Yes, here is some proplem! Pse QRX!
Hi had the vhfstpete dll flagged today and also telnet disconnects.
However I have an issue with the bandmap, its just not showing even though its ticked.
I have recently changed to a new win11 PC from win10, and I am not sure if my install copied across OK as each time i load it I have various different things happening. It doesn't seen to save the views and associated radios.
Question for everyone incase there is a better way.
I have a view for SSB where I have a radio selected for control.
For FT8 I have a view with wsjtx loaded, in Loghx no radio is selected and its controlled via wsjtx.
Best way to manage it? Issue is if I want to quickly nip to ssb then its a reload of view as the reports are still +- etc.
ignore this I managed to fix the view by copying over the ini for the bandmap from a different view.
I'm still getting the telnet disconnects as well.. only to localhost - external ones are fine.
Also sone UI issues..
Firstly, on loading LogHX, I get the following 2 error windows:
Вложение 365968
Вложение 365969
After loading, there are 2 windows that don't come up properly...
First the Awards window - all font sizes increase by approx 35% each time the window is reopened.
Secondly, the Frequency window. I have set it to look like this:
Вложение 365971
but after reloading the software, it comes up like this:
Вложение 365970
I have to re-set it each time.
Even though I have saved the setup under "Select View" once I have it as I want, the issues still persist.
It's worth pointing out that I have a multi-screen setup here, I don't know if that is part of the problem.
[QUOTE=RX4HX;2075109]Log version?
Oh sorry ! Should have said.... Build 776
since updating my gfx card all the views open but they seem to all appear off the screen and I cannot view the windows. REally weird.
Is there anything I can reset in the view ini to fix this?
While we wait and see if Alexei comes up with a solution....
I don't have a definitive answer, but the file you're looking for is likely to be in LogHX/INI/Vews/GeneralViews then select the folder of the name of the view you are currently using. Make a copy of the loghx_view.ini, so that if this doesnt work, you still have a copy of the original.
Change all lines starting "left" or "top" to 0 and see if that repositions your windows to where you can see them on restarting LogHX.
I THINK that worked for me in the past.
Thanks will try it.
One more question.
I have view for SSB and a view for FT8. I am sure before this reinstall that the SSB allowed a radio in CATHX and in FT8 view the radio was disabled. I've tried resaving the views with these settings but the radio still remains on and clashes with wsjtx for control and the radio ends up in rtty-r mode.
Do you want link CAT to View? If yes, check here -
Вложение 366476
Been off the air for a while since the last rotator question.
I have the rototar connected, it says click left SP etc on the QSO entry window. When I click the SP it just sends the Rotator to 0 deg, LP does nothing.
Any ideas how to troubleshoot?
Test quuestion
Hello Ian!
I'm new to LOG XH, and I find it great. I managed to set it up easily. However, while using it, the LOG
window suddenly shrank for no apparent reason. Now, I can’t resize it back to its original size.
Can someone help me? Thanks, 73 Pierre VA2CZ
Can't you stretch the window with the mouse? Show printscreen, please!
