After setting the administrator right, in the latest versions (734 and 735), everything works normally.
Thanks for your help, 73 from py5ej.
Really easy this question I am sure. Which is the option to preview the image and other information from QRZ.com. I have closed it accidentally and just remember the name of the window to select.
73 de Danny M0SDB
I have found it again - Right click on the QSO input window then 'Find...'/Find call on QRZ.com' :)
Alexei, I trust you're doing well.
I've come across a question regarding the RADIO SETUP > RADIO 1 > HAMLIB > Setup in our beloved logbook. While exploring the menus, especially the radio control settings, I noticed a screen where we can configure RADIO 1 or 2. There's an option labeled "HAMLIB" specifically for setting up a "NETWORK CONNECTED RADIO." I'm curious about how this is supposed to function; does it relate to Hamlib TCP rig control daemon RIGCTLD?
Вложение 345304
The question is the Radio Setup/HamLib/Network connected radio (PICTURE LEFT SIDE) the same thing as in JTDX HamLib NET Rigctl (PICTURE RIGHT SIDE)?
For context, the rigctld program is a NEW Hamlib rig control daemon ready for testing that handles client requests via TCP sockets. This allows multiple user programs to share one radio.
In my scenario I've successfully got my older radios (TS440S and IC718) running smoothly using RIGCTLD in conjunction with either JTDX/WSJT-X. Of course it took some time to figure out, but with a simple command line, I can switch the CAT Control between radios and control them seamlessly.
Just as reference I'm sharing the batch file I'm currently using for Hamlib TCP rig control:
Batch File for IC-718
I create a batch file and use the NSSM (Non-Sucking Service Manager) to create it as a Windows Service so I can launch it with windows InitializationКод:@echo off
del D:\Ham\HamLib\log.txt
rem ----------------------------------------------------------------
rem D:\Ham\HamLib\hamlib-w64-4.5.5\bin\rigctld.exe -m 3013 -r COM1 -s 9600 -c 0x5E --set-conf="dtr_state=ON" -p COM7 -P DTR
rem -m 3013 << Seleciona o modelo ICOM IC-718
rem -r COM1 << Porta COM a ser utilizada no CI-V
rem -s 9600 << Set serial speed to 9600 baud
rem -c 0x5E << CI-V address to communicate with the rig
rem --set-conf="dtr_state=ON" << ON turns on DTR, OFF turns it off, Unset disables it
rem -t 4533 << Change the termination network port for text protocol when using the
rem -p COM7 << Use as the file name of the Push-To-Talk device using a device file
rem -P DTR << Use of Push-To-Talk device
rem -vv << Set verbose mode, cumulative upt to 4 Vs
rem -L << List all config parameters for the radio defined with
rem -Z << Enable time stamps for the debug messages
D:\Ham\HamLib\hamlib-w64-4.5.5\bin\rigctld.exe -m 3013 -r COM1 -s 9600 -c 0x5E --set-conf="dtr_state=ON" --set-conf="ptt_share=1" -t 4533 -p COM7 -P DTR -vv -Z -L >> D:\Ham\HamLib\log.txt
I'd appreciate any insights or guidance you can provide on the HAMLIB option in the logbook setup.
Hello,
I cannot to add 70 MHz (4m) band to General Setup (OLEdB error). Can you help?
73 Josef OK2WO
Здравствуйте! Появилась такая проблема, на данный момент работает версия 732, в новых релизах программы (по 737) перестала корректно закрываться программа sdruno, которая запускается одновременно с Loghx3 через установки для внешних программ. Подскажите, пожалуйста, в чем может быть дело и как исправить, до 732 версии все было хорошо.
Вложение 345366
Hey Alexei,
I wanted to share some additional information about using Hamlib Net now with FLDIGI, and you can check out the attachment for more details.
Вложение 345684
For instance, I've successfully run JTDX, WSJT-X, and FLDIGI simultaneously, with all programs having access to RADIO CAT. It's worth noting that this might not be feasible with every program open at the same time, but in certain contexts, it's definitely doable.
Feel free to explore and let me know if you have any questions!
» UTILITIES -> FIND MANAGER (NOT INSERT MANAGER)
NOT WORK with "CURRENT QSO"
NOT WORK with "ALL QSO"
NOT WORK with "SELECTED QSO"
Please Alexei verify, this work only, if find a single manager,
but if find a multiple manager, for example, with different year,
the utilities don't insert the manager, they move on (skip), it should insert the most recent one instead
73 de IK2XDE Andrea
Must be fixed, please check -
https://forum.qrz.ru/355-loghx-appar...ml#post1988066
Unfortunately it doesn't work,
it inserts the manager only if it finds a single result,
if it finds multiple managers with different years,
it does not insert anything, skips the QSO and moves on to the next one.
In this case it should choose the one with the most recent date, and insert it.
Thanks.
73 de IK2XDE Andrea
Yes. If for station found only one manager - insert anyway.
If found many managers - check date interval. If not found valid date interval - manager is not set.
... Well, as variant:
first - check for valid begin and end date
if not found - check for valid begin or end date
if not found again - insert last manager.
Yes I think this is the best solutions.
It will work correct.
Please verify also manual insert, I just send you a video of the problem,
when we push insert, DO NOT CHECK the call of qso.....so insert a manager
to any qso without verify the call.
Thanks.
Wait for new prerelease.
73 de IK2XDE Andrea
