Returning to version 776 all work fine,
so please check here the difference.
Thanks in advance.
73 de IK2XDE Andrea
Hello Andrea!
Try this test version:
http://rx4hx.qrz.ru/files/loghx/test..._build_780.exe
Version at 25 august.
Hi, thanks for your attention.
You probably have the solution right in front of you, but you can't see it...hey...
Let's start with something that's certain: version 776 works correctly.
So you need to look at what you changed afterward; the problem persists from 777 to 780.
I use WSJT-X as always and obviously haven't changed any configurations (which I checked, however).
When the callsign of the correspondent is in the call field of wsjt-x,
the callsign field in the "log entry" window is filled with the same callsign.
Loghx searches for the data on qrz.com and completes the other fields.
Then I put "N" in the Print Queue field because I don't want a QSL (QSL NOT NEED).
Here's where it ends: when WSJT-X saves the QSO, LogHX also saves the QSO,
but without the pre-populated qrz.com fields and also leaves the PrintQueue field blank, where I manually entered the "N."
Check carefully: the solution is in version 776, which works correctly.
Thanks in advance for your efforts in finding the solution.
Try this version -
at 27.08.2025
Что то не пойму что делаю не так, прошу помощи гуру, задача из журнала выбрать связи в FT8, FT4 и все это сохранить в adif. Что делал, в журнале выбрал фильтр-установить фильтр Вложение 373109 , настроил дату старта и окончания, настроил мод и диапазоны, выбрал все континенты, тыкаю установить фильтр, по идее в журнале должны все связи выделится, но я не вижу выделения как при выделении клавишей пробел, где покопать??
It was difficult, but I did it!)))
Now all is Ok!
OK , Now I test v 780 date 28/08/2025 - 15.50
all fields was saved correctly......thanks....!!
But we have another problem
Вложение 373151
Duble Error on start, v 780 28/08 15.50
Вложение 373152Вложение 373153
Hello Alex,
what about SSB Macros via TCI for our SunSDR2DX....??
For now, I'm using RadioMacros, which comes with ESDR3, but it would be nice to see it work with LogHX.
Will there be any future possibility of using MTTY via TCI?
Thanks for your attention.
73 by IK2XDE Andrea.
Hi,
how do you use this new feature and what is it for?
LogHX3.exe /V=ViewName
start LogHX with "View" - "ViewName"
Thanks.
73 de IK2XDE Andrea
