Страница 10 из 68 ПерваяПервая ... 345678910111213141516172060 ... ПоследняяПоследняя
Показано с 136 по 150 из 1015
Like Tree167Спасибо
Тема: LogHX: English version
  1. #136
    03.02.2006
    20,425
    10032
    5396
    Цитата Сообщение от Alde Посмотреть сообщение
    LoTWdl.txt
    From file:
    Username/password incorrect
  2. #137
    26.10.2019
    46
    17
    9
    From file:
    Hi Alexei,
    I cleaned everything up, installed the new version of LogHX v.3.0 build 599, reconfigured all and now everything, with LoTW, works fine.
    Thanks for all help.
    73 de py5ej,
    Pavanatti.
  3. #138
    26.10.2019
    46
    17
    9
    Suggestion to LogHX country_district.dat to PY+LU countries
    Hello, Alexei, and LogHX users.
    Since the end of November 2020, I migrated from UR5EQF-log to LogHX, to facilitate the use, it was necessary to update the database of LogHX- build 603:
    In C:\HAM\LogHX\LogHX\CountryData
    File: country_district.dat_(PY+LU ver. PY5EJ -Dez20), file attached with fields updated >> Call, State, WAZ and ITUZ for Brazil and Argentina, as suggestion for review and eventual use;
    In menu LogHX >> Utilities/Primary and secondary areas;
    PY- Brazil (State list without special characters):
    LU- Argentina (State list with reference into suffix):
    To use the above information, it will be necessary to edit via LogHX menu >> Utilities/Primary and secondary areas and rename file attached to country_district.dat and replace the originals.
    After review, please Alexei, consider to include the update to the next build.
    Thanks to Alexei,
    73 of py5ej,
    Pavanatti.
    Вложения Вложения
  4. #139
    03.02.2006
    20,425
    10032
    5396
    Thank you very much! It's very good job!
    But need little correction:
    Brazil (Acre State (AC)): 11: 12: SA: -9.97: -67.81: 3.0: PY: 43: 108:
    PT8{Z0123456789},PU8{ABCDEFGHIMNOPQRSTUVWXYZ0123456789};
    and
    Brazil (Amapa State (AP)): 11: 13: SA: 0.03: -51.06: 3.0: PY: 43: 108:
    PQ8{Z0123456789},PU8{ABCDEFJKLMNOPQRSTUVWXYZ0123456789};
    here same prefix PU8 - how determine - PU8AA is it "Acre State" or "Amapa State"?
    And not need write {ABCDEFJKLMNOPQRSTUVWXYZ0123456789} - it's excludes simbols from call. If you mean any letter - right is "PU8" only.
    Code simbols in .dat file:
    * - any letter A-Z
    $ - any numbarts 0-9
    {} - exclude simbols fom call - example for JA calls:
    Japan (Chugoku): 25: 45: AS: 34.87: 132.82: -9.0: JA: 143: 339:
    J{TUWVXYZ0123456789}4;
    JT, JU, J8 ets - it's not Japan.
  5. #140
    26.10.2019
    46
    17
    9
    Hello Alexei,
    Thanks for your prompt feedback!
    The PU8xxx, are the following allocation:
    PU 8 AAA a CZZ AMAZONAS;
    PU 8 DAA a FZZ RONDONIA;
    PU 8 GAA a IZZ AMAPA;
    PU 8 JAA a LZZ ACRE;
    PU 8 MAA a OZZ MARANHAO;
    PU 8 PAA a SZZ PIAUI;
    PU 8 TAA a VZZ RORAIMA;
    PU 8 WAA a YZZ PARA;
    Attached are more information about Call allocation.
    73 de py5ej,
    Pavanatti.
    Вложения Вложения
  6. #141
    07.04.2002
    г.Москва, г.Троицк
    48
    9,476
    2567
    7671
    @PY5EJ
    May I add this into COUNTRY_USER.DAT file ?
