Страница 48 из 68 ПерваяПервая ... 3841424344454647484950515253545558 ... ПоследняяПоследняя
Показано с 706 по 720 из 1017
Like Tree167Спасибо
Тема: LogHX: English version
  1. #706
    03.02.2006
    20,681
    10185
    5463
    Цитата Сообщение от IK2XDE Посмотреть сообщение
    Wait for new prerelease.
    Test this version -
    http://rx4hx.qrz.ru/files/loghx/test..._build_739.exe
  2. #707
    03.01.2021
    196
    18
    Well.....done...!!
    Now UTILITIES --->> FIND MANAGER.....work great...!!
    I will make some other test...but seems al is ok.
    Persist the problem with manual enter.
    if i am on a qso with no manager in the database,
    and I push insert, DO NOT CHECK the call of qso.....and insert any manager
    to any qso without verify the call.
    73 de IK2XDE Andrea.
    IK2XDE Andrea - WWLoc. JN45MQ
    https://www.xdenews.net/ik2xde/logonline/
    RADIO Setup (update 30/08/2025)
    ICOM IC-7600 - (HF - 50MHz.)
    SunSDR2DX - (HF - 50MHz. - 144 MHz.)
    OM Power - OM2000A+ (1.8-50 MHz. Amplifier)
    OB11-3 (11 element - 3 band - 10m-15m-20m)
    OB9-3 WARC (9 element - 3 band - 12m-17m-30m)
    SkyWire Loop (40-60-80-160 m.)
    LogHX Managers Database (update for free)
    https://www.xdenews.net/managers/
  3. #708
    26.07.2023
    41
    4
    How do we change the CQ Zone iun the log?
    VO2NS comes up as Zone 5, but is Zone 2 and cant see where to change it. Thanks.
    - - - Updated - - -
    Disregard. Found it.
    While I'm here... Bandscan window (using the horizontal one) - Changing the font size doesnt seem to change the font size of coloured spots.. the uncoloured ones do change but coloured spots remain rather small.
    The Band review windows (really handy feature, this, by the way!) One can change the fonts but the line size stays the same... increase the font too much and the lines get cut off at the top and bottom. If you need, I can provide a screenshot for both issues after the weekend is done.
    Cheers.
  4. #709
    03.02.2006
    20,681
    10185
    5463
    Unckeck here:
    Hmmm... Yes, it's wrong! Will be fixed in next release!
  5. #710
    26.07.2023
    41
    4
    Thanks. That worked!
    Thought I'd toggled that option yesterday, obviously not. Thanks fopr the tip and quick response
  6. #711
    26.07.2023
    41
    4
    I might be mistaken, but I thought there was a means of saving all received DX spots to a file, but I can't find it.
    1. Is there such a feature in LogHX, and
    2. If there isn't, would that be easy to add, perhaps saving to a text or CSV file, with a new file being started each day, or month?
  7. #712
    03.02.2006
    20,681
    10185
    5463
    Now there is no such function. Is there such a function in other logs? And what is the meaning of this function? Why save spots to a file?
  8. #713
    26.07.2023
    41
    4
    It's useful to have an archive for propagation. I also use old spots for goign through older SDR IQ recordings.
    There are some loggings progs that allow the archiving of spots.. but I have found that VE7CC cluster software that I use to supply spots has an archiver, so I have enabled that.
  9. #714
    03.01.2021
    196
    18
    Hello Alex,
    I hope that in the next and upcoming version you will fix this bug.
    In the ver. 739 of 14/11 unfortunately I see that it is not yet correct.
    Persist the problem with manual enter from MANAGER local database.
    If i am on a qso with no manager in the database,
    and I push "INSERT" in the manager windows,
    Just send you a video, I don't know if you've seen it.
    Always many thanks for all the work you are doing.
    73 de IK2XDE Andrea
  10. #715
    07.07.2023
    16
    3
    3
    Post Feature Request - More filters on AutoCall
    Hi Alexey, hope you are all fine.
    I have a feature request to AutoCall in JT window, of course if it is possible to implement, it is better to draw then explain, currently we have this screen:
    my request is to have the capabilitie to focus on unworked CQ Zones, WPX and GridLocators something like this "really bad MSPAINT job"
    Justifying my request, some times I already worked a country but still didn't have an uncomon zone from this country, or an special event callsign with a different callsign WPX, or the GridLocator is complete new or maybe rare. This feature could be interesting to complete my personal archivements or goals, in special when we talk about JTs modes.
    Thats for now, let me know if you understood or need more clarification.
    All the best 73 PY5XT - Eleandro
  11. #716
    03.02.2006
    20,681
    10185
    5463
    Hello Eleandro!
    Now LogHX use only one pre-calculated statistic - DXCC. But yes, there are many requests to add statistic by Zone, WWLoc, WPX, State, County... Maybe something else
    I am currently working on this issue. I plan to add option for user to choose many pre-calculated statistic. I am currently finishing work on a new version of the log. Adding new statistics will be the next step.
  12. #717
    07.07.2023
    16
    3
    3
    OK Alexei, for me that sounds a good plan.
    Just to you be aware, in the future of course if possible read the CQ DX Marathon (https://dxmarathon.com). I'm participating not in the top tear, but having fun in participating.
    Basiclly DX Maraton from CQ is "Starting January 1 of each year and running until the end of December, the DX Marathon is the perfect answer for the DX-er who needs that extra incentive to get on the air every day! Simply work as many countries and CQ Zones as you can in each calendar year, regardless of the band or mode. Each country and zone counts only once, so you can concentrate on working new ones, rather than working the same ones on multiple bands and modes."
    Maybe in the future, we could have a filter for the current year to help the tracking of worked countries e CQ Zones.
    Thanks a lot for your effort in updating our beloved LogBook app, if you need any help don't exitate to ask.
    All the best, 73 from Eleandro PY5XT
  13. #718
    03.01.2021
    196
    18
    Hello Alex,
    73 de IK2XDE Andrea
    Problem with manual enter from MANAGER local database
    persist also in ver. 739 dated 08/12 unfortunately I see that it is not yet correct.
    Thank you for your attention and your work.
  14. #719
    26.07.2023
    41
    4
    A slight oddity... unless I'm missing a setting to reverse this:
    In the Frequency Display window, using the left and right mouse buttons to change the digits...
    Название: Screenshot 2023-12-12 125427.png
    Intuitively, i would expect the left mouse click to adjust the digit downwards, and the right mouse click to adjust the digit upwards.
    But here, it's the other way round.
    Is there a setting to reverse this, or could it be reversed as it's not (to me, anyway! ) logical?
  15. #720
    03.02.2006
    20,681
    10185
    5463
    In new version will be here -
  1. LogHX: Актуальные релизы и история изменений.
    Ответов: 971
    Последнее сообщение: 08.01.2026, 00:04
  2. DIY UW3DI (for English OPs)
    от UU2JET в разделе КВ: UW3DI
    Последнее сообщение: 18.01.2013, 12:04
  3. KENWOOD TS-2000 (Black Version)
    от UA3IRS в разделе TS-2000
    Последнее сообщение: 16.11.2009, 20:16
  4. Navitel 2.0 Pocket PC Version
    от RX3AOE в разделе APRS
    Последнее сообщение: 26.09.2006, 03:39
  5. windows 64 bit version не ставится
    от UR4LZW в разделе Программное обеспечение
    Последнее сообщение: 12.09.2005, 23:58
