Страница 7 из 68 ПерваяПервая 12345678910111213141757 ... ПоследняяПоследняя
Показано с 91 по 105 из 1017
Like Tree167Спасибо
Тема: LogHX: English version
  1. #91
    03.02.2006
    20,627
    10150
    5453
    Цитата Сообщение от M0CGF Посмотреть сообщение
    I added my API key to LogHXbut it doesn't seen to go up automatically.
  2. #92
    Low Power
    16.04.2020
    89
    3
    Thanks, I am having trouble with Profiles.
    I go to Create profile and type in all the boxes for my 3 types, M0CGF, M0CGF/M, M0CGF/P. I cannot then select these profiles in the log via the select profile option. When I go to the select setup>profiles>select Active Profile, none of these are in the list shown. If I type the full name in Set>profiles>create it then appears but I cannot get it to put in the information in the log. For example I run M0CGF/M, but often different locations so I want a profile per location with different equipment and location references.
  3. #93
    03.02.2006
    20,627
    10150
    5453
    M0CGF/M, M0CGF/P
    Don't use "slash" / in Profile name. Instead M0CGF/M write M0CGF_M, etc.
  4. #94
    Low Power
    16.04.2020
    89
    3
    Thanks, that saves well now, in the columns but now trying to get QRZ to upload, seems the _m is an issue but I cannot see where this is referenced
  5. #95
    03.02.2006
    20,627
    10150
    5453
    Profile name use only for save profile-settings. It's all. I think - it's coincidence. May be call M0CGF/M not register on QRZ.COM?
    Look here:
    May be EXTENDED=M?
  6. #96
    Low Power
    16.04.2020
    89
    3
    Its definately on QRZ.com, you can see the Logbook info I posted from QRZ.com in the photo.
    Really strange.
    What fills in the Empty part you point to? Is that generated from QRZ.com?
ID:	279098Название: Capture1.JPG
  7. #97
    03.02.2006
    20,627
    10150
    5453
    I don't know about QRZ.COM, but may be for "/M" you must register "/M" like "extended" for base call?
    Or may be OWNER must be M0CGF/M?
    I think - problem it QRZ.COM settings for book.
  8. #98
    Low Power
    16.04.2020
    89
    3
    Thanks, I posted in their forum aswell. Will let you know the answer.
    I uploaded the adi after i exported it.
    QRZ has completed the import processing of your logbook file.
    File name: m0cgf_mobile.adi (25 records)
    Destination Book(s):
    "M0CGF/M" (276317)
    Started on: Fri Oct 23 19:08:02 2020
    Finished on: Fri Oct 23 19:08:03 2020
    Import Results:
    25 QSO's were inserted
    0 duplicates were replaced
    0 duplicates ignored
    0 errors.
    25 queued for confirmation checking
  9. #99
  10. #100
    03.02.2006
    20,627
    10150
    5453
    No luck on QRZ.com
    As a result, I didn't understand: what does the log do wrong?
  11. #101
    Low Power
    16.04.2020
    89
    3
    maybe its my profiles?
    When I select my mobile log in LogHX but I keep the operator as M0CGF it uploads to QRZ to my home log not mobile. If I choose profile M0CGF/M thats when I get the error message on the live upload window. So I think its something not set properly in my loghx.
    also noticed a typo on the delete QSO. Shure - SureНазвание: Capture2.JPG
  12. #102
    03.02.2006
    20,627
    10150
    5453
    Install new prerelease
    http://rx4hx.qrz.ru/files/loghx/prer..._build_587.exe
    What to do: run log with parametr /D=<NewDirForSetupFiles>
    Create new icon for log like this:
    Set name for new icon LogHX_Modile or other and run LogHX from new icon. Set QRZ.COM settings for /M call.
    Now you have two loghx icons - for home and for mobile.
    Shure - Sure
    Thanks! Fixed!
  13. #103
    Low Power
    16.04.2020
    89
    3
    In here? Not sure where it goes
    Does this mean its the same loghx.exe running but it just looks at different data?
  14. #104
  15. #105
    03.02.2006
    20,627
    10150
    5453
    In here?
    Yes!
    Yes - it's simple vartiant for work with multi-logs.
    is it easy to set up a new contest?
    If I make it. Little time. But I will.
  1. LogHX: Актуальные релизы и история изменений.
    Ответов: 971
    Последнее сообщение: 08.01.2026, 00:04
  2. DIY UW3DI (for English OPs)
    от UU2JET в разделе КВ: UW3DI
    Последнее сообщение: 18.01.2013, 12:04
  3. KENWOOD TS-2000 (Black Version)
    от UA3IRS в разделе TS-2000
    Последнее сообщение: 16.11.2009, 20:16
  4. Navitel 2.0 Pocket PC Version
    от RX3AOE в разделе APRS
    Последнее сообщение: 26.09.2006, 03:39
  5. windows 64 bit version не ставится
    от UR4LZW в разделе Программное обеспечение
    Последнее сообщение: 12.09.2005, 23:58
