Look here:
Вложение 279097
May be EXTENDED=M?
Its definately on QRZ.com, you can see the Logbook info I posted from QRZ.com in the photo.
Really strange.
What fills in the Empty part you point to? Is that generated from QRZ.com?
Вложение 279098Вложение 279100
Thanks, I posted in their forum aswell. Will let you know the answer.
I uploaded the adi after i exported it.
QRZ has completed the import processing of your logbook file.
File name: m0cgf_mobile.adi (25 records)
Destination Book(s):
"M0CGF/M" (276317)
Started on: Fri Oct 23 19:08:02 2020
Finished on: Fri Oct 23 19:08:03 2020
Import Results:
25 QSO's were inserted
0 duplicates were replaced
0 duplicates ignored
0 errors.
25 queued for confirmation checking
No luck on QRZ.com
https://forums.qrz.com/index.php?thr.../#post-5642838
maybe its my profiles?
When I select my mobile log in LogHX but I keep the operator as M0CGF it uploads to QRZ to my home log not mobile. If I choose profile M0CGF/M thats when I get the error message on the live upload window. So I think its something not set properly in my loghx.
also noticed a typo on the delete QSO. Shure - SureВложение 279909
Install new prerelease
http://rx4hx.qrz.ru/files/loghx/prer..._build_587.exe
What to do: run log with parametr /D=<NewDirForSetupFiles>
Create new icon for log like this:
Вложение 280003
Set name for new icon LogHX_Modile or other and run LogHX from new icon. Set QRZ.COM settings for /M call.
Now you have two loghx icons - for home and for mobile.
Thanks! Fixed!
Вложение 280037
In here? Not sure where it goes
Does this mean its the same loghx.exe running but it just looks at different data?
Also
is it easy to set up a new contest? Looking to enter this weekend, this comp https://www.ukeicc.com/DXcontestRules/rulesrussian.htm
