03.04.2021, 19:48 #286Standart Power
- 03.01.2021
- 196
- 18
Hello Alexei,
Using build 631
In the "QSO MANUALLY ENTRY" now you add e drop down menu for "Print Queue" field.....welll....work fine.
But you are missing "N" QSL NOT NEED please add it....
Thanks.
73 de IK2XDE Andrea.
03.04.2021, 22:46 #287Координатор темы
- 03.02.2006
- 53
- 20,557
- 10118
- 5442
Many thanks Andrea! This is a big help for me! In new version I'll make here new functional.
How about variant - checkbox "Send manually" in upload window?
About LoTW: here create ADIF or tq8 file for manually upload?
Look new prerelease 632 for new work of Print Queue here:
https://forum.qrz.ru/355-loghx-appar...ml#post179246973 de RX4HX, Alexei, http://rx4hx.qrz.ru
Ant.: UW4HW, Pwr.: ~500 Wtts
04.04.2021, 00:25 #288Standart Power
- 03.01.2021
- 196
- 18
Yes, for EQSL and CLUBLOG
checkbox "CREATE ADIF TO SEND MANUALLY"
if checked, loghx only create an adif file, to be send manually via
web interface.
Same checkbox here.
Create ADIF file to be send manually with TQSL,
then users sign file with TQSL and send to lotw server.
Thanks.
Ok, using build 632
Please here add this choice "QSL NOT NEED" = PritQueue field = "N"
Thanks in advance.
73 de IK2XDE Andrea
A simple solution would be to create a TXT file similar to NotFoundRecord_Lotw
containing:
"New COUNTRY CONFIRMED" and
"NEW QSO CONFIRMED"
so after synchronization we can see the result.
04.04.2021, 09:37 #289Координатор темы
- 03.02.2006
- 53
- 20,557
- 10118
- 5442
04.04.2021, 21:39 #290Координатор темы
- 03.02.2006
- 53
- 20,557
- 10118
- 5442
05.04.2021, 16:23 #291Standart Power
- 03.01.2021
- 196
- 18
OK....try build 633
works perfectly .... thanks .... !!
With build 633 works perfectly .... thanks .... !!
Well all work fine for me with build 633
In this section it remains for you to fix HRDLOG.
Without upsetting the program, it is enough that it puts UPLOAD
with these possibilities:
ALL QSO
SELECTED QSO
NOT SEND QSO
manually upload to server (only create ADIF)
To do this I think it is necessary to add in the log the field "HrdlogS" (Yes or No)
to know which qso's have already been sent or not to the server.
Thanks for the excellent work you are doing, and the constant commitment.
In the next few days I will ask you again for the management of the local database of managers.
73 of IK2XDE Andrea
06.04.2021, 18:58 #292Low Power
- 16.04.2020
- 89
I seem to be getting this error a lot recently in 631
06.04.2021, 19:46 #293Координатор темы
- 03.02.2006
- 53
- 20,557
- 10118
- 5442
What decimal separator do you use? What skin do you use (may be "broken" skin)?
About new fields in log: i'm waiting "Russian Lotw" - http://Hamlog.online
for add fields for this QSL. I hope it will be soon.
07.04.2021, 00:34 #294Low Power
- 16.04.2020
- 89
and black box.asz
08.04.2021, 08:50 #295Координатор темы
- 03.02.2006
- 53
- 20,557
- 10118
- 5442
To M0CGF: what decimal separator here:
10.04.2021, 16:56 #296Low Power
- 16.04.2020
- 89
The same as your photo shows.
10.04.2021, 18:34 #297Standart Power
- 03.01.2021
- 196
- 18
Using build 634
I try to setup "Digital Mode Windows" using RTTY.
Radio was IC-7600 mode RTTY (not USB or LSB) using FSK
So I will configure MTTY to TX with EXTFSK64.
Problem was that when I start "Digital Mode Windows" Radio go on SSB....
How can I configure to stay on RTTY....??
I find that if I disable CAT (setting NO RADIO) all work fine.
SO I think that HXCATinterface when find DIGI MODE change tu USB (using AFSK)
but I whant to stay in RTTY using FSK.Последний раз редактировалось IK2XDE; 10.04.2021 в 18:42.
10.04.2021, 23:48 #298Координатор темы
- 03.02.2006
- 53
- 20,557
- 10118
- 5442
11.04.2021, 00:25 #299Standart Power
- 03.01.2021
- 196
- 18
Well, everything works perfectly.....!!
Sorry but there are still some configurations / settings that I don't know.
Have you thought about how to update the management
of the managers on the local database ... ??
11.04.2021, 13:52 #300Standart Power
- 03.01.2021
- 196
- 18
In the "SET FILTER WINDOW"
"Use Costum Filed" section,
Freq field was missed....please ad it....
I know that there is band filter,
but is different search for 20m qsl or for 14,260 qso.
Please add all log field here.....hi...
Thanks in advance.
167Спасибо
