Страница 26 из 68 ПерваяПервая ... 1619202122232425262728293031323336 ... ПоследняяПоследняя
Показано с 376 по 390 из 1017
Like Tree167Спасибо
Тема: LogHX: English version
  1. #376
    Low Power
    19.11.2019
    Nyirabrany
    11
    43
    It's not problem, but why do you not use keys "Home"-"End" for go to first-last QSO?
    Alexei,
    Funny but I did not know/think about it! Home/End works fine!
    "Last" button is good if the mouse is in your hand, than not need to release it! I'm lazy...
    73 Egon
  2. #377
    03.02.2006
    20,631
    10151
    5453
    Цитата Сообщение от HA3MN Посмотреть сообщение
    "Last" button
    New release 663:
  3. #378
    Low Power
    19.11.2019
    Nyirabrany
    11
    43
    RDA windows in build 663
    New release 663:
    Alexei,
    You are awesome! Thank you very much! Red arrows are perfect! (rel. 663) But... I found "something" again!
    As a RDA collector, I use RDA Award window very often and if I click on any RDA, only an empty window appears and to open this empty window, I have to click four! Two mouse click do nothing. Photos attached. Rel. 660 works fine, two click is enough as normally.
    Greetings, Egon
Размер: 18.8 КбНазвание: 660.PNG
    PS: build 662 do the same.
  4. #379
    03.02.2006
    20,631
    10151
    5453
    nothing
    Yes, it's mistake! Thank you for your comment!
    Fixed. Release reload:
    http://rx4hx.qrz.ru/files/loghx/LogH..._build_663.exe
  5. #380
    03.01.2021
    196
    18
    New release 663:
    Hello,
    running v 3.0 build 665
    no correct display new START/END command.
    73 de IK2XDE Andrea
    IK2XDE Andrea - WWLoc. JN45MQ
    https://www.xdenews.net/ik2xde/logonline/
    RADIO Setup (update 30/08/2025)
    ICOM IC-7600 - (HF - 50MHz.)
    SunSDR2DX - (HF - 50MHz. - 144 MHz.)
    OM Power - OM2000A+ (1.8-50 MHz. Amplifier)
    OB11-3 (11 element - 3 band - 10m-15m-20m)
    OB9-3 WARC (9 element - 3 band - 12m-17m-30m)
    SkyWire Loop (40-60-80-160 m.)
    LogHX Managers Database (update for free)
    https://www.xdenews.net/managers/
  6. #381
    03.02.2006
    20,631
    10151
    5453
    What is name of skin? Setup->Use skin - here.
  7. #382
    03.01.2021
    196
    18
    Hello, as posted with image, in my msg. 380
    Skyns: Acryl.asz
    Styles: Luna
    73 de IK2XDE Andrea.
  8. #383
    03.02.2006
    20,631
    10151
    5453
  9. #384
    03.01.2021
    196
    18
    About EQSL image.
    I just download from eqsl all my 65000 qsl image,
    all image are stored in a directory, C:\Users\LOG\Pictures\IK2XDE-EQSL
    Вложение 306626
    As you can see in the example, all immage,
    All qsl use this format file name: CALL_DATE_TIME_BAND_MODE.png
    I try to import a single file image in the PHOTO field of the log, and all work fine,
    but, import manualy 65000 file take a long time.
    Can you please add and automatic integration of the file....??
    For example, if I push show photo (on selected qso)
    automatic verify if file exist in the declared directory, and show it.
    No importing all immage, no importing link or other, only verifiy the file ...and if exist show it.
    Thanks for your attention,
    I hope this change is possible....!!
    Hello,
    any news about this ....??
    Hello,
    using Sunsdr2DX,
    there is no problem if using ESDR2 with TCI 1.4
    but please verify that ESDR3 A0.8 work with TCI 1.5
    and the ESDR3 A0.9 work with TCI 1.6.
    So in the next feature you must updare TCI with 1.6 version.
    There is some little difference.
    Thanks in advance for your effort.
