From file:
Username/password incorrect
Hello, Alexei, and LogHX users.
Since the end of November 2020, I migrated from UR5EQF-log to LogHX, to facilitate the use, it was necessary to update the database of LogHX- build 603:
In C:\HAM\LogHX\LogHX\CountryData
File: country_district.dat_(PY+LU ver. PY5EJ -Dez20), file attached with fields updated >> Call, State, WAZ and ITUZ for Brazil and Argentina, as suggestion for review and eventual use;
In menu LogHX >> Utilities/Primary and secondary areas;
PY- Brazil (State list without special characters):
Вложение 288393
LU- Argentina (State list with reference into suffix):
Вложение 288394
To use the above information, it will be necessary to edit via LogHX menu >> Utilities/Primary and secondary areas and rename file attached to country_district.dat and replace the originals.
After review, please Alexei, consider to include the update to the next build.
Thanks to Alexei,
73 of py5ej,
Pavanatti.
Thank you very much! It's very good job!
But need little correction:
Brazil (Acre State (AC)): 11: 12: SA: -9.97: -67.81: 3.0: PY: 43: 108:
PT8{Z0123456789},PU8{ABCDEFGHIMNOPQRSTUVWXYZ0123456789};
and
Brazil (Amapa State (AP)): 11: 13: SA: 0.03: -51.06: 3.0: PY: 43: 108:
PQ8{Z0123456789},PU8{ABCDEFJKLMNOPQRSTUVWXYZ0123456789};
here same prefix PU8 - how determine - PU8AA is it "Acre State" or "Amapa State"?
And not need write {ABCDEFJKLMNOPQRSTUVWXYZ0123456789} - it's excludes simbols from call. If you mean any letter - right is "PU8" only.
Code simbols in .dat file:
* - any letter A-Z
$ - any numbarts 0-9
{} - exclude simbols fom call - example for JA calls:
Japan (Chugoku): 25: 45: AS: 34.87: 132.82: -9.0: JA: 143: 339:
J{TUWVXYZ0123456789}4;
JT, JU, J8 ets - it's not Japan.
Hello Alexei,
Thanks for your prompt feedback!
The PU8xxx, are the following allocation:
PU 8 AAA a CZZ AMAZONAS;
PU 8 DAA a FZZ RONDONIA;
PU 8 GAA a IZZ AMAPA;
PU 8 JAA a LZZ ACRE;
PU 8 MAA a OZZ MARANHAO;
PU 8 PAA a SZZ PIAUI;
PU 8 TAA a VZZ RORAIMA;
PU 8 WAA a YZZ PARA;
Attached are more information about Call allocation.
73 de py5ej,
Pavanatti.
@PY5EJ
May I add this into COUNTRY_USER.DAT file ?
TNX
Please test this version:
http://rx4hx.qrz.ru/files/loghx/prer..._build_604.exe
here add PY and LU areas to country_district.dat
and now for PY and LU will be field "State" auto-determine .
Hello,
Alexei, and Anton -RC3C.
Alexei, thanks for add PY and LU areas to country_district.dat, the auto filling for the state field, works fine, perfect.
The rules to commemoratives call (PY, ...), with two or more numbers, like py##xxx, are Federative and allocated to Brazil, not associate with state.
Example:
zv15cdr Brazil 15Th Anniversary;
zw30bf Brazil Thirtieth Bauernfest - German Festival;
zz100abcz Brazil 100 anos da ABCZ - Uberaba MG (PY4 state);
Anton, if still interest, in attached you find as I did to edit and setting PY and LU on (COUNTRY_USER.DAT)..
Please accept my thanks.
Merry Christmas, for all!
Hi,
Alexei.
Merry XMAS!
Feedback to country_district.dat build_604.
Please, look for LU#(Sulfix XP-XZ) Tierra del Fuego the state is TF (not FT).
73 de py5ej,
Pavanatti.
For Flora Fauna is it possible to match the reference exactly like on the wwff website, For example DLFF-0093 instead of DFFF-093? As I typed into the WFF field DLFF-0093 and it doesn't show it in the Award part. Is there anything I can help with getting the WWFF references up to date locally with me then send them you to save time?
Вложение 289737
