У меня hamalert работает только если в ручную логин и пароль вводить
How get freq LogHX => Good question, and I don't know exactly but for me (Not sure) it is the same way that WSJT-X . It work perfectly with WSJT-X but with FLDIGI frequencey must be modify slowly. I tried to increased VSP speed from 19200 to 38400 and it is the same.
Here is the setup
Вложение 325343
73s Christian F8GHE
b693 = b692 on Telnets.
b694 = b693 = b692 on Telnets.
Telnet1: All OK! dx.hu/9000, hamalert.org/7300, 127.0.0.1/7373 works fine WITH scripts.
Telnet2: With scripts do nothing. Without scripts (empty scripts) I can login manually.
Telnet3: same as Telnet2
b695 on Telnets is same as before.
Hi Alexei, Have you looked to code a macro or other method able of adjusting the CW speed to that of a CW spot from a cluster ? Another setting could be a default CW speed.
73s Christian F8GHE
- - - Updated - - -
Hello, for me there is an issue with the Telnet1 Script with these error messages 1 and 2Вложение 325687
Alexei,
Thank you in advance!
It is would be very useful when a /P or /M station works from 2-3-4 rayons (RDAs).
No any option to logging all RDA at once, must be line by line for correct info in Award window.
I would just click on the "Copy" button and reedit just the next RDA in State/Country fields.
The "Insert" button is helps a bit but missing datas.
PS: Telnets are OK, thank you for your effort!
At me Telnet1, Telnet2 with script(s), Telnet3 without script(s).
Alexei,
Is it possibele when I logging a QSO with split, then logging the RX frequency not the TX frequency?
For me, more important to see/know/remember where I HEARD the other station.
