Страница 40 из 68 ПерваяПервая ... 3033343536373839404142434445464750 ... ПоследняяПоследняя
Показано с 586 по 600 из 1017
Like Tree167Спасибо
Тема: LogHX: English version
  1. #586
    07.04.2002
    г.Москва, г.Троицк
    49
    9,497
    2569
    7700
    Цитата Сообщение от IK2XDE Посмотреть сообщение
    so for example 4U1VIC who operate from Vienna was considered as Austria
    4U1VIC has been dismissed from Vienna and no longer valid as 4U callsign.
    4U1A is valid from UN in Vienna. Please, note this. Any questions to Andy OE1ZZZ.
  2. #587
    03.01.2021
    196
    18
    Thanks for info, also 4U1A was in my log,....same problem....for WAE
    But of course OLD qso with 4U1VIC are currently valid for the award.
    73 de IK2XDE Andrea
    ik2xde@gmail.com
    Последний раз редактировалось IK2XDE; 07.01.2023 в 01:57.
    IK2XDE Andrea - WWLoc. JN45MQ
    https://www.xdenews.net/ik2xde/logonline/
    RADIO Setup (update 30/08/2025)
    ICOM IC-7600 - (HF - 50MHz.)
    SunSDR2DX - (HF - 50MHz. - 144 MHz.)
    OM Power - OM2000A+ (1.8-50 MHz. Amplifier)
    OB11-3 (11 element - 3 band - 10m-15m-20m)
    OB9-3 WARC (9 element - 3 band - 12m-17m-30m)
    SkyWire Loop (40-60-80-160 m.)
    LogHX Managers Database (update for free)
    https://www.xdenews.net/managers/
  3. #588
    03.02.2006
    20,619
    10148
    5452
    Same thing goes for JW9JKA who operate from Bear Is. but was considered as Svalbard
    You must manually set country -
  4. #589
    03.01.2021
    196
    18
    Hello,
    unfortunately this is not the solution.
    With CTRL+C I will change DXCC country, that is not the same of WAE country.
    WAE award search in the Country field, and does not find UN Vienna, but will find OE - Austria DXCC 206
    and for this he will count the valid QSO as Austria and not as Unitited Nation in Vienna.
    Same problem with JW9JKA from Bear Is. EU-027
    In the field country we will find JW - Svalbard DXCC 259
    so in the WAE award will count like Svalbard Is. JW and not JW/B Bear Is.
    I hope I have explained the problem well.
    73 de IK2XDE Andrea
  5. #590
    03.02.2006
    20,619
    10148
    5452
    WAE country
    Log don't have WAE country. Only DXCC and P-150-C.
  6. #591
    03.01.2021
    196
    18
    That's right, that's the point, so the WAE stats will always come out wrong.
    What solution can we adopt to have the calculation of the correct award..??
    73 de IK2XDE Andrea
  7. #592
    03.01.2021
    196
    18
    Do you use skin? If yes - disable skin and try without skin. May be here.
    Ok i tried, but nothing changed, i completely disabled the skins, and i also tried to select others, but nothing changes.
    This loading pause occurs on the first start.
    Then if I go out and come back, at the new start everything works fine.
    All this always and only on the PC with multiple monitors.
    73 de IK2XDE Andrea
  8. #593
    Low Power
    02.05.2021
    6
    Hi, I'm currently testing (again) the ARS-USB rotator control (Az only) from EA4TX:
    Everything work perfectly when I use ARS-USB through PSTRotator.
    But it is not the same:
    1. When I try to configure ARS-USB in direct connect to the serial COMx port in YAESU emulation without ARSVCOM.
    - It works (Az is sent to the ARS-USB) but I observe after the second or the third character (Depend of LogHX config) of the Callsign input two clicks in the relay
    of the control box per character sent (It's like a ARS-USB reset for each new character sent). AZ sent is correct and rotation OK.
