Alexei,
Funny but I did not know/think about it! Home/End works fine!
"Last" button is good if the mouse is in your hand, than not need to release it! I'm lazy... :s10::s12:
73 Egon
New release 663:
Вложение 311229
Alexei,
You are awesome! Thank you very much! Red arrows are perfect! (rel. 663) But... I found "something" again! :s6:
As a RDA collector, I use RDA Award window very often and if I click on any RDA, only an empty window appears and to open this empty window, I have to click four! Two mouse click do nothing. Photos attached. Rel. 660 works fine, two click is enough as normally.
Greetings, Egon
Вложение 311236Вложение 311237
PS: build 662 do the same.
Yes, it's mistake! Thank you for your comment!
Fixed. Release reload:
http://rx4hx.qrz.ru/files/loghx/LogH..._build_663.exe
Hello,
running v 3.0 build 665
no correct display new START/END command.
Вложение 311657
Вложение 311656
73 de IK2XDE Andrea
Hello, as posted with image, in my msg. 380
Skyns: Acryl.asz
Styles: Luna
73 de IK2XDE Andrea.
Hello,
any news about this ....??
Hello,
using Sunsdr2DX,
there is no problem if using ESDR2 with TCI 1.4
but please verify that ESDR3 A0.8 work with TCI 1.5
and the ESDR3 A0.9 work with TCI 1.6.
So in the next feature you must updare TCI with 1.6 version.
There is some little difference.
Thanks in advance for your effort.
Hi Andrea,
I have been using ESDR3 with LogHX and it works ok for me for everyday work. The only "annoyance" i have found is that klicking on spots on ESDR3 panadapter does not fill the QSO window in LogHX. But according to UT4LW this function is not fully implemented in ESDR3 yet. I am, however, no advanced user, only CW and digimode work with JTDX and MSHV. So if Alexei want to wait until ESDR3 matures until implementing different TCI log on for ESDR2 and ESDR3, I can wait.
73 de LB2EG Richard
Hello Richard,
Yes, TCI 1.6 work with ESDR A0.9.
So this not necessary for now, but I think in the future, we need to verify loghx and update to TCI 1.6.
I confirm that for now....with alpha version....is not necessary.....we are wait for a new ESDR 3 version soon (I hope....hi)
In the clublog when we upload our log ..... immediatily, (not manualy)
please add the choice MERGE into EXISTING LOG.....or......CLEAR LOG before UPDATE (CLEAR OPTION)
Normaly when we send ALL QSO - will be CLEAR OPTION
Normaly when we send NOT SEND QSO - will be MERGED
You can find info about CLEAR option here:
https://clublog.freshdesk.com/suppor...-into-club-log
I find also that actualy, adif file that we send to clublog,
not contain field QSL_RCVD and LOTW_RCVD
This false the clublog DXCC statistic, because not contain, if qso was confirmed or not.
So please add QSL_RCVD and LOTW_RCVD field to adif to send.
you can find other info about this here:
https://clublog.freshdesk.com/suppor...tch-my-logger-
Thanks in advance.
Just a few polite requests and a question.
- in "Radio1" window : when I inserted a callsign from a webpage, sometimes there were 1 or 2 spaces left at the beginning of the callsign, so I couldn’t find it in the log. Would you do that to cut off the blank parts in front of and behind the callsign, please !?
- in "QSO manually/edit" window : there are some fields where I can't paste text with the "Control-V" method, just with the mouse, using the "Menu / Paste". For example: Via, Locator fields. The RSTs, Name, QTH, WFF are OK. (cut of spaces as well?)
- Do you plan to use the new "HamlogR / S" in QSL status and statistic as well as on LoTW, eQSL, Clublog?
The new "QSO manually / Edit" window is very nice! Congratulations to your nice work and the many new things you do! The program is better and better every time, really a pleasure to use it!
Thanks for all Alexei!
73 Egon
Thank you again Alexei!
Well... Most of the time (99%) I usually paste from these websites as I mainly hunt for RDAs : tnxqso, cfmrda, mydx. Sometimes I copy 1-2 spaces front or behind the callsign. :s7: I just insert and do not push the Enter key and checking the result in the "Previous QSOs" window.
73 Egon