  10. #385
    25.03.2020
    30
    3
    20
    Hello,
    Hello,
    using Sunsdr2DX,
    Hi Andrea,
    I have been using ESDR3 with LogHX and it works ok for me for everyday work. The only "annoyance" i have found is that klicking on spots on ESDR3 panadapter does not fill the QSO window in LogHX. But according to UT4LW this function is not fully implemented in ESDR3 yet. I am, however, no advanced user, only CW and digimode work with JTDX and MSHV. So if Alexei want to wait until ESDR3 matures until implementing different TCI log on for ESDR2 and ESDR3, I can wait.
    73 de LB2EG Richard
  11. #386
    03.01.2021
    196
    18
    Hello Richard,
    Yes, TCI 1.6 work with ESDR A0.9.
    So this not necessary for now, but I think in the future, we need to verify loghx and update to TCI 1.6.
    I confirm that for now....with alpha version....is not necessary.....we are wait for a new ESDR 3 version soon (I hope....hi)
  12. #387
    03.01.2021
    196
    18
    In the clublog when we upload our log ..... immediatily, (not manualy)
    please add the choice MERGE into EXISTING LOG.....or......CLEAR LOG before UPDATE (CLEAR OPTION)
    Normaly when we send ALL QSO - will be CLEAR OPTION
    Normaly when we send NOT SEND QSO - will be MERGED
    You can find info about CLEAR option here:
    https://clublog.freshdesk.com/suppor...-into-club-log
    I find also that actualy, adif file that we send to clublog,
    not contain field QSL_RCVD and LOTW_RCVD
    This false the clublog DXCC statistic, because not contain, if qso was confirmed or not.
    So please add QSL_RCVD and LOTW_RCVD field to adif to send.
    you can find other info about this here:
    https://clublog.freshdesk.com/suppor...tch-my-logger-
    Thanks in advance.
    Последний раз редактировалось IK2XDE; 17.09.2021 в 23:00.
  13. #388
    Low Power
    19.11.2019
    Nyirabrany
    11
    43
    Just a few polite requests and a question.
    - in "Radio1" window : when I inserted a callsign from a webpage, sometimes there were 1 or 2 spaces left at the beginning of the callsign, so I couldn’t find it in the log. Would you do that to cut off the blank parts in front of and behind the callsign, please !?
    - in "QSO manually/edit" window : there are some fields where I can't paste text with the "Control-V" method, just with the mouse, using the "Menu / Paste". For example: Via, Locator fields. The RSTs, Name, QTH, WFF are OK. (cut of spaces as well?)
    - Do you plan to use the new "HamlogR / S" in QSL status and statistic as well as on LoTW, eQSL, Clublog?
    The new "QSO manually / Edit" window is very nice! Congratulations to your nice work and the many new things you do! The program is better and better every time, really a pleasure to use it!
    Thanks for all Alexei!
    73 Egon
  14. #389
    03.02.2006
    20,631
    10151
    5453
    Yes of course. It will be.
    Ok, i'll check this problem.
    All spaces in Call field must be deleted when call inserted. From where web do you insert call? I'll correct this.
  15. #390
    Low Power
    19.11.2019
    Nyirabrany
    11
    43
    Thank you again Alexei!
    Well... Most of the time (99%) I usually paste from these websites as I mainly hunt for RDAs : tnxqso, cfmrda, mydx. Sometimes I copy 1-2 spaces front or behind the callsign. I just insert and do not push the Enter key and checking the result in the "Previous QSOs" window.
    73 Egon
  1. LogHX: Актуальные релизы и история изменений.
    Ответов: 971
    Последнее сообщение: 08.01.2026, 00:04
  2. DIY UW3DI (for English OPs)
    от UU2JET в разделе КВ: UW3DI
    Последнее сообщение: 18.01.2013, 12:04
  3. KENWOOD TS-2000 (Black Version)
    от UA3IRS в разделе TS-2000
    Последнее сообщение: 16.11.2009, 20:16
  4. Navitel 2.0 Pocket PC Version
    от RX3AOE в разделе APRS
    Последнее сообщение: 26.09.2006, 03:39
  5. windows 64 bit version не ставится
    от UR4LZW в разделе Программное обеспечение
    Последнее сообщение: 12.09.2005, 23:58