    73! Anton RC3C (ex.RV3DHC, RK3KPE, 5ØVE/Ø) & RY3AAL & 5ØRDXØØ3 & RK5AØØ2SWL & 5ØRC/38A2
  7. #142
    26.10.2019
    46
    17
    9
    Цитата Сообщение от RC3C Посмотреть сообщение
    @PY5EJ
    Hello,
    As mentioned it is a suggestion, and is under analyses.
    Feel free to use this information in the best way that suits you.
    73 de py5ej,
    Pavanatti.
  8. #143
    07.04.2002
    г.Москва, г.Троицк
    48
    9,476
    2567
    7671
    TNX
  9. #144
    03.02.2006
    20,425
    10032
    5396
    COUNTRY_USER.DAT
    Best way - i will add it to country_district.dat
    I'll try to do it tomorrow.
    Thanks! Now all ok!
  10. #145
    07.04.2002
    г.Москва, г.Троицк
    48
    9,476
    2567
    7671
    oO
    It will be very helpful, Alexey. Appreciated on that addition.
    TNX.
  11. #146
    03.02.2006
    20,425
    10032
    5396
    Please test this version:
    http://rx4hx.qrz.ru/files/loghx/prer..._build_604.exe
    here add PY and LU areas to country_district.dat
    and now for PY and LU will be field "State" auto-determine .
  12. #147
    26.10.2019
    46
    17
    9
    Build_604.exe[/url]
    add PY and LU areas to country_district.dat.
    Hello,
    Alexei, and Anton -RC3C.
    Alexei, thanks for add PY and LU areas to country_district.dat, the auto filling for the state field, works fine, perfect.
    The rules to commemoratives call (PY, ...), with two or more numbers, like py##xxx, are Federative and allocated to Brazil, not associate with state.
    Example:
    zv15cdr Brazil 15Th Anniversary;
    zw30bf Brazil Thirtieth Bauernfest - German Festival;
    zz100abcz Brazil 100 anos da ABCZ - Uberaba MG (PY4 state);
    Anton, if still interest, in attached you find as I did to edit and setting PY and LU on (COUNTRY_USER.DAT)..
    Please accept my thanks.
    Merry Christmas, for all!
    Вложения Вложения
  13. #148
    07.04.2002
    г.Москва, г.Троицк
    48
    9,476
    2567
    7671
    Oo
    Appreciated very much on this information. I'll add it to my COUNTRY_USER.DAT file.
    Merry XMAS!! Stay Safe!
  14. #149
    26.10.2019
    46
    17
    9
    Hi,
    Alexei.
    Merry XMAS!
    Feedback to country_district.dat build_604.
    Please, look for LU#(Sulfix XP-XZ) Tierra del Fuego the state is TF (not FT).
    73 de py5ej,
    Pavanatti.
  15. #150
    Low Power
    16.04.2020
    88
    3
    For Flora Fauna is it possible to match the reference exactly like on the wwff website, For example DLFF-0093 instead of DFFF-093? As I typed into the WFF field DLFF-0093 and it doesn't show it in the Award part. Is there anything I can help with getting the WWFF references up to date locally with me then send them you to save time?
  1. LogHX: Актуальные релизы и история изменений.
    Ответов: 971
    Последнее сообщение: 08.01.2026, 00:04
  2. DIY UW3DI (for English OPs)
    от UU2JET в разделе КВ: UW3DI
    Последнее сообщение: 18.01.2013, 12:04
  3. KENWOOD TS-2000 (Black Version)
    от UA3IRS в разделе TS-2000
    Последнее сообщение: 16.11.2009, 20:16
  4. Navitel 2.0 Pocket PC Version
    от RX3AOE в разделе APRS
    Последнее сообщение: 26.09.2006, 03:39
  5. windows 64 bit version не ставится
    от UR4LZW в разделе Программное обеспечение
    Последнее сообщение: 12.09.2005, 23:58