    - I didn’t find how to control rotor start as possible with DXLog (ALT+F12 or CTRL+F12) or PSTRotator (Option: Confim Imported Data)
    (Automatic starting of the rotor is problematic because not necessarily desired).
    When I don't check "Auto rotation to QSO entry Call" in config, I don't know how to start the rotation.
    2. When I tried to configure ARS-USB as EA4TXARS in LogHX, I received an error message "Can not open link ARSWIN !".
    I tried to install ARSWIN but it doesn't work on my x64 OS and ARSVCOM is not recognized.
    Am I doing something wrong?
    73s Christian F8GHE
    - - - Updated - - -
Название:	1.LogHX Yaesu emul.JPG
Название:	2.LogHX EA4TXARS.JPG
    73s Christian F8GHE
  9. #594
    03.02.2006
    20,619
    10148
    5452
    If I understand correctly, you want to start the rotation manually.
    It's here - by keys:
    or by mouse -
    I'll correct this problem!
    I checked. LogHX uses an old version of the EA4TX program. Install last version of EA4TX ARSVCOM and configure LogHX like Swisslog - select Yaesu rotor in LogHX.
    https://ea4tx.com/en/faqs/ars-usb-fa...etup/swisslog/
  10. #595
    04.01.2019
    101
    38
    32
    Hi Cristian
    I want to draw your attention to one problem when controlling the rotator from LogHX. In your picture of the rotator setup, I see that you have two antennas on one rotator (10M, 2M). I use 4bander 40,20,15 and 10M on one rotator with PSTRotor. When I configured it like you (40M,20M,15M,10M) the rotator only worked on the first band (40M). The rotator did not work on the other bands. I had to configure each band separately. Then it worked. You might have the same problem. On 10M the rotator will work for you as Alexey wrote, but on 2M the hint (Rotor connected!....) will not appear and the rotor does not work.
    Vlado OM3BY
  11. #596
    03.02.2006
    20,619
    10148
    5452
    Thanks Vlado! It will be fixed in next version!
  12. #597
    Low Power
    02.05.2021
    6
    ALexei and Vlado, thanks very much for your help and advices.
    I'm going to check.
    73s Christian F8GHE
  13. #598
    Low Power
    02.05.2021
    6
    Hi Cristian
    Vlado OM3BY
    Hi Vlado, with the last build 717, I didn't meet this issu. I'm able to control all bands set on the same line with a "Rotor Type" = PSTROTOR or YAESU and in Manual or Automatic control.
    May be Alexei solved this issu previously !?
    73s Christian F8GHE
    - - - Updated - - -
    It's here - by keys or by mouse
    Hi Alexei, Thanks very much. Now, everything works perfectly
    Note: A hotkey to "stop" the rotation of the motor could be very useful. This would allow to overcome ARSVCOM or PSTROTATOR to do that.
    73s Christian F8GHE
  14. #599
    03.02.2006
    20,619
    10148
    5452
    Not problem! I'll do it!
    How about Ctrl+ESC for stop rotation?
  15. #600
    Low Power
    02.05.2021
    6
    Good idea Alexei or why not [Ctrl+Alt+ESC] to be similar with [Ctrl+Alt+S] and [Ctrl+Alt+L] used for others rotor control cdes ?
    Thanks very much for your help
    73s Christian F8GHE
  1. LogHX: Актуальные релизы и история изменений.
    Ответов: 971
    Последнее сообщение: 08.01.2026, 00:04
  2. DIY UW3DI (for English OPs)
    от UU2JET в разделе КВ: UW3DI
    Последнее сообщение: 18.01.2013, 12:04
  3. KENWOOD TS-2000 (Black Version)
    от UA3IRS в разделе TS-2000
    Последнее сообщение: 16.11.2009, 20:16
  4. Navitel 2.0 Pocket PC Version
    от RX3AOE в разделе APRS
    Последнее сообщение: 26.09.2006, 03:39
  5. windows 64 bit version не ставится
    от UR4LZW в разделе Программное обеспечение
    Последнее сообщение: 12.09.2005, 23:58
