23.08.2025, 11:49 #991Standart Power
- 03.01.2021
- 196
- 18
IK2XDE Andrea - WWLoc. JN45MQ
https://www.xdenews.net/ik2xde/logonline/
RADIO Setup (update 30/08/2025)
ICOM IC-7600 - (HF - 50MHz.)
SunSDR2DX - (HF - 50MHz. - 144 MHz.)
OM Power - OM2000A+ (1.8-50 MHz. Amplifier)
OB11-3 (11 element - 3 band - 10m-15m-20m)
OB9-3 WARC (9 element - 3 band - 12m-17m-30m)
SkyWire Loop (40-60-80-160 m.)
LogHX Managers Database (update for free)
https://www.xdenews.net/managers/
25.08.2025, 20:16 #992Координатор темы
- 03.02.2006
- 53
- 20,566
- 10121
- 5443
Hello Andrea!
Try this test version:
http://rx4hx.qrz.ru/files/loghx/test..._build_780.exe
Version at 25 august.73 de RX4HX, Alexei, http://rx4hx.qrz.ru
Ant.: UW4HW, Pwr.: ~500 Wtts
26.08.2025, 10:07 #993Standart Power
- 03.01.2021
- 196
- 18
26.08.2025, 13:02 #994Координатор темы
- 03.02.2006
- 53
- 20,566
- 10121
- 5443
26.08.2025, 15:47 #995Standart Power
- 03.01.2021
- 196
- 18
Hi, thanks for your attention.
You probably have the solution right in front of you, but you can't see it...hey...
Let's start with something that's certain: version 776 works correctly.
So you need to look at what you changed afterward; the problem persists from 777 to 780.
I use WSJT-X as always and obviously haven't changed any configurations (which I checked, however).
When the callsign of the correspondent is in the call field of wsjt-x,
the callsign field in the "log entry" window is filled with the same callsign.
Loghx searches for the data on qrz.com and completes the other fields.
Then I put "N" in the Print Queue field because I don't want a QSL (QSL NOT NEED).
Here's where it ends: when WSJT-X saves the QSO, LogHX also saves the QSO,
but without the pre-populated qrz.com fields and also leaves the PrintQueue field blank, where I manually entered the "N."
Check carefully: the solution is in version 776, which works correctly.
Thanks in advance for your efforts in finding the solution.IK2XDE Andrea - WWLoc. JN45MQ
27.08.2025, 08:39 #996Координатор темы
- 03.02.2006
- 53
- 20,566
- 10121
- 5443
Try this version -
at 27.08.202573 de RX4HX, Alexei, http://rx4hx.qrz.ru
27.08.2025, 10:30 #997Low Power
- 24.05.2022
- Оренбург
- 71
- 8
- 14
Что то не пойму что делаю не так, прошу помощи гуру, задача из журнала выбрать связи в FT8, FT4 и все это сохранить в adif. Что делал, в журнале выбрал фильтр-установить фильтр
, настроил дату старта и окончания, настроил мод и диапазоны, выбрал все континенты, тыкаю установить фильтр, по идее в журнале должны все связи выделится, но я не вижу выделения как при выделении клавишей пробел, где покопать??
27.08.2025, 14:45 #998Standart Power
- 03.01.2021
- 196
- 18
27.08.2025, 20:09 #999Координатор темы
- 03.02.2006
- 53
- 20,566
- 10121
- 5443
It was difficult, but I did it!)))
Now all is Ok!73 de RX4HX, Alexei, http://rx4hx.qrz.ru
28.08.2025, 19:46 #1000Standart Power
- 03.01.2021
- 196
- 18
28.08.2025, 20:50 #1001Координатор темы
- 03.02.2006
- 53
- 20,566
- 10121
- 5443
28.08.2025, 21:46 #1002Standart Power
- 03.01.2021
- 196
- 18
30.09.2025, 23:25 #1003Standart Power
- 03.01.2021
- 196
- 18
Hello Alex,
what about SSB Macros via TCI for our SunSDR2DX....??
For now, I'm using RadioMacros, which comes with ESDR3, but it would be nice to see it work with LogHX.
Will there be any future possibility of using MTTY via TCI?
Thanks for your attention.
73 by IK2XDE Andrea.IK2XDE Andrea - WWLoc. JN45MQ
07.11.2025, 20:35 #1004Standart Power
- 03.01.2021
- 196
- 18
Hi,
how do you use this new feature and what is it for?
LogHX3.exe /V=ViewName
start LogHX with "View" - "ViewName"
Thanks.
73 de IK2XDE AndreaIK2XDE Andrea - WWLoc. JN45MQ
07.11.2025, 22:16 #1005Координатор темы
- 03.02.2006
- 53
- 20,566
- 10121
- 5443
167Спасибо
