Страница 13 из 68 ПерваяПервая ... 3678910111213141516171819202363 ... ПоследняяПоследняя
Показано с 181 по 195 из 1015
Like Tree167Спасибо
Тема: LogHX: English version
  1. #181
    07.04.2002
    г.Москва, г.Троицк
    48
    9,470
    2558
    7668
    Цитата Сообщение от IK2XDE Посмотреть сообщение
    ADIF tag "COMMENT" not exist any fild in the log.
    No way, Andrea, I am think. NOTES will be forever Last word is on Alexey himself.
  2. #182
    03.02.2006
    20,328
    9983
    5361
    COMMENT
    Here:
    Now you can export log field Info to ADIF tag COMMENT.
  3. #183
    03.01.2021
    196
    18
    Great news......thanks...!!
  4. #184
    26.10.2019
    46
    17
    9
    Hello!
    To contribute, follow my current setup of coutry_district.dat and more information.
    HNY, and 73 de py5ej.
    Stay safe.
    Вложения Вложения
  5. #185
    07.04.2002
    г.Москва, г.Троицк
    48
    9,470
    2558
    7668
    [FILE] country_district_(PY5EJ-2021-01).zip (35.6 Кб, Просмотров: 0)
    Did you add those territories according to IK2XDE question already in your file?
  6. #186
    26.10.2019
    46
    17
    9
    Hi,
    Anton.
    As you can see from the attached files, the information is similar, but with a structure, and additional data,
    to allow "auto-determine State", when added to country_district.dat, except for the Chile area.
    The "XX - Call Distribution (Country).txt" files, also contain information for editing the "Primary and secondary areas" fields in LogHX.
    Canada - Code adding, and some CQ and UTI zones have been corrected.
    For testing, it will be necessary to replace the original file with country_district_(PY5EJ-2021-01).dat.
    Thanks for your attention.
    73 de py5ej.
  7. #187
    07.04.2002
    г.Москва, г.Троицк
    48
    9,470
    2558
    7668
    OK. Appreciated on that. I'll take a try to prepare some test within.
  8. #188
    03.02.2006
    20,328
    9983
    5361
    Many thanks! Added! Please, check it:
    http://rx4hx.qrz.ru/files/loghx/prer..._build_608.exe
  9. #189
    04.01.2021
    59
    11
    3
    Hello, I use V3.0 build 608. I use CWGet V2.37 registered, i can not start this from LogHX i have Error CWGet not found.
    73 Pat
  10. #190
    03.02.2006
    20,328
    9983
    5361
    Цитата Сообщение от ON3CQ Посмотреть сообщение
    CWGet not found.
    For use CWGet, CWType, TrueTTY with log, run once this programs with administrator rights for registration their in Windows.
  11. #191
    04.01.2021
    59
    11
    3
    Hi Alexei,
    Thanks for the info works now.
  12. #192
    03.01.2021
    196
    18
    COUNTRY ERROR
    C31CT was ANDORRA and not Uruguay
  13. #193
    07.04.2002
    г.Москва, г.Троицк
    48
    9,470
    2558
    7668
    Восклицание
    COUNTRY ERROR
    it seems the mistake is in country_district.dat in line of
    Код:
    Uruguay (Montevideo):      13:  14:  SA:   -34.88:  -56.27:   3.0:    CX:     307:  144:  MO:
        C{ABCDEFGHIJKLMNOPQRSTUYZ}$A,C{ABCDEFGHIJKLMNOPQRSTUYZ}$B,C{ABCDEFGHIJKLMNOPQRSTUYZ}$C;
  14. #194
    26.10.2019
    46
    17
    9
    Hi,
    Andrea and Anton.
    In attention, I solved with the "country_district.dat (15jan21)" find in attached, for analyze and test,
    If want test, please, rename and replace the file original.
    Thanks.
    73 de py5ej.
    Вложения Вложения
  15. #195
    07.04.2002
    г.Москва, г.Троицк
    48
    9,470
    2558
    7668
    OK. I'll take a try this one. TNX
    Tried.. C31CT now defined as Andorra
    seems it works now with PY5EJ's correction
  1. LogHX: Актуальные релизы и история изменений.
    Ответов: 971
    Последнее сообщение: 08.01.2026, 00:04
  2. DIY UW3DI (for English OPs)
    от UU2JET в разделе КВ: UW3DI
    Последнее сообщение: 18.01.2013, 12:04
  3. KENWOOD TS-2000 (Black Version)
    от UA3IRS в разделе TS-2000
    Последнее сообщение: 16.11.2009, 20:16
  4. Navitel 2.0 Pocket PC Version
    от RX3AOE в разделе APRS
    Последнее сообщение: 26.09.2006, 03:39
  5. windows 64 bit version не ставится
    от UR4LZW в разделе Программное обеспечение
    Последнее сообщение: 12.09.2005, 23:58
